XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 04-28-2007, 08:18 PM   #1
windwithme
windwithme's Avatar
Full Solid CAP and big heat-pipe MB on Intel platform – MSI P35 Platinum first look
On Intel chipset product line schedule, they usually renew the whole
products series from half to one year.
The 975X chipset exist for a long time, the P965 also launched for almost a
year.
The upcoming Intel new generation processor will speed up to FSB1333MHz
and DDR3 architecture, then the P35 and X38 series chipsets will become the
new generation leader in second half 2007.
The board I got this time is P35 chipset based – MSI P35 Platinum – DDR2
The box design, this time they use different theme on cover, got another
better style
Inside packing, the cable color and wording is also enhanced from old design.
(CD driver not in photo)
The motherboard itself
Down left side
Even P35 have same design with 965P on single PCI-E x16 lane design.
But higher level boards will make them as dual VGA layout.
Audio chip use ALC888T, 7.1 channel HD audio with mant solid CAPs.
Down right side
5 SATAII and 1 IDE port.
Red bottom is for Clear CMOS function.
DRAM part
4DIMM DDRII
CPU PWM part use 4 phase design
IO shield
Except 1394, also support 2 extra eSATA ports
This time MSI have the brake through design on heatpipe design compare
with their old products. They have 4 special parts to high light.
The first part: up left on CPU socket.
The inscription with the pipe name “CIRCU-PIPE”, looks good.
Second part: Up right side on CPU socket.
Third part: North bridge pipe
It’s special design that I’ve never seen before. Comes with bigger surface to
spread the heat, seems better then other normal design.
Forth part: South bridge.
The copper and pipe is thick in heatsink.
The testing modules
On this coming P35 product, we see MSI comes with enough function and
better look hestsink with special design,
The special feature and outlook design is almost align to a higher standard
with the three big MB manufactors.
This time MSI coming very fast with well prepared, hope MSI can have more
brake through on overclock limited, then their P35 series will have good
reputation on P35 market soon.
windwithme is offline   Reply With Quote
Old 04-28-2007, 08:27 PM   #2
CedricFP
CedricFP's Avatar
Wow, those circular heatpipes look pretty nifty, but could interfere with some of the larger heatsinks around, perhaps even water.
Looking forward to your results
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 04-28-2007, 08:43 PM   #3
Daveb2012
Daveb2012's Avatar
Send a message via AIM to Daveb2012
Wow I love the heat pipe cooling on this! Will probably trade my Quad GT in for one of these as long the price is reasonable. Can I ask whats up with that little plastic jewel cat camera whore appearing in all the shots? Is that like some ones signature?
__________________
Current Setup:
-9850 GX2's in Quad SLI config
-Asus P5N32-SLI MB
-2x512mb of PC2-5300 DDR2
-Intel Celeron D OC'd to 3.2Ghz
-Windows Me with XP theme
-WD Caviar 20GB Hard Drive
-Zip drive
-Jazz drive
-3.5" floppy drive
-5.25" floppy drive
Daveb2012 is offline   Reply With Quote
Old 04-28-2007, 08:48 PM   #4
theteamaqua
theteamaqua's Avatar
r u gonna test it ?? like install windows and run benchies on it??
__________________
E6600 @ 3.6
IN9 32x MAX
EVGA 8800Ultra
750W
theteamaqua is offline   Reply With Quote
Old 04-28-2007, 08:51 PM   #5
nn_step
YouTube Addict
nn_step's Avatar
first and foremost what the heck did MSI do with the Power connector placement? Also I hope they clean up that mess of heatsinks
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is offline   Reply With Quote
Old 04-28-2007, 09:08 PM   #6
Hazzan
Brotherhood
Hazzan's Avatar
Send a message via MSN to Hazzan
run it !! I want to see performance from chipset P35 .......................
Hazzan is offline   Reply With Quote
Old 04-28-2007, 09:10 PM   #7
nugzo
Ultra Durable
nugzo's Avatar
Send a message via MSN to nugzo
OMG its a rollercoaster
__________________
Under Construction. EX58a-UD7 in route. Currently Running:
EVGA X58 Classified 759 (3-way x16 SLI +physX)
Intel Core i7-950 Bloomfield @ 4.2Ghz (24x175)
G.SKILL Perfect Storm 12GB (6 x 2GB) 1745 8-8-8-21
Cooler Master Storm Sniper
Thermaltake 1000w PSU
2-128GB gskill Titan SSD RAID 0
2-1TB Seagete 32mb RAID 0
1-1TB Western Digital
1- Plextor PX-B320SA Blue Ray
1- Plextor PX-880SA 24x DVD/RW
2- EVGA Nvidia GTX-295 Quad SLI
TRUE w/2-SCYTHE S-FLEX™ "SFF21G" 120mm Fans
Acer 27" B273HU LCD / ASUS 24" LCDe
nugzo is offline   Reply With Quote
Old 04-28-2007, 09:32 PM   #8
Peter949
Nice mobo....kinda like the loop heat pipe design.
Peter949 is offline   Reply With Quote
Old 04-28-2007, 10:09 PM   #9
Chewbenator
Chewbenator's Avatar
Its a rollercoaster for electrons!
Chewbenator is offline   Reply With Quote
Old 04-28-2007, 10:36 PM   #10
SaFrOuT
Egyptian OverClocker
SaFrOuT's Avatar
Send a message via ICQ to SaFrOuT Send a message via MSN to SaFrOuT
the upcoming mobos from GB, ASUS and MSI have very large NB heatsink that it will be a problem when the owner wants to install one of the high end huge aircooling solutions
__________________
DFI Ultra-D, Opteron 165, G.Zkill ZX 2GB, Gigabyte 8800GT
Married since 26/12/08 and still enjoying my honeymoon
SaFrOuT is offline   Reply With Quote
Old 04-28-2007, 11:16 PM   #11
mezcal
mezcal's Avatar
@nnstep what's wrong with the power connectors? Looks pretty standard to me-am I missing something?
+1 for leaving out the parallel and com ports.
Those heatpipes--they may work, I don't know. I do know I will never buy anything like that
And are you SURE those are cats?? I'm thinking that one is an owl
__________________
Intel D975XBX2 v5.04, 2745 | E4300, 9x300 @ 1.325 V| 2x1GB Corsair XMS5402v5.2, 1:1 on 800 strap @ 4-4-4-12, 1.84V
2xGigabyte X1950PRO 256MB with Zalmans @ 594/700 | P180B / Neo HE 550 with airflow and wire management mods
2xWD1600YS (Raid 1, Raid 0) and 1xWD1600JS on ICH7R | WD4000KD in Icy Dock MB559 eSATA enclosure on Marvell
Buffalo TeraStation HD-H0.6TGL (Raid 5) | WD MyBook Premium 500GB (EXT3-used only for TeraStation mirror)
mezcal is offline   Reply With Quote
Old 04-28-2007, 11:22 PM   #12
nn_step
YouTube Addict
nn_step's Avatar
The 8pin looks like a pain to plug in, I wish they had more of a DFI style layout which makes routing easier
__________________
-Linus Torvalds
Old 04-28-2007, 11:31 PM   #13
PotGoblin
PotGoblin's Avatar
I am liking that shiny red button for clear cmos - no more jumper
__________________
What part of "Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn" don't you understand
Current Rig:
CPU: P4 2.6Ghz w/ HT @ stock
RAM: 1gig mushkin ddr-3200
MBD: Gigabyte 865p
Video: GeForce 128mb 6600GT
PSU: Enermax 420w
Sound: SB Audigy 2
HDD: 60gb ide and 160gb sata
PotGoblin is offline   Reply With Quote
Old 04-28-2007, 11:41 PM   #14
thecoldanddark
I'll be honest, I don't like it. It looks like a decent motherboard if you are air cooling, but other than that it just looks like a nightmare. The 8pin is in a terrible spot and how are the heatpipes supposed to cool themselves off if you don't have air cooling on your processor? Add fans, to where (stupid bling covers)? The northbridge is funky (probably works pretty well, but to get a small fan on it... I have the
p965 MSI plat limited edition and I like the way the heatpipes are set up on it (besides the one on the southbridge ) It could be a great board, but it looks more bling then useful (like most of the copper bling filled boards).
Yes nn, I agree that 8 pin spot is scary.
thecoldanddark is offline   Reply With Quote
Old 04-28-2007, 11:45 PM   #15
BobHarris
Isn't it very difficult to mount the HSF with all those heatpipes in place?
Will those oversized sticks of RAM get in the way of an Infinity HSF?
BobHarris is offline   Reply With Quote
Old 04-28-2007, 11:58 PM   #16
Nanometer
Xtreme Mentor
Nanometer's Avatar
Send a message via AIM to Nanometer
Those heatpipes look ridiculous.
__________________
PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.35 volts | Cooled by Swiftech GTZ - CPX-Pro - MCR320+MCR220 | Completely Silent loads at 66c
GTX 260 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
OCZ Vertex RAID-0(60Gig x 2) | WD 1000Gig Storage
Enermax Liberty 620| With a low speed yate, the stock ball bearing fan crapped out after 1 year of service.
Nanometer is offline   Reply With Quote
Old 04-29-2007, 04:25 AM   #17
Varsos
Varsos's Avatar
And i thought Striker's heatpipes were ugly............Jesus.
__________________
i7 920 3922A436 W/C HEATKILLER
DFI LP UT X58-T3EH8 W/C Swiftech MCW30
Corsair 6GB DDR3-1600 Ram Kit (3 x 2GB, PC2 12800, 7-7-7-20, TR3X6G1600C7)
Sapphire HD4870 X2 W/C (EK)
PC P&C 750 Quad Cf
4 x Raptor 36Gb Raid0
2 x Seagate 500Gb Raid0
2TB Western MYBOOK STUDIO EDITION II Raid0
Audigy 4
DELL 2407WFP
WIN 7 Ultimate x64
CoolerMaster CM Stacker
ThermoChill PA120.3, Swiftech MCP 355 with XSPC v3 top
Varsos is offline   Reply With Quote
Old 04-29-2007, 05:59 AM   #18
rozzyroz
hmmm, cable management would suck on that. it would be nice to see the power connectors near the edge and at a 90 degree angled off away from the board. the 4 pin molex connector placement looks just as bad.
rozzyroz is offline   Reply With Quote
Old 04-29-2007, 06:38 AM   #19
PPInDaHouse
PPInDaHouse's Avatar
Send a message via MSN to PPInDaHouse
nice circular heat-pipe
__________________
PPInDaHouse is offline   Reply With Quote
Old 04-29-2007, 06:50 AM   #20
berk
berk's Avatar
Heat pipes are the devils work i tell you !!!
They always have been when it comes to mobo implementation.
And this is the worst ive seen so far...
Anyhoo's numbers please....
__________________
I'm just not interested in AMD.
Bugs in sigs suck.
Cheapen SSD drives (we're almost there!!) and bring back mobo fans!!!!
...remember kids,the Ipad is an incredible experience...
berk is offline   Reply With Quote
Old 04-29-2007, 07:16 AM   #21
dinos22
...you two characters
dinos22's Avatar
terrible power connector placement and those heatpipes.........are they really necessary
we want FSB testing and also does it run 1066 strap all the way or not
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 04-29-2007, 07:22 AM   #22
stealthbomber
Is there even a single board with a heatpipe design that performs even adequately compared to stand alone copper heatsinks?
Waste of time if you ask me, they could have spent the money on beefing up other parts of the board, I'd keep the two upper parts of the pipe design near the CPU socket where the copper sinks cools the MOSFET's/ic though.
stealthbomber is offline   Reply With Quote
Old 04-29-2007, 09:04 AM   #23
Phosphate
I'm really interested in this set-up. Looks much better than the old methods. I wonder how well it will perform in the real world.
__________________
Gigabyte DS3 F10 bios
E4500 2.75 GHz @stock volts
Thermalright Ultra 90 CPU cooler
4 GB (2 x 2) Patriot PC4200 memory kit
Powercolor X800 GTO (waiting for DX10 card)
Antec P160 case with 2 120mm fans
Antec NeoHe 550 watt PSU
NEC 3550A
Seagate 80 GB SATA HD.
Samsung 226BW monitor
Phosphate is offline   Reply With Quote
Old 04-29-2007, 09:13 AM   #24
K404
Xtreme Mentor
K404's Avatar
If its for 1333 CPUs, I gotta say..I doubt it. Maybe a strap selection if we're lucky?
Am I right in saying theres more than 1 version of this board? Theres also one with a mix of DDR2/DDR3 slots.
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
K404 is online now   Reply With Quote
Old 04-29-2007, 04:20 PM   #25
Soker
Soker's Avatar
Beautiful heatpipe cooling, nice fsb but what is this!?
Soker is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
