XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme 3D Team
Reply
Old 05-21-2007, 11:27 PM   #1
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
P5K + QX6700 + Vapo + 8800Ultra
Intel QX6700 2.66Ghz ES
Asus p5K deluxe
Corsair PC10000 Dominators
Enermax Galaxy 1Kw
Asetek Vapochill modded by Chilly1
Nvidia 8800 Ultra Max clock with stock cooling 733/1222
Unmodded shaders
Single card runs on P35 platform
Vapochill R507 modded and tuned for quad core
Max quad FSB 480Mhz
http://valid.x86-secret.com/show_oc?id=199946
Max duo FSB 551Mhz
http://valid.x86-secret.com/show_oc.php?id=199837
Futuremark 2001
Max clocked, 73/1222
Futuremark 2003
Futuremark 2005
Picked up the clocks more
Futuremark 2006, 16K is pretty good for single card stock sink.
SLI, Bandwidth and Pi stuff coming
__________________
Intel Core i5 661 @ 4.6Ghz
Gigabyte P55A - supports 32nm now
Gigabyte GTX 260 SOC
Corsair Dominator 8GB 2200C8
Intel SSD RAID 0
http://valid.canardpc.com/show_oc.php?id=925582
FUGGER is offline   Reply With Quote
Old 05-22-2007, 07:14 AM   #2
VictorWang
Uni Hardware
VictorWang's Avatar
very nice 01 results
hope to see u at computex
__________________
Uni Hardware:
http://www.unihw.com
Team China
VictorWang is offline   Reply With Quote
Old 05-22-2007, 08:04 AM   #3
rob[GL]
rob[GL]'s Avatar
Good work as always!
__________________
Intel Core i7 920 @ 3.8GHz (183x21)
Gigabyte EX58-DS4 BIOS F5
3GB PATRIOT PC3-10666 DDR3
Sapphire Radeon HD4870 512MB BLACK
2x500GB SEAGATE SATA-II 7200.11
OCZ GameXstream 750W PSU
Antec Three Hundred Chassis
rob[GL] is offline   Reply With Quote
Old 05-22-2007, 10:37 AM   #4
FUGGER
Xtreme Owner
FUGGER's Avatar
I have two cards and testing both, as you can see there is a difference in the two as one is much better than the other.
Now I just need to tune a bit more and pass Denny.
__________________
Intel SSD RAID 0
Old 05-22-2007, 12:46 PM   #5
G H Z
Champion
G H Z's Avatar
Nice benching setup
G H Z is offline   Reply With Quote
Old 05-22-2007, 02:23 PM   #6
Pedro Rocha
Xtreme Old School Moderator
Pedro Rocha's Avatar
Nice numbers as always Charles
How much VCore are you using on the QX6700? and how the Vapo holds the heat?
My QX6700 do 10 seconds / Rend 4 Cores 2088 CB on Cinebench with P5K dlx on air cooling (tuniq)
Try to run Cinebench wth yours in Vapo please
I really love these P5K and the CPU Voltage Damper (really efective), also the performance per clock seems to be near the 975x with much more FSB to go
Pedro Rocha is offline   Reply With Quote
Old 05-22-2007, 02:25 PM   #7
Pedro Rocha
Use LOD's!!!
Just try 4.8 for Nature and you will jump 30fps at least
Old 05-22-2007, 03:45 PM   #8
FUGGER
Xtreme Owner
FUGGER's Avatar
I will load up cinebench, I should be able to do it around 4.2Ghz @ 1.6v
__________________
Intel SSD RAID 0
Old 05-22-2007, 03:54 PM   #9
xs64
xs64's Avatar
FUGGER, does SLI with G80 works in P35, sir?
xs64 is offline   Reply With Quote
Old 05-22-2007, 04:18 PM   #10
ZoLKoRn
Xtreme X.I.P.
ZoLKoRn's Avatar
Send a message via MSN to ZoLKoRn
Very nice score ! , How you disable core ?
Thank.
__________________
Sorry For My English
OverclockZone Team
THAILAND
Originally Posted by hipro5 View Post
Actually there is NO NEED for 164 phases that companies put in nowadays mobos....
FOUR (4) are enough with nowadays materials and maybe SIX (6) with the upcoming Gulftowns....
The 1024 phases is a "marketing trick" nowadays....
You will buy MY mobo because I put 2048 phases in my motherboard....
ZoLKoRn is offline   Reply With Quote
Old 05-22-2007, 06:12 PM   #11
FUGGER
Xtreme Owner
FUGGER's Avatar
No, I will switch back to 680i for SLI
__________________
Intel SSD RAID 0
Old 05-22-2007, 06:19 PM   #12
WRC
excellent results!
WRC is online now   Reply With Quote
Old 05-22-2007, 07:12 PM   #13
boblemagnifique
Xtreme X.I.P.
boblemagnifique's Avatar
Send a message via ICQ to boblemagnifique Send a message via AIM to boblemagnifique
Great Score Fugger
Impressive Pedro
What freq/timmings ram ? please
__________________
OCM Member / IXTREMTEK Admin !!
DDR1 2*256 BH5 Adata @324.7Mhz 1.5/2/2/5 1T at 4v @318.6Mhz Benchs
DDR2 1*512 Kingston Pc8500 @702Mhz 5/5/5/18 at 2.42v réel
DDR2 2*1024 Cell Shock Pc8000c4 @534Mhz 3/3/3/8 at 3.5v réel
Cooling : XP90C , Big Typhoon , waterchiller R507 , LN2 ....
boblemagnifique is offline   Reply With Quote
Old 05-22-2007, 10:04 PM   #14
FUGGER
Xtreme Owner
FUGGER's Avatar
Cinebench at 4.1Ghz and 4.2Ghz
__________________
Intel SSD RAID 0
Old 05-22-2007, 10:46 PM   #15
Nordling
Nordling's Avatar
Send a message via ICQ to Nordling
stock cooling Unmodded shaders
Why not mod's?
__________________
Nordling is offline   Reply With Quote
Old 05-22-2007, 11:16 PM   #16
FUGGER
Xtreme Owner
FUGGER's Avatar
I will, just stating that they are not modded for these runs.
From looking at others around the net, the cores hit 700Mhz on average with stock heatsink and good air cooling to the case or bench.
I cannot match the 488FSB in with all four cores enabled, 480 and widows freezes but it seems I can bench all the way up to 479 on this board, I need to jump back onto the P5K3 again to see what it maxes at.
__________________
Intel SSD RAID 0
Old 05-23-2007, 12:03 AM   #17
bmg
I am Xtreme
My Ultra's pretty much the same as the weaker of your two, 702 benches fine, but 720 is just a bit much until I voltmod the card.
I'm curious how you disable cores in the P5K Deluxe bios? There must be a secret setting I'm missing
__________________
I7 950 processor/Ultra 120 Extreme cooling/Asus P6T Deluxe V2 motherboard/6Gb corsair 1600C7 ram
Evga 280 FTW video/Mitsubish 2070SB 22" monitor/SB XFi-Titanium sound/Intel X25-M 160gb
Enermax Galaxy DXX 1000w Power Supply/Coolermaster RC-832 case
bmg is offline   Reply With Quote
Old 05-23-2007, 06:33 AM   #18
k|ngp|n
k|ngp|n's Avatar
Real nice FSB's Charles on the P5k
Did you mod those shaders or waiting for SLI?? Are you going to waterchill the cards?
__________________
k|ngp|n is offline   Reply With Quote
Old 05-23-2007, 06:44 AM   #19
Movieman
I'm feeling BLUE!
Movieman's Avatar
ahh, a place where I can compete!
See if you can get down to 8 seconds in Cinebench!
Nice rig there Charles!
__________________
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Frisch View Post
If you have lost faith in humanity, then hold a newborn in your hands.
Movieman is offline   Reply With Quote
Old 05-23-2007, 07:05 AM   #20
kiwi
Xtreme
kiwi's Avatar
Send a message via MSN to kiwi Send a message via Skype™ to kiwi
Nice gaming rig
Only through msconfig Not many MBs have it in bios
__________________
kiwi is offline   Reply With Quote
Old 05-23-2007, 09:58 AM   #21
FUGGER
Xtreme Owner
FUGGER's Avatar
I found out that firing up over 500FSB will lose two cores. I have no control but I known and expect it to happen on this board.
Vince, wanted to get my initial benches done.
Kiwi, yep this is my gaming rig. I need to fire up on the cascade for better placement on the ORB.
__________________
Intel SSD RAID 0
Old 05-23-2007, 12:08 PM   #22
perkam
Live Long And Overclock
perkam's Avatar
Send a message via MSN to perkam Send a message via Yahoo to perkam
I preferred it when Fugger was going purple X(
But great stuff nonetheless
Perkam
__________________
Star Trek Online Open Beta
Name: Captain Maxentius
Rank: Lt.
Ship: USS Kira
Class: Miranda-Class
Preferred Class: Akira-Class
perkam is offline   Reply With Quote
Old 05-27-2007, 05:34 AM   #23
FUGGER
Xtreme Owner
FUGGER's Avatar
Some SLI results on 680i, this board is hurting. Switched back to x6800 and cannot get a high stable bus.
A CPUID with decent memory speed in dual channel
http://valid.x86-secret.com/show_oc.php?id=202056
I ran a 2K1 and picked it up a bit for 2K3 and 2K5
http://service.futuremark.com/compare?2k1=9206064
http://service.futuremark.com/compare?2k3=5378511
http://service.futuremark.com/compare?3dm05=3081093
I ran 2K6 a few days ago on the quad
http://service.futuremark.com/compare?3dm06=1997772
__________________
Intel SSD RAID 0
Old 05-27-2007, 01:19 PM   #24
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
Fugger -
High FSB's arent impossible with Quad Core and 680i.
one little mod, and alittle time to tune that mod, and you can really change how that board works when using quad core.
heres some examples of the stuff I been doing with it.
8 x 450 easily 3dmark, and game stable, and been running like this for about 4-5 days now.
all the details, and more screen shots can be found in my post about it, in the Vmod area.
http://www.xtremesystems.org/forums/...d.php?t=145524
give the mod a shot, its easy, and only takes a 1K VR, and about a hour or so, of tweaking to really get down.
it's not a quick, instant results mod, as you really do have to take the time to tune the voltage to near perfect voltage range, but as you can see, the results are definatly worth the effort.
__________________
Kunaak is offline   Reply With Quote
Old 05-27-2007, 01:33 PM   #25
NickS
I am Xtreme
NickS's Avatar
Not bad. 4.0 on a vapo is pretty low for 05, though.
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
