05-23-2007, 12:39 AM
#1
Xtreme News
GIGABYTE Odin PSUs with Software Control
Odin GT, the flagship model, on completion, had post-design testing which took another year to complete. Among the influences taken into account during design and testing was Microsoft’s new OS Vista, the new generation of dual or more PCI-express display cards and the Intel almighty multi-core processors. What does this all mean? Simply put, all new technology requires the right type of supporting hardware to maximize its glory.
At a glance, Odin GT seems pretty well… ordinary. Zoom in, and a few things crystallize.
Behold. A software management solution embedded in this little monster. How this works? In brief, it manages the following: output voltages and load on each rail, power fan speed tweak, localized or preset temperature monitors, power supply lighting control, proximity warning bells and even present user modes for performance, normal use or silent operation. This equates to absolute manageability.
Intel 12V V2.2 specification guidelines were not enough for Odin. Odin comes live with no less then 4 rails of power output. This means even more added stability for your personal computer.
If the above is not enough for you to play with… enter cable management. This absolves untidy cable interiors, impeded internal aerodynamics of airflow and last but not least, it just looks good.
Japanese capacitors, a large illuminated heat sink, 14CM dual-ball-bearing fan top it all off to allow Odin to fly the 80+ efficiency flag, meaning, in short, more than 80% of your input power is usable with average components clocking in at about 20% less than that. This equates to two things. 20% more power or 20% less power loss and 20% less heat generated from the power loss.
http://www.gigabyte.com.tw/News/Ther...px?NewsID=1331
__________________
05-23-2007, 12:55 AM
#2
Xtreme Mentor
No comment until reviews. I`m not totally convinced though
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M
Originally Posted by soundood
you sigged that?
why?
05-23-2007, 02:20 AM
#3
Xtreme Mentor
"ODIN, releases the child within you!"
__________________
Originally Posted by LexDiamonds
Anti-Virus software is for n00bs.
05-23-2007, 03:26 AM
#4
Muslim Overclocker
Yes. No more opening the case for MM readings!
__________________
My watercooling experience
Water
Scythe Gentle Typhoons 120mm 1850RPM
Thermochill PA120.3 Radiator
Enzotech Sapphire Rev.A CPU Block
Laing DDC 3.2
XSPC Dual Pump Reservoir
Primochill Pro LRT Red 1/2"
Bitspower fittings + water temp sensor
Rig
E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
05-23-2007, 06:55 AM
#5
Thrusters on full!
Well... only if it's accurate enough, it would be sad if these software redaings were of same quality as mobo temp sensors.
__________________
Originally Posted by miahallen
FurMark is a waste of time.....it's not ranked on HWBot
W3520 on Rampage II Gene | hardmounted TRUE + 2x 120mm push-pull | 3x 2gig of HCF0
Zombie GTX280 | look mom, i has no IHS | Thermalright HR-03 GT
Lian-Li PC-A70B | Brushed aluminium tank
MOA 2009 Poland #2
Test bench: Clarkdale, several AMD Confidentials
05-23-2007, 09:31 AM
#6
Xtreme PSU Tester
The readings won't be accurate because they'll be measured at the PSU's PWM. No accounting for resistance created by the wires to the modular interface, the modular interface or the cables going from the PSU to the peripherals.
That said, still a cool idea. Just the ability to tweak the voltages via software should be, at the very least, "fun."
05-23-2007, 09:36 AM
#7
What does designing a power supply has to do with Vista?
"Among the influences taken into account during design and testing was Microsoft’s new OS Vista"
P.S @xoqolatl 10X
05-23-2007, 09:39 AM
#8
Xtreme Mentor
+1 for 14cm fan
05-23-2007, 09:46 AM
#9
Thrusters on full!
That means software is Vista compatible, and driver probably has WHQL stamp.
__________________
MOA 2009 Poland #2
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
