XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 05-18-2007, 03:02 PM   #1
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
R134a Can Tap
I never thought I'd need r134a but now I need a few ounces for a chiller I'm building. I biked to all the stores in a 2 mile radius of my house and I can't find a r134a can-tap with a shraeder fitting, they all feature the automotive fittings. The one shraeder equipped tap on ebay pierces the sidewall, I'd rather have a tap that pierces the seal on the top with the threads, anyone know of a source for these taps? Purchasing a 30lb cylinder of r134a is out, I wouldn't use 30 pounds of the stuff in my lifetime.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 05-18-2007, 03:27 PM   #2
Exahertz
Exahertz's Avatar
so you need a can of r-142a to connect to a shraeder valve? you could cut the hose from the can, and then cut a hose with the shraeder fitting on it. then join the two by using a doubble hose barb.
__________________
Current System Build
Designaton:" Rad Hat "
__________________
  • Mother Board, RAM and CPU:
    Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
  • Graphics Processor:
    GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
  • Hard Drives:
    RAID: 2x 74GB Raptors on RAID 0 for OS Drives
  • Case and Power Supply:
    Case: Antec Case | PS: OCZ ProXstreame 1000W
  • Water Cooling:
    Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
  • (Water Blocks and Fittings):
    CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
    Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
Last Updated 11/11/09
Exahertz is offline   Reply With Quote
Old 05-18-2007, 03:30 PM   #3
[XC] gomeler
Suppose I could do that but I was hoping for a complete system, not something ghetto-fabbed up. If nobody gets back to me soon then I suppose I can use something like that to transfer the contents from the r134a cans into another proper cylinder.
__________________
Old 05-18-2007, 03:53 PM   #4
Exahertz
Exahertz's Avatar
yea it is ghetto, but if you cant find anything, it may work.
__________________
__________________
  • Hard Drives:
  • Water Cooling:
Old 05-18-2007, 04:13 PM   #5
wdrzal
I am Xtreme
wdrzal's Avatar
they all had a brass vavles with 1/2 acme threads that screws right on. and have a piercing valve,use what you need and shut off
I keep a can ,tap and 8" hose in every vechicle, if you develope a leak and its slow you can add enoughn gas so the low pressure limit does not keep clutch from engaging. bike ridiing is good exercise, towworow ,but put a gp transmitter on bike so we can track you.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 05-18-2007, 05:27 PM   #6
[XC] 2long4u
Xtreme Cruncher
[XC] 2long4u's Avatar
Send a message via Yahoo to [XC] 2long4u
Whats wrong with puncturing the side?
[XC] 2long4u is offline   Reply With Quote
Old 05-18-2007, 06:11 PM   #7
[XC] gomeler
Bike riding indeed is good excercise but I prefer running, ran 6.5 miles on wednesday though so I thought I'd give my legs a break from the shock of running in the city. Would be funny to put a GPS transmitter on the bike, was all over the place today. I mainly don't want the side-wall puncturing taps as I have all of my gases stored in a large wooden chest and I wouldn't want the side-wall tap from getting jostled and then leaking the remaining ~8 ounces of R134a, with something that threads onto the can then a leak is less likely. Silly but I try very hard to not vent any non-HC refrigerants. Picked up a threaded can-tap that'll tap into the top seal on the can and it has a valve so I can shut it off and store it, hopefully the thing forms a good seal. Thanks for the help guys, time to go watch Shrek 3
__________________
Old 05-20-2007, 10:42 PM   #8
ak_47_boy
One for these ^
$7 @ Hardware store.
I bent mine so it fits the arc of the can better. You have to make a strap out of sheet metal etc.. Like a giant vamp clamp It even shuts off.
ak_47_boy is offline   Reply With Quote
Old 05-21-2007, 10:35 AM   #9
[XC] gomeler
Thanks but I didn't want to pierce the sidewall, I wanted everything to be done via the top. Found a solution though, thanks
__________________
Old 05-21-2007, 12:44 PM   #10
wdrzal
I am Xtreme
wdrzal's Avatar
Originally Posted by ak_47_boy View Post
One for these ^
thats to tap a copper line to feed water to fridges cold water & ice maker,plus other item like humidifiers and the like
__________________
Register today .
Old 05-21-2007, 01:49 PM   #11
Xeon th MG Pony
Xtreme Mentor
Xeon th MG Pony's Avatar
Send a message via Yahoo to Xeon th MG Pony Send a message via Skype™ to Xeon th MG Pony
As such refrigerant will go through the rubber seals of that clamp, it is useless for refrigerants. For water it is perfect, for refrigerant no.
__________________
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Today's Fortune Cookie:
- Imbesi's Law with Freeman's Extension: In order for something to become clean, something else must become dirty; but you can get everything dirty without getting anything clean.
- Life can be so tragic -- you're here today and here tomorrow.
- The chief danger in life is that you may take too many precautions.-- Alfred Adler
- Those who are too smart to engage in politics are punished by being governed by those who are dumb. - Plato
- Gunter's Airborne Discoveries: (1) When you are served a meal aboard an aircraft, the aircraft will encounter turbulence. (2) The strength of the turbulence is directly proportional to the temperature of your coffee.
- A wise man can see more from the bottom of a well than a fool can from a mountain top.
Xeon th MG Pony is offline   Reply With Quote
Old 05-23-2007, 11:52 PM   #12
gkiing
gkiing's Avatar
Huh? Refrigerant doesn't go through the rubber seals on my gauges :p
__________________
AMD 1700+ @ 2850Mhz 1.95v (24/7 Setting) || ABIT NF7-S v2.0 ||2x256MB KHX3200 || 120GB Seagate 7200.7 SATA/80GB 7200.7 IDE|| 9800Pro || R22/R170 (Ethane) Cascade -80C Loaded
I reject your reality and substitute my own
gkiing is offline   Reply With Quote
Old 05-24-2007, 12:45 AM   #13
Xeon th MG Pony
Xtreme Mentor
Thats becuase the rubber on your guages of a perticuler type, just as the rubber for water service is of a perticuler type and so on, not all rubber is simply rubber.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
