XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Operating Systems
Reply
Old 05-31-2007, 12:55 PM   #1
N/A Matt
Angry Weird user account issue on XP after uninstalling Logitech Setpoint software
I have no idea why this would change anything with the accounts. I uninstalled the Logitech setpoint software for my G5 mouse as in-game it was acting very odd, not responding to the increase or decrease buttons for sensitivity or going in the wrong direction.
So I uninstall and restart, I'm not logged in as Admin instead of the user I was on, "jose" .
Try as I might I could not log back in as Jose. I coppied all the saved files over from that account to the admin folder. Under user accounts it did not even show the Jose account, it just showed admin. I created a new account thinking I could copy the files over, once I did the new account also wouldn't show.
Anyone have any idea what is going on here? With all the times I've installed XP I have not come across this one, but it is certainly the most frustrating. I built this system for my uncle, it had Vista Business x64 but he was told by some one it wasn't compatible with a lot of stuff so I took it off for him, and put on XP. It was a clean install so I know there is nothing left over from Vista causing the issue.
For some reason now it is also showing the HD as a USB device in the taskbar. Try as I might I can't get rid of that either.
This whole project has been a huge pain so far, so any help would be greatly appreciate.
-Matt
N/A Matt is offline   Reply With Quote
Old 06-04-2007, 11:20 PM   #2
jimmyz
Xtreme 3D Team Member
jimmyz's Avatar
use system restore to go back to before the driver removal. that should set things right.
__________________
QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
DFI LP LT X-38 T2R
2X HD4850's water cooled , volt modded
Thermaltake 1KW Psu
4x Seagate 250GB in RAID 0
8GB crucial ballistix ram
jimmyz is offline   Reply With Quote
Old 06-06-2007, 07:56 PM   #3
ak_47_boy
My computer won't go into standby since i installed setpoint for my G5. Sometimes the mouse looses power and i got to restart to fix.
ak_47_boy is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
