XtremeSystems Forums
Reply
Old 05-27-2007, 08:52 PM   #1
lilflippy
What do ya think of using 50/50 mixture of coolant in watercooling system?
What do ya guys and girls think about it?
How will i perform?
lilflippy is offline   Reply With Quote
Old 05-27-2007, 09:00 PM   #2
Truckchase!
Truckchase!'s Avatar
If you're not running a chiller setup there is no reason; you'll just loose performance. Just a dash of antifreeze is enough to keep bacteria away and that's all you need. I run about 95/5 distilled/RV antifreeze.
__________________
Asus P6T-DLX V2 1104 & i7 920 @ 4116 1.32v(Windows Reported) 1.3375v (BIOS Set) 196x20(1) HT OFF
6GB OCZ Platinum DDR3 1600 3x2GB@ 7-7-7-24, 1.66v, 1568Mhz
Sapphire 5870 @ stock until DP Flicker is fixed in unlocked BIOS
X-Fi "Fatal1ty" (endorsements suck) & Klipsch ProMedia Ultra 5.1 Speaks/Astro A40 Mixamp with beyerdynamic DT-880 Pro (2005 Model) and a mini3 amp
WD 150GB Raptor (Games) & 2x WD 640GB (System)
PC Power & Cooling 750w
Homebrew watercooling on CPU and GPU
and the best monitor ever made + a Samsung 226CW + Dell P2210 for eyefinity
Windows 7 Utimate x64
Truckchase! is offline   Reply With Quote
Old 05-27-2007, 09:06 PM   #3
CedricFP
CedricFP's Avatar
A little antifreeze and a little anti-corrosion is all you need. As of yet, nothing beats distilled water in a loop in both terms of performance and practicality.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 05-27-2007, 09:12 PM   #4
Envydia007
Envydia007's Avatar
80/20 is even too much.
__________________
INTEL Q6600 G0 @ 3.6GHz 1.4V
MUSHKIN 2X2GB @ 1066MHz 1.9V
GPU: EVGA GTX 260 216 @ 702/1404/2000
PPU: EVGA 9800GTX KO @ 738/1836/2250
ASUS P5E X38 @ 1600MHz FSB
X-FI TITANIUM FATAL1TY
WD 76GB X 2 RAPTORS RAID 0 10KRPM
WD 1TB CAVIAR BLACK 32MB STORAGE
CORSAIR HX1000W PSU
WINDOWS 7 PRO 64-BIT OS
HANNSPREE 28" 1920X1200 RESOLUTION
Envydia007 is offline   Reply With Quote
Old 05-27-2007, 09:14 PM   #5
lilflippy
So would distilled water and a biocide to prevent algae be ok?
I also have Chrome Plated fittings on my cpu block and Nickel Plated Brass fittings on my rad would i need antfreeze to prevent corrosion? Is antifreeze needed to lubricate my pump?
Old 05-27-2007, 09:34 PM   #6
Hard H20
Xtreme Cruncher
Send a message via ICQ to Hard H20 Send a message via Yahoo to Hard H20
Yes, distilled and biocide is all you need in your loops to keep the algae in check. I would recommend Petosin G11 / G12 if you're concerned about corrosion. You can find your Petosin and PT Nuke both here: http://www.petrastechshop.com/wacoac.html
__________________
Charles Barkley
"Poor People have been voting for Democrats for the last 50 years ... and they are still poor."
Hard H20 is offline   Reply With Quote
Old 05-28-2007, 06:06 AM   #7
mcoffey
Banned
no,
the nobility of those two metals are close enough not to cause any problems. A 50/50 mix has to hi a viscosity and cause problems with flow rate and such. Pentosin in a 1/9 ratio with distilled water should keep you safe in any event.
gl and have fun,
andyc
mcoffey is offline   Reply With Quote
Old 05-28-2007, 06:18 AM   #8
IanY
I am Xtreme
1% to 2% Valvoline Super Racing Zerex, biocide and 98% to 99% distilled water. I don't even use biocide. I use provodine iodine. In one system still going strong, I use 0.1% bleach.
I am not convinced about the 10% Pentosin thing.
Distilled water is the best coolant. Mixing it with anything else just lowers the cooling effectiveness.
IanY is offline   Reply With Quote
Old 05-28-2007, 07:42 AM   #9
MrToad
I am Xtreme
MrToad's Avatar
That seems to be the consensus. The least you add to you distilled water, the better it will perform as coolant.
**Edited for being deliberately inflammatory. Tsk, tsk... you should know better stupid batrachian.
MrToad is offline   Reply With Quote
Old 05-28-2007, 07:47 AM   #10
IanY
I am Xtreme
Deleted to protect the innocent
Old 05-28-2007, 08:01 AM   #11
MrToad
I am Xtreme
MrToad's Avatar
Hahahaha... a comment so timely... did you see the flame fest I'm having with a bunch of Europeans ?
I did... that's the whole point of the coment
But then I edited it... in the end of the day is funny or not depending on who and in what mood reads it.
Old 05-28-2007, 08:15 AM   #12
IanY
I am Xtreme
Mr. Toad, you're ok
Old 05-28-2007, 08:24 AM   #13
Skauneboy
Skauneboy's Avatar
Not entirely true. About 5% of glycerine is supposed to increase thermal conductivity. http://www.dow.com/glycerine/resources/table13.htm
__________________
CM Stacker STC-T01, Corsair HX620, ASUS P5Q-Deluxe, E8400 E0 @4.05/1.375v,
Crucial Ballistix PC6400 @560/5-5-5-18/2.1v, HIS HD4870 w/ vmod.
Laing D5 + EK X-TOP , D-TEK Fuzion w/ 4.5mm nozzle, D-TEK Fuzion GFX w/ "Saltshaker" mod,
Thermochill PA120.3, 1/2" 3/4" Tygon B-44-4X.
Skauneboy is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
