XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 05-03-2007, 11:12 PM   #1
luihed
Overkill
luihed's Avatar
Corrupted bios...HELP!!!
I have a Commando with bios 0803 that Ive been using for a couple of weeks now without any problems..... Yesterday after benching I couldnt get my system to boot so I took out the battery, unplugged everything and left it till today..... That seemed to fix my problem and my computer booted today but I cant get in to XP or vista, since my important files are in vista, I tried to reload XP..... Couple mins in the install I get a blue screen saying my bios is not ACPI compatible...... I tried to repair Vista and same thing, blue screen saying my bios is not ACPI.....
So I decided to reflash to my current bios ( 0803 ) and now afudos says it cant recognize my bios version..... Tried different afudos version and same thing, I tried the latest version from AMI and now its saying " Bios does not support AFU".....
So I figure Ill try EZ Flash from bios option.... I cant even get in to EZ flash, its telling me " Bios has no version information".....
So it seems my bios is screwed but I cant reflash...... All the info during POST looks ok and in bios everything looks normal cept for ezflash..... What can I do now? I dont really want to go through RMA cos my board might not pass lol......
__________________
E8400 DFI LP P35T2R Ballistix
8800GTS PCP&C 1.2kw Raptors
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
luihed is offline   Reply With Quote
Old 05-04-2007, 12:12 AM   #2
Daveb2012
Daveb2012's Avatar
Send a message via AIM to Daveb2012
__________________
Current Setup:
-9850 GX2's in Quad SLI config
-Asus P5N32-SLI MB
-2x512mb of PC2-5300 DDR2
-Intel Celeron D OC'd to 3.2Ghz
-Windows Me with XP theme
-WD Caviar 20GB Hard Drive
-Zip drive
-Jazz drive
-3.5" floppy drive
-5.25" floppy drive
Daveb2012 is offline   Reply With Quote
Old 05-04-2007, 12:17 AM   #3
crazyea
crazyea's Avatar
too much time.......
__________________
| eVga x58 3x Sli | i7 920 w/ Ultra 120 Extreme | Radeon HD 5850 |
| 6x1GB Aenon DDR3-1600 | WD6401AALS | Antec Sonata III w/ 500w |
crazyea is offline   Reply With Quote
Old 05-04-2007, 01:33 AM   #4
luihed
Overkill
luihed's Avatar
I hope I dont have too cos like crazy said it takes too much time......
@crazyea, tough luck on our canucks eh? What a goal to end the season, very Clouthier like lol....... also You the guy that sold my buddy some Fatboys?
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 05-04-2007, 04:45 AM   #5
Frostbyte
Frostbyte's Avatar
Yep, even with the pain in the arse RMA'ing is, it might be the best bet in this instance because of the likelihood of bad hardware causing the issue in the first place.
Frostbyte is offline   Reply With Quote
Old 05-04-2007, 05:23 AM   #6
jamiet757
yep
__________________
Asus P5N32-E SLI
Intel Core 2 E6700 @3.62Ghz
2 x 36gb Western Digital Raptor 10000rpm in Raid 0
2 x Hitachi 160gb 7200rpm Sata HDD in Raid 0
4gb crucial ddr2-1066
evga 8800GTS
jamiet757 is offline   Reply With Quote
Old 05-04-2007, 08:12 AM   #7
luihed
Overkill
luihed's Avatar
Just when Im about to call RMA, I decided to reseat my cpu and not bolt it down as tight as I usually do and bam she fires up again...... Whew....
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 05-04-2007, 09:01 AM   #8
Falkentyne
Falkentyne's Avatar
Huh ???
Falkentyne is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
