XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 05-24-2007, 09:52 PM   #1
DarthBeavis
Infected with the Ewe Flu
DarthBeavis's Avatar
DarthBeavis Clinic Server V3.0 Project Log
The waterbox-based version 2.0 has been scraped and re-purposed as a workstation. The server project is now based on a Mountain Mods Duality.
The server will contain two identical setups. One side will always be powered down and only used if the primary side has a non-hard drive hardware failure. The server will use raid 1 Raptor Xs for HDD security as well. If there is a hardware failure, the server is equiped with swappable hard drive bays so the staff can just pop out the two HDDS from on set of bays, pop them in the other side, fire that other side up and then run like Forrest Gump.
Hardware:
Intel E6600 Core 2 Duo
4 Gigs OCZ RAM (two 2 gig sticks)
Intel Bad Axe 2 mobo
DD TDX block on CPU
DD Maze 4 block on NB
DD D5 Pump
Thermochill PA 120.2 Rad with 4 Yate Loons in Push/Pull
Matrix Orbital M222
Corair 620 watt modular PSU
Note: Two of each of the above of course since this is Duality
My goal is almost ZERO downtime. Custer Xeon servers would be a bit spendy. We must have our system running to run the business (almost paperless medical records folks).
And yes, I am an attention monger . . .we are expanding our clinic (taking over an additional 1800 sq ft to our existing 3000 sq ft) which means a total remodel. Part of our plans (well, I part) is to have an display area that joins the lobby and middle work area for displaying the server and Waterbox workstations (like a shelf between teh two) with a shelf lower and behind the display in the middle for some of the network hardware and such). We plan to make the lobby a hot spot as well and are going to put in a game system of some sort for the kids and teenie boppers.
After a short break I am getting this puppy finished. Leak testing tonight. After that, wire management then use Acronis to copy the server over.
Nice PSUs:
Front:
Backup System:
Primary System:
Baby got back:
Close up of rads and rats nest to straighten up:
DarthBeavis is offline   Reply With Quote
Old 05-24-2007, 10:07 PM   #2
dinos22
...you two characters
dinos22's Avatar
red liquid
don't see that every day
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 05-24-2007, 10:42 PM   #3
.Logic
I agree on the red liquid, looks really good though.
If you don't mind me asking what type of clinic do you own (veterinary, medical, physchological etc)
Keep up the awesome work, I'm now subscribed to all your worklogs
__________________
.Logic is offline   Reply With Quote
Old 05-24-2007, 11:12 PM   #4
DarthBeavis
veterinary clinic - 6 doctor practice - small and exotic
Old 05-25-2007, 12:00 AM   #5
clone38
clone38's Avatar
Nice one m8,seen this build a while back and thought you may have trashed it,glad to see it`s up and running
__________________
EVGA 4 Way- 920 DO- Corsair 6GB GT 2000MHz
Crucial 64GB SSD- Corsiar HX 850- Megahalems
XFX 5870 CF-X-Fi Titanium - Fatal1ty Professional
clone38 is offline   Reply With Quote
Old 05-25-2007, 09:52 AM   #6
DarthBeavis
I had to take time off to travel to Maui. As soon as this one is done I have to finish this:
1. Clinic waterbox workstation
2. Add pelt to Order 66 box:
3. Install Team Next Gen/SSilencer modded Vapochill back into Hellmouth Box (will be quad core):
4. Autopsy build (see Autopsy project log - this is the biggie)
5. Go back to school to get meh MBA
Old 05-26-2007, 01:44 PM   #7
clone38
clone38's Avatar
Wow busy busy,keep up the good work there m8
__________________
Old 06-05-2008, 04:51 PM   #8
RealRedRaider
Banned
An oldy, but a goody...
MM CASE + DARTH BEAVIS = PURE GOODNESS
RealRedRaider is offline   Reply With Quote
Old 06-05-2008, 06:35 PM   #9
Yeknom
DB = Pwn
Yeknom is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
