XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware > Storage
Reply
Old 05-22-2007, 08:08 PM   #1
CedricFP
CedricFP's Avatar
Partitioning HDD - Slower Performance?
I currently run 2 partitions. Windows installed on C, games installed on D.
Would it benefit my gaming performance if they were installed on the same partition as windows? I think I might have read somewhere that performance is slowed when using a partition that windows isn't installed on.
XP PRO SP2, btw.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 05-23-2007, 12:49 PM   #2
RealTelstar
RealTelstar's Avatar
Send a message via MSN to RealTelstar
Performance decades when windows is accessing both partitions at the same time. If you can get another drive (and its not ide on the same channel) to put the games onto it'll be better.
__________________
Gaming Rig:
| CPU: Xeon E3110 Q807 @4GHz | Cooling: TRUE with Scythe Ultra Kaze 3000
| Motherboard: Asus Rampage Formula | RAM: 4GB G.Skill F2_9600CL5D_4GBPI | Video: Asus GTX 280
| Storage: Controller: LSI Megaraid 320-2E 128MB | 3x Fujitsu MAU 146 GB 15k raid0 + Samsung F1 1TB + 2x WD GP 1TB
| Audio: Creative SB X-Fi Xtreme Fatal1ty Pro | Sennheiser HD595 hearphones
| Case: Lian-Li PC 78 | | PSU: Silverstone Zeus 750W | Display: Samsung 2693HM 25,5" LCD
| OS: Vista x64 / Windows7 x64 b7000 (testing)
Music Rig:
| Dual Xeon with Reveal 5A active monitors
AC powered through APC Smart-UPS 1500 and APC PowerSurge
RealTelstar is offline   Reply With Quote
Old 05-23-2007, 11:57 PM   #3
CedricFP
CedricFP's Avatar
Ahh, I see. So, assuming this, I could assume that putting games onto C drive will ensure that the HDD doesn't need to access both partitions?
__________________
Old 05-26-2007, 05:16 AM   #4
Neon Biker
Neon Biker's Avatar
Yes, but on the other hand keeping C: as small as posible also helps boosting the performance.
__________________
Docendo discimus (lat.)
Neon Biker is offline   Reply With Quote
Old 05-26-2007, 05:48 AM   #5
RealTelstar
Depends. on where is your swap, if indexing service is enabled on the second partition, if other programs running are reading/writing there.
In general is better to have a separate DRIVE (of the same interface) for swap and temporary.
__________________
Gaming Rig:
Music Rig:
Old 05-26-2007, 08:57 PM   #6
CedricFP
CedricFP's Avatar
I see.
Thanks RealTelstar and NeonBiker.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
