XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 05-27-2007, 10:12 AM   #1
ruffus
reading manifold
well this might be a dumb question but i don't want to muck things up
i just need to know what markings to go buy the psi markings or do i go by the markings for the refrigerant that i am using please help
ruffus is offline   Reply With Quote
Old 05-27-2007, 10:27 AM   #2
4Qman
-100C Club
4Qman's Avatar
Send a message via MSN to 4Qman
Mate no disrespect but its a bit of a Noob question when playing with refrigerant and material that can be dangerous if not used properly.
90% of the time its safe but thats when you know whats going on, not when your stuck deciding what part of the gauge your reading I mean this in the kindest possible way dude. A few people may be more strict on such a question as saftey is a big factor on this forum. "As it should be"
4Qman is offline   Reply With Quote
Old 05-27-2007, 10:35 AM   #3
tim-
Send a message via MSN to tim-
well, the pressure is what you look at, you get the temptures by using a thermometer.
tim- is offline   Reply With Quote
Old 05-27-2007, 10:56 AM   #4
ruffus
ok my system is running and i know what temp it is running at and i know what temp i am going for but my gages have markings fro r404a r134a and r22 plus the psi markings know i have been told that the markings that r marked for the refrigerant or for mixing and to just use the psi markings for charging and tunning is this right
Old 05-27-2007, 11:06 AM   #5
Big SturL
HVAC/R student
Big SturL's Avatar
Send a message via ICQ to Big SturL Send a message via MSN to Big SturL
Pressure is pressure. When using low pressure gasses, any manifold will do. For higher pressure gasses (such as used in cascades) need stronger, an more expensive, manifolds.
__________________
...is no longer working as an assistant HVAC/R-installer...
But, is still blasting 20000 songs of real Rap
Big SturL is offline   Reply With Quote
Old 05-27-2007, 11:19 AM   #6
ruffus
so does this mean that i just go by the psi markings
Old 05-27-2007, 11:25 AM   #7
tim-
yes, kind of.. the temptures on the manifold describs evaporating tempture at specific pressure.
use the termometer to check temptures and use the manifold for pressure.. that's what I do and that's the way I'm learn to use it.
the tempture on the highpressure side of manifold describs if it's possible to condens the refrigrant to liquid or not by comparing tempture at specific pressure with the tempture on outlet of condenser.
Old 05-27-2007, 11:31 AM   #8
ruffus
thanks tim i just did not want to put my compressor in to too much of a vac as it would muck it up
Old 05-27-2007, 12:31 PM   #9
wdrzal
I am Xtreme
wdrzal's Avatar
4Qman how can you be so harsh on a question most,including you ,and the rest who posted plus those who didn't answer or don't know the answer too.
ruffus welcome to XS
as you can see their are many scales on your hi & low side gauges.
First always remember this:If you know the pressure you know the temperature,if you know the temperature,you know the pressure.this applies as long as liquid and gas are both present, the % is lower than 1% so thats a safe number,thats another topic.
your gauges have pressure scales usually psi & bar . They also have temperature scales for the 3 refrigerants you listed. lets use 134a and psi and Fahrenheit for temperature.
I don't know why but psi is imperial as Fahrenheit,as is bar & centigrade
metric system
Here at XS most read psi for pressure and centigrade for temperature.(I suspect until -40 where they are the same its easier to get to -20C than -20F)
now the explanation useing the imperial system ,PSI & Fahrenheit,you can google up a temperature & pressure converters .
first say you have a tank or system that has >1% liquid is at ambient temperature(room temp) put hose on tank of 134a and read pressure say pressure is 70 psi now follow the needle to the 134a inner scale (Fahrenheit) use can use a piece of paper as a straight edge ,set edge of paper on 70 psi and run to needle center pivot pin. or just imagine a straight line as if the needle was there. It will cross the F scale @ exactly 69 degrees F. providing refrigerant is stabilized and it a pure 134a mix. A lot of guy here mix refrigerants, don't do that. how did I know that ,reread bold print.
your gauge has a built in pressure/temperature chart for those 3 refrigerants.
yes you can use that manifold on other refrigerants but,you then just read pressure and consult a P/T (pressure/temperature) chart.
To sum up as long as liquid and gas are present, you can read pressure and know temperature or read temperature and know pressure.
so now add accurate thermometer to tank it is 70 psi so its temperature is exactly 69 Fahrenheit.
Read up on pressure/temperature charts. Then read up on sub-cooling and superheat. thats another day in the future.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 05-27-2007, 12:38 PM   #10
wdrzal
I am Xtreme
wdrzal's Avatar
your low side gauge goes to -29.92 hg vacuum always rounded and marked 30 hg vacuum then goes to 0 the to ultimate high pressure for low side gauge,usually around 350 psi.
the high side gauge works the same way for reading pressure and temperature.starts at 0psi and goes to 500 to 800 psi depending on manifold set.
__________________
Register today .
Old 05-27-2007, 01:25 PM   #11
mytekcontrols
mytekcontrols's Avatar
wdrzal stated... 4Qman how can you be so harsh on a question most,including you ,and the rest who posted plus those who didn't answer or don't know the answer too.
Very good point
I think many of us need to be less harsh about what we say to others on this forum. Just because some one thinks they are an expert, doesn't mean they need to be critical of others, or what they are sharing. We are all here to learn, to share, and to hopefully teach. Let's just remember how it feels to be starting out, and how exciting that can be.
__________________
Michael St. Pierre
  • Worked 15 years for Polycold Systems
  • Now Self-Employed
  • Manufacture Heat Load Controllers
  • Also do contract service work on Polycold units
mytekcontrols is offline   Reply With Quote
Old 05-27-2007, 03:46 PM   #12
ruffus
ok thanks alot this helps me out alot
Old 05-27-2007, 04:09 PM   #13
runmc
Admin
runmc's Avatar
If you are using r404a and you gauges are scaled for r404a, then the pressure/temperature scales will correspond and be accurate.
If your using R22 and your gauges are not scaled for r22 you can get a P/T chart for r22 and match the pressure from you gauges to the pressure - temperature reading on the chart and find out your temperature that way.
You don't need a thermometer. Under normal circumstances, a refrigerant is a specific temperature and a specific pressure.
__________________
Worthy is the Lamb
runmc is offline   Reply With Quote
Old 05-27-2007, 05:04 PM   #14
wdrzal
I am Xtreme
wdrzal's Avatar
you do need a thermometer to measure sub-cooling and superheat as I mentioned, Thats another thread, when you don't know the exact charge to weigh in ,or measure by volume, sub-cooling superheat is your best choice to charge by, a sight glass or ultra sonic sight glass (i found to work well)will also do on suction tube. any refrigerant leaving the evap as liquid and boiling off does the evaporator little good.
I still believe sight glasses gives noobs a visual of whats happening in the tubes. A picture is worth a thousand words
Have a happy and proud memorial day Ron and other members in the U.S.A.and our allies.
__________________
Register today .
Old 05-27-2007, 05:45 PM   #15
Athanatos
Athanatos's Avatar
http://www.xtremesystems.org/forums/...d.php?t=144603
Athanatos is offline   Reply With Quote
Old 05-27-2007, 11:38 PM   #16
[XC] 2long4u
Xtreme Cruncher
[XC] 2long4u's Avatar
Send a message via Yahoo to [XC] 2long4u
Does anybody have a t/p chart for R290?
[XC] 2long4u is offline   Reply With Quote
Old 05-31-2007, 06:14 PM   #17
wdrzal
I am Xtreme
wdrzal's Avatar
I just noticed , that some companies as Refco gauges are oppisite of what I described above, the principal is the same but someone posted a pic of a gauges that had the Temperature scales in the outer rings and pressure scales on the inner rings
This is oppisite to all my equiptment just the scales are oppisite. pressure look for psi & bar................temperature look for Rxxx number refrigerants......you read them the same as described.
__________________
Register today .
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
