Need a silent, low profile PC for storing music ONLY.
Hi guys, my experience is only with overclocking and high end PCs. Well, I need to build a SILENT pc, with the lowest profile (smallest) case possible.
The only requirements:
-silent
-able to hold at least ONE pci card. Not PCI express, just PCI.
-Preferably, space for at least 2 hard drives and one optical drive.
This does NOT need to be fast, tweaked, overclocked or anything. It needs to be reliable.
It's only use is going to be storing my lossless audio collection. It will be controlled by TightVNC. NO need for mouse, keyboard, monitor or anything.
It will output a digital-coaxial bit-perfect audio signal. I already have the PCI sound card for this. That is what the PCI slot is for.
I really only need suggestions for motherboard, case, and PSU. Remember, this NEEDS to be silent.
__________________
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550 —Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
look up Mini-ITX form factor PCs. They can almost always have one optical drive, one PCI slot, and one hard drive, sometimes two HDs. They are generally kinda slow though, although I think they are coming out with Core 2 ITX motherboards now.
__________________
Originally Posted by Shintai
Imagine Microsoft said that Windows 7 would only work on Acer/HP/Dell/Lenovo machines.
Its just Apple thats full of BS
Tyan S2932G2NR-SI
AMD Opteron quads @ 2.6GHz (Shanghai) x2
16GB of Kingston DDR-800 ECC RAM
ATI 4890 1GB
ASUS M3A79-T Deluxe
Phenom II 940 @ 3.75GHz w/ 1.4v
NB and HTT @ 2.75GHz w/ 1.4v & 1.3v
G.Skill PI @ DDR1150 w/ 2.1v
ATI 4890 @ 1022MHz core
Mini ITX?? Whats that? Just checked newegg, sweet! The boards are TINY and there are fanless ones that include everything! What kind of funky CPU are they using though?
The hardware I would be using with it would be an optical drive (full size or half height, whatever the case supports, does not have to be a burner, just read CDs and preferably DVDs as well), an internal 3.5" SATA hard drive, 512mb of RAM and finally an ESI Juli@ PCI sound card. A PSU as well but they seem to come with all the ITX cases.
My requirements for the case are only that it fit the hardware mentioned above, and if at all possible, no fans. If it MUST have fans, they need to be whisper silent. So what are my case options? I would also like it to be as small as possible and still meet my requirements.
__________________
Should have everything you would want. Keep in mind mini-ITX does tend to more expensive than matx or cheaper Shuttle size computers, for example you could go for something like this: http://www.newegg.com/Product/Produc...82E16856101480
which has alot more features but isn't as small or completely fanless as mini-ITX.
