XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware > General Memory
Reply
Old 05-19-2007, 11:07 AM   #1
little_scrapper
Will I have any problems running my DDR1000 5-5-5-15 @ DDR667 3-3-3-8?
Whats the advantages or disadvantages of the different levels.
I can run my ballistix DDR1000 D9GMH (i peeked under the hood) at over DDR1000 5-5-5-15. or I can run is @ DDR1000 4-4-4-14 if I bump the V up to near 2.4v. But I worry about running them too hot. I do have a 80mm fan on them.
I can run these at DDR800 4-4-4-12
Or I can run these in sync for DDR667 3-3-3-8 @ 2.0V or a little less.
Lately I have just been running these @ 3-3-3-8 and 2.0v. I have not, however, tested to see just how high I can go with these timings. But I cant tell any difference between any settings. Doesnt seem to effect my FPS at all. Only benchies show any difference.
__________________
E8400 @ 9 x 450 = 4.05Ghz 1.28v idle 37C load 64C GA-965P-DS3 rev3.3
EVGA GTX 260 216sp 730/1550/2450 stock v. Crucial Ballistix @ DDR900 4-4-4-12 2x1GB,
Scythe Ninja REV B - lapped to 600 grit - ASCeramique - Thermalright Bolt Through Kit
WD 500GB WD500AAKS XPpro Hitachi 0A38016 1TB Pagefile/backup, Seasonic S12 600W
Audigy 2 Value, ACER 22" LCD, CM 690, DViCO FusionHDTV7 Dual Express HDTV Tuner Card
MAXIMUM SUSTAINED POWER: 360 WATTS, a full 50% increase just from switching out my old 8800GT
3DMark06 = 18517 3DMark01 SE = 79733
little_scrapper is offline   Reply With Quote
Old 05-19-2007, 12:00 PM   #2
TouGe
[XC] Xtreme Cruncher
TouGe's Avatar
Send a message via MSN to TouGe
Are these the ones that you have?
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
If so, they are rated for 2.2V and you should be able to at least hit 4-3-3-8 @ 800MHz depending on your OC.
I'd lower it down to 4-3-3-8 @ 2.2V and run OCCT's memory test for 6-8 hours and see it they pass then drop it down to 3-3-3-8 @ 2.2V and run it again. If they pass then drop the volts a little and see if you can do those timmings w/ less juice.
I did this with my Patriot sticks in my sig and was able to stay stable 8+ using OCCT at 3-3-3-9 @ 2.15V running them at ~800MHz. I'm not sure if I can go lower with the volts as I don't have the time right now to continue testing.
Oops, after running stable on the memory test run the blend for another 8 hours or so and make sure those ram timmings work with your CPU overclock.
__________________
QX 9650 | Maximus II Formula | G.SKILL 4GB (2 x 2GB) PC2 8500 | Sapphire 4850 X2 2GB| Auzen X-Fi Prelude 7.1 | 3x's WD 150GB Raptors & 2x's 1TB Seagate 7200.11 | Silverstone OP1200 | SilverStone TJ07 | Dell 2707WFP
EK-RES 250 --> Swiftech MCP655 --> Apogee GTZ --> Enzotech Sapphire NB --> Feser X-Changer 360
TouGe is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
