05-07-2007, 05:02 PM
#1
Good platform/cpu help for xp32-64 and vista32-64 bit
Mainboard
http://www.mlacom.si/tree.aspx?nodeid=2039 940
http://www.mlacom.si/tree.aspx?nodeid=2200 1207
2x Opteron Cpu's
http://www.mlacom.si/tree.aspx?nodeid=2213
What do you think:
I whant to Get somthing Good /ass kikin for my bro.
Abaut 800$ for mainboard
Abaut 700$ for each cpu
And 400$ for memory
I whant to know its worth to wait abit for new cpu's??
Any ideas, links, suggestions i need that now since this is my first post
__________________
I underclock!
Need total stability, and your
_____________________________
Asus P5K3 Deluxe + wi-fi
iQ9550 with OCZ XTC Platinum OCZ3P1600EB2G ddr3 6-6-6-18
Win Vista32 + winXp32 and 64 bit
And dont forget to check my homepage @ my profile
Sys#2 Asus X51L laptop, not oced.
Sys#3 Atari 1040STf 2.5meg ram. Tos1.0 Tos206. 20meg hdd and foture... UltraSatan !
Reason: Amd or Intel
05-07-2007, 05:06 PM
#2
I'm feeling BLUE!
Originally Posted by Ego
Are you locked into using Opterons? I mean do you already own them?
__________________
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Frisch
If you have lost faith in humanity, then hold a newborn in your hands.
05-07-2007, 05:08 PM
#3
Not using it yet. But soon,
need best thing for this $
__________________
I underclock!
05-07-2007, 05:12 PM
#4
I think 4 gig ram will be enugh for home use.
Well i need mainboard + cpu + Pcie singlecard graphics and fast memory.
No ocing ofc = stability
__________________
I underclock!
05-07-2007, 05:18 PM
#5
I'm feeling BLUE!
For that kind of money I can build a dual clovertown or high end woodcrest that would destroy a dual opty..( here come the flames)
US prices:
Board: SM X7DAE:$450.00
Memory: 4x1 gig DDR2-667 FBDimms:$362.00
cpu's: Vary but for $1400.00 total you can get 2 that will meet your needs.
A couple of the lower end clovertowns BSEL modded from 1066 to 1333FSB and in the 2500mhz range..on 8 cores!
__________________
05-07-2007, 06:41 PM
#6
This- 8 cores..
http://www.mlacom.si/article.aspx?docid=23483
Mainboard price is abaut 1000$
__________________
I underclock!
05-07-2007, 06:53 PM
#7
I'm feeling BLUE!
__________________
05-08-2007, 03:55 AM
#8
Sounds interesting
But who got better ones intel-xeon or amd-opteron ?
I need performance compare charts...
__________________
I underclock!
05-08-2007, 04:04 AM
#9
I'm feeling BLUE!
Sounds interesting
As far as I'm concerned the only thing the opty does better in is bandwidth.
Everywhere else the clover beats it.
remember, a dual opty is 4 cores, a dual clover is 8.
It should outdo the opty.
That 4 socket Tyan board you linked to:
One of the guys has one of them with 8 Opty 880's on it using the plug in daughter card that accepts 4 more cpu's so 16 cores on his machine
He ran cinebench on it and got 2764 I beleive.
I got in the 2600's with 8 cores and Kaz-n has water cooled a dual clover to 3789 and beaten that 2764 mark..
That a good enough answer?
__________________
05-08-2007, 04:06 AM
#10
Xtreme Mentor
clovertowns = much faster
__________________
Platform: DFI CFX3200-DR; AMD Opteron 185 w/ TTBT
Memory: 2GB Mushkin Redline XP4000 @ 260MHz 3-3-2-8
Video: Jetway HD 4850 512MB @ 750/1125 w/ SI-128; Samsung 206BW
Audio: Creative X-Fi Fatal1ty; Logitech Z-5500; Sennheiser HD515
Storage: 4x Seagate ES.2 250GB on Adaptec 1430SA; 1x Seagate 7200.11 500GB
Power: Seasonic M12 700W
05-08-2007, 04:15 AM
#11
I'm feeling BLUE!
Sounds interesting
Here's some numbers for you to look at.
Your average everyday clovertown:
__________________
05-08-2007, 05:34 AM
#12
Good!!
Thats a minimum price single cpu
http://www.mlacom.si/article.aspx?docid=29137
1 cpu w 4 cores with 8 meg and cost abaut 700 $ per cpu lol maybe i need to find cheaper shop for less money for cpu you know
__________________
I underclock!
05-08-2007, 12:41 PM
#13
I told my bro and he is rdy to have that machine
Is it posible to run win Xp pro with 2 cpu's w 8 cores ?
__________________
I underclock!
05-08-2007, 01:23 PM
#14
you'll want the 64-bit version of pro, or vista-ultimate, else you'll only see 3 gigs of ram...
__________________
Athlon XP-M 2500+ Barton 0343MPMW | 2938, 226x13, 2.000v vcore
Abit NF7-S 2.0 | Antec TruePower 480w | X800GTO 16pp 256mb, 398/493
2 x 256mb Corsair PC3500 | 2.0-2-2-11 1T 1:1 | 2.90v vdimm | 1.70v vdd
Intel vs. AMD can be described as this:
Long and thin gets it in, but, short and thick does the trick.
05-08-2007, 02:41 PM
#15
Xtreme Mentor
Core2 generally performs 20-25% better at the same clockspeed than AMD64 K8, and that applies to Clovertowns and Opterons , too.
The devil is in the details. The registered DDR2 is cheaper than the FBDIMMS so as you add memory the price/performances closes. Overclocking on socket 771 is really horrible, much worse than on Socket F or Socket 940.
The main advantage of Socket F Opterons over 940 is hardware support for virtualization.
The main advantage of Intel CPUs is that you can get Intel chipsets, whereas when you pick AMD CPUs you have to live with NVidia chipsets in this segment.
05-08-2007, 03:06 PM
#16
So can i say if you want to run the VMware stuff go for opterons ?
05-09-2007, 01:22 AM
#17
With 1 cpu 4 cores posible to run winxp pro 32bit?
I need to run winxpPro32 and 64 and vista 32 and 64 as with 2 cpus=8 cores will be great
What i need is good cpu for all this....
Tell me what to do
__________________
I underclock!
05-09-2007, 12:12 PM
#18
Xtreme Mentor
I said "socket f" over socket 940.
05-12-2007, 07:30 AM
#19
I found all anwsers by my self thanks alot for help,lol.
__________________
I underclock!
05-13-2007, 05:19 AM
#20
Well tell us what did you buy? I personally don't base a system purchase on benchmarks like SuperPI and Sisoft Sandra. That's pretty misleading.
__________________
Athlon 64 X2 4200+ @ 2800Mhz
Zalman CNPS9500
Asus M2N-E
2GB PQI DDRII @ 800Mhz CL5
Asus GeForce 7900GT @ 550/1520
18x DVD Burner
Maxtor 120GB IDE
WD 160GB SATA
Iiyama Vision Master Pro 410
Saving for Phenom X4
06-26-2007, 10:42 AM
#21
Well my bro deside to have INTEL 6600 conroe.
Works great on 1.2 volts and ¨2400Mhz as default freq¨
In this case i tell him by ME see things in this forum i6600 is best performer for $
__________________
I underclock!
06-29-2007, 12:32 PM
#22
XS News
Kinda useless thread then if he wanted best performance/price.
Did he spend them on horses instead ?
__________________
Everything extra is bad!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
