XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 05-07-2007, 04:10 AM   #1
Hicks
3dMark Isn't Everything
Hicks's Avatar
New Case needed for new build, Cooling top priority
The rig in my sig, seems to be to much for my Lian Li PC-65 to handle. Now i do like the case, the build quality is awesome, and it looks great, but i can't keep it, as the temps rise 10C with the side panel on.
Looking for a new case now. Cooling is a major major factor. id also like it to look nice, and i don't wanna spend to much, say £100 max.
Looking at the Antec 900 as it seems to have excellent cooling, but whats the build like? and is it only in black? Also what size, id rather still have a midi tower, but my cooler is very close to the edge of the case at the mo and it's 220mm wide.
__________________
Kentsfield Q6600@ 3100Mhz
Asus P5B-E Plus
2GB GSkill DDRII PC6400GBHZ
Albatron Geforce 8800GTX
Silverstone Temjin TJ-09
Thermalright Ultra 120
Corsair 620W HX
74GB Raptor/ X-Fi Platinum
19" CRT NEC 930 SB
Windows XP Pro SP2
Hicks is offline   Reply With Quote
Old 05-07-2007, 04:30 AM   #2
[XC] Adywebb
DC Prostitute
[XC] Adywebb's Avatar
I use Antec P180's for most of my Kents - plenty big for your cooler (I use Tuniq Tower 120's) and has 4 x speed adjustable 120mm fans.
I also have an Antec Solo fitted with a Kent, it only has 1 x 120mm fan fitted at the rear, but you can fit 2 x 92mm fans at the front for good airflow - the case is smaller than the P180 but still big enough for your cooler.
Build quality on both are excellent.
__________________
DC Prostitute - Crunching In Memory of My Dad
[XC] Adywebb is offline   Reply With Quote
Old 05-07-2007, 04:35 AM   #3
Hicks
Hicks's Avatar
Thanks for the reply. Forget the 900 is looks crap.
What about Lian Li's cases? I wouldn't mind spending a bit more, for a quality build case, with good cooling. I also don't want it to noisy.
__________________
Asus P5B-E Plus
Corsair 620W HX
19" CRT NEC 930 SB
Windows XP Pro SP2
Old 05-07-2007, 07:57 AM   #4
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
yeah lianLi's are great looking cases and i have always liked the internal design of them.. maybe a v2000 if it's not too heavy on your wallet.. also coolermaster stacker STC-T01 or RC-810.. personally can't stand the looks of the newer 830/1 evo case.
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is offline   Reply With Quote
Old 05-08-2007, 09:03 AM   #5
Hicks
Hicks's Avatar
Leaning towards the Antec P182. Has anyone got a Corsair 620W HX in it? worries me that the cables won't be long enough. And will my HSF fit ok?
__________________
Asus P5B-E Plus
Corsair 620W HX
19" CRT NEC 930 SB
Windows XP Pro SP2
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
