XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Liquid Cooling > Liquid Cooling Worklogs
Reply
Old 05-15-2007, 04:47 AM   #1
RockfordFosgate
RockfordFosgate's Avatar
Tj07 Review&Cooling Project
Today i wake up with door ring. I see UPS Cargoman at the door.But i cant understand something cos still ive sleep
I guess this case pack bigger then a Stacker pack.Here is our case packet.
Left View
Now time to open case. Case packing style is cool and strong.
Case is black and have open windows side cover. This cover look very cool and original.
At the back of case, here 2 x 92 mm fan. Top of the case 2 x 120mm egzost fan.
Case maded from best quality elements.The aluminum have best quality.And case fans working good, very silent.
I guartee this to your.This case'e another good speciality, have screwed in design.Cos some of case
have rivet in design (mean screwless design), then hard to demount.They say to us, take and mod it
In the case pack, user manual, montage screws (maded aluminum).A plate for montage vertical PSU.
At back side case have really good quality we can see.these side dont need in daily use,but still have quality.
In bottom of case have 6 hdd mount. If you wanna you can demount it easyly. And Silverstone put it here 2 x 120 m silent fan.
Here is demounted hdd rack.
mobo table have sledge style.if you wanna montage mobo, can take of so easy.
Note: In this pictive they are my own fans. (Enermax 92mm blue led)
Now demount some parts of case. Like HDD mount, for my watercooling system.
WCS:
-Swiftech Apogee GT Extreme
-Swiftech MCW30 Chipset block
-Alphacool Nexxos 360-LE Radiator
-Laing D5 1500lt
-Dangerden Maze4
-1/2'' Primoflex Tube
-1/2''barbs
-XSPC Passive 250mm Reservoir
-3x120mm Enermax Fan
-Aqua UV Green dye
In this pictuve i cut mobo plate for hiding cables (wire design).
Here is my Dremel set
I mount watercooling blocks without radiator and water pomp. This is my
wireless case design haha
I drill some hollow for putting my water reservoir. Then mountad 360mm radiator.
Then i prepare some UV liquid, putin' blue neon. I hope you like this case. I dont to so much modding i will start
in 20 July to modding.
C ya later.. Now, case pic for you.
Rockford Fosgate
Sorry for my english
__________________
Intel Core i7 920 D0 | Gigabyte EX58-UD4P | 3x1Gb OCZ 1600mhz | Gigabyte 8800GT Turboforce 820/2010 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi|N97
Watercooling & Case mod soon...
Hardwarena Overclock Team
RockfordFosgate is offline   Reply With Quote
Old 05-15-2007, 05:46 AM   #2
G80
G80's Avatar
Nice showing us and nice setup. Im thinking of buying this case myself as it is quite friendly when it comes to watercooling.
__________________
Intel is like Egypt in Rome:total war
G80 is offline   Reply With Quote
Old 05-15-2007, 05:55 AM   #3
septim
Banned
Send a message via Yahoo to septim
hmm that was a fast setup...
very nice outcome. maybe some temps too...
septim is offline   Reply With Quote
Old 05-15-2007, 07:31 AM   #4
Polizei
Xtreme Cruncher
Polizei's Avatar
Send a message via AIM to Polizei
Copper blocks, aluminum radiator?
I want one of those cases.
__________________
Polizei is offline   Reply With Quote
Old 05-15-2007, 07:37 AM   #5
BlueAqua
I am Xtreme
BlueAqua's Avatar
Nice setup, very clean.
BlueAqua is online now   Reply With Quote
Old 05-15-2007, 07:40 AM   #6
newls1
Xtreme Cruncher
newls1's Avatar
Send a message via AIM to newls1
Very well done, and no need to apologize about your english, it is just fine..... Have fun with it.
__________________
No more PC, damn economy
02 Tahoe with a *NICE* stereo! Soon to be:
2 300a alts, 4 AQ2200D amps, AQ90x4 amp, 4 18" AQ HDC3A's (2200RMS Watts each) multi batts in rear all G31's, MLA 15.4v module, etc.... Nearing 10,000watts
newls1 is offline   Reply With Quote
Old 05-15-2007, 07:46 AM   #7
RockfordFosgate
Thanks guys
No:
Copper blocks&radiator but aluminium reservoir
__________________
Old 05-15-2007, 07:57 AM   #8
Grinch
Xtreme Cruncher
Grinch's Avatar
very nice looking! and FAST build...*-)
__________________
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
Grinch is offline   Reply With Quote
Old 05-15-2007, 08:03 AM   #9
Webster
Webster's Avatar
Copper + Anodized Aluminum = horrible galvanic corrosion
Webster is offline   Reply With Quote
Old 05-15-2007, 08:08 AM   #10
RockfordFosgate
I'm using this
http://www.firebal.net/asp/show_stock.asp?product=WA046
Anticorrosion No problem.
__________________
Old 05-15-2007, 11:52 AM   #11
pie_uk
can i ask wat south bridge cooler you are using? i would like to get one for my asus
__________________
Main PC || Sugo-Evolution || Intel C2D 4300 @2.8ghz || Gigabyte DS2R || Sapphire X1950XTX || 2GB Cellshock DDR2 || 500W Silverstone sc || 20" 2007WFP || Creative X-fi || 250Gb Seagate .10 || Optiarc || Sharkoon air cooling
Sound || Sennheiser HD 595 || Marantz PM4001 || eltax monitor3 ||
pie_uk is offline   Reply With Quote
Old 05-15-2007, 11:55 AM   #12
RockfordFosgate
This is a Noctua NC-U6 Chipset cooler
http://www.evrenshop.com/asp/show_st...p?product=nc06
This is my P5B deluxe:
Edit:Picture
__________________
Old 05-15-2007, 07:26 PM   #13
Webster
Webster's Avatar
Originally Posted by RockfordFosgate View Post
I'm using this
OK! Good! You scared me for a second! I thought about getting that reservoir, but i decided on the EK 250 instead
Old 05-16-2007, 03:26 AM   #14
RockfordFosgate
EK 250 is a very very quality reservoir
__________________
Old 05-16-2007, 03:38 AM   #15
perfection
perfection's Avatar
How did you mount those HDDs??
__________________
My Rig
CPU: Intel Core 2 Duo E6600 L626A175 3GHZ 1.30V real
RAM: Crucial Ballistix PC2-8500 stock speed and timings
Motherboard: Asus P5E X38 333MHZ FSB x9 multi
Video: Gigabyte 8800GTS 320mb stock speeds
Soundcard Creative Soundblaster Audigy 2 ZS
Hard Drives Seagate 250GB 7200.10 SATAII (boot) > Samsung HD501J 500GB SATAII (Storage)
Case: Lian Li PC-S80
Powersupply: Corsair HX620W 620watt
Optical: Samsung SH-S182D DVDRW 18x
Monitor: Asus MW221U 22" LCD
Mouse: Logitech CF G7
Keyboard: Logitech G15
Speakers: Logitech Z5500
The water cooling
CPU waterblock: Swiftech Apogee (original with custom top and mounting plate)
GPU waterblock: EK FC8800GTS Acrylic
Pump: Laing D5 Vario "3" speed setting
Radiator: Swiftech MCR220 w/ 120mm Yate Loons D12SM-12 running at 7V
Resevoir - Swiftech MCRES Micro - Pentison G11
perfection is offline   Reply With Quote
Old 05-16-2007, 08:15 AM   #16
masaville
masaville's Avatar
Very nice Rockford. Looks great! TJ07 is a great w/c case isn't it? Lots of room to tinker.
__________________
E6700 | eVGA 680i MB | 4GB OCZ Spec Ops DDR2-800 | Raptor 74GB + 150GB | eVGA 8800 GTX SLI | TJ07 | OCZ 1000w | HP LP3065 30" LCD
D-tek Fuzion | DD 8800 GTX GPU blocks | BIX GTX 480 & 240 Rad | 2 x Swiftech MCP655 Pump | 2 x EK-Res-200...all in one pimped out TJ07 case!
Project thread - http://www.xtremesystems.org/forums/...d.php?t=136408
masaville is offline   Reply With Quote
Old 05-17-2007, 03:27 AM   #17
RockfordFosgate
Thanks masaville.Yes Tj07 is the best case for wc
Small update:
Scythe Kama Meter
Scythe kama Bay
__________________
Old 05-30-2007, 10:34 PM   #18
shaolin95
shaolin95's Avatar
I am interested in that as well as I want to build me a WC rig with that case but I have 4 HDDs and will probably add one more....also my DVD burner and X-Fi breakout box...
I want to make sure I will be able to fit everything.
Regards...
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 05-31-2007, 12:28 AM   #19
whoodiestyle
Regards...
u can always buy a rack for the 5.25 bays or i think u can but i know they sell the 5.25 that convert into 3.25
__________________
whoodiestyle is offline   Reply With Quote
Old 05-31-2007, 08:29 AM   #20
septim
Banned
most likely with a converter 5.25 - 3.5 behind the kama bay
or try one of LianLi Ex-34 expansion kit if you can find one.
Old 05-31-2007, 09:37 AM   #21
RockfordFosgate
Yes yes yes
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
