04-25-2007, 06:20 PM
#1
Stock Vapochill LS - noob questions
Tonight I test started the system with a stock Vapochill LS unit cooling the CPU (QX6700). CPU at stock speed.
I'm not using the LS case, I had everything moved inside a Lian Li V2000B Plus II case.
Everything went good, system posted right away, BIOS reported CPU temp -44 Celsius, evaporator temp -48 Celsius.
Here are my questions:
1. The compressor unit gets very hot. So hot that I couldn't keep my hand on it. That's after 1hr.
Is that normal? Is it dangerous for 24/7 work? Or is the compressor built in such manner to handle that heat?
2. Just as I wanted to turn off the system, I noticed the fans RPM (in all system) started to fluctuate (i could hear them speed up then decrease speed, very fast).
I watched the LS display and noticed the temp started to rise. Went from -48 Celsius up to -37 Celsius (took about 3 minutes). At that moment, the fans RPM normalized and the LS display showed that the temp was again decreasing. I watched it as it went down to -48 and stabilised there.
Was that a power line issue? Vapo issue? Or is it normal?
If that was a powerline issue, it will be fixed once I get the system home and power it through the UPS.
04-25-2007, 06:57 PM
#2
I don't know what the problem is, but I'd stay away from overclocking the quad and using a stock phase unit.
The stock units are known to die from the load of quad cores.
__________________
04-25-2007, 07:13 PM
#3
Xtreme Cruncher
^agreed. these units were designed wayyy before quad cores were around and it's probably overheating from the high heatload
__________________
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
04-25-2007, 07:24 PM
#4
First, thanks for answering.
Yes, I am aware that some unfortunate users got their Mach GTs' and LSs' fried by the quad core, but that happened to me at stock speed on a brand new unit. FSB was set at 266, multiplier at 10. Could it overheat at stock speed? Is the compressor built to work at about 60 Celsius? Or is that too hot?
I exchanged some emails with a guy that's been keeping his quad at 4GHz on a stock LS for some months now and said that his unit is ok. No fried chips sound, no sign of weakness.
04-26-2007, 01:36 PM
#5
Yes. thats what the people above have been trying to say.
04-26-2007, 04:36 PM
#6
Who/where can mod this LS unit in eastern europe?
04-26-2007, 04:38 PM
#7
I think GrayMole is available for modding units.
__________________
04-26-2007, 04:59 PM
#8
LittleDevil is from Slovenia also
04-26-2007, 05:12 PM
#9
I'd wait to check with some of the more experienced Phase experts before doing anything. A stock Vapo should easily handle anything at stock volts. It's only when running at high volts for a long period that units are wearing out. That being said, something doesn't sound right about the fluctuating fans - It's possible there is a controller issue or maybe just a loose connection somewhere.
__________________
Asus P5k DLX
C2Q6600 G0
4365 mhz - 485 x 9 @ 1.68v(Bios) 1.65v w/droop
2G Patriot 8500 EL at 5:6 1164 5-5-5-15
TT Toughpower 750,
1 x Raptor, 1 x 250G WD2500KS
BFG 8800GTX OC 600/1800
Custom Single Stage Phase
04-28-2007, 02:09 AM
#10
yer i agree the ls should handle the quad ok at stock vcore..
problem is knowing when to stop the vcore rise..... and keep the life of the vapo going..
__________________
Asus COMMANDO -Intel Q6600 @ 3.6Ghz 401x9 have sum test @ 445x9 4GHZ :-)
2x74 Gig Raptors Raid 0..GSKILL 6400 2x1Mb matchd Pair.-OCZ 550w Powerstream adjustable rails- XE2 Vapochill -pioneer Dvd.-2x160 Gig Hitachi ide drives..-Asus 7600 gs video card
http://www.hwbot.org/user.do;jsessio...C3?userId=8636
04-28-2007, 09:21 PM
#11
Xtreme Mentor
try putting a 120mm fan in front of the compresor and a 120mm fan behind the compressor in a push/pull configuration, more air-flow should help. compressors are ment to get hot, but it depends what gas yoru using. the cold gas coming from the suctionline is supposed to cool it, but if the quad core is dumping too much heat into the line it might not be cold enough to cool down the compressor.  sorry thats a bummer. what would be the first thing to mod to make it better?
04-29-2007, 07:42 PM
#12
Single stage can manhandle quad at stock vcore. Its once you get above 1.5 or so that things start going awry, depending on what your unit is tuned for.
04-29-2007, 11:43 PM
#13
why is your case covered in tape ?
04-30-2007, 01:14 AM
#14
-100c Club Member
I think because he markered where he need to make holles etc...
You have really nice setup there
regards
04-30-2007, 05:43 PM
#15
Xtreme Mentor
if you don't mind me asking, and this question is not ment to me hostile and sorry for me being ignorant, but arn't these like 900 bucks each? the vapochills and promaterias? why do people continue to buy them at such a high price when they are goign to spend an additional large sum of money to mod them? (askign a question, not being snotty...) do people not research before or something? btw, i love the watercooled gpu's, nb and sb. i might do the same one day...
04-30-2007, 05:53 PM
#16
I am Xtreme
People just dont research properly.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
04-30-2007, 06:03 PM
#17
Xtreme Mentor
so am i retarted or is there no point to this unless people are scared of custom stuff?
04-30-2007, 06:16 PM
#18
Xtreme Mentor
Just as noob said people buy into marketing or simply impatient.
I tell all my customers that for bang for the buck custom is the only way, but side effect is it takes a bit longer to get the finnsihed product.
Chances are he scored his unit used, so non the less its a deal.
__________________
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Today's Fortune Cookie:
- Imbesi's Law with Freeman's Extension: In order for something to become clean, something else must become dirty; but you can get everything dirty without getting anything clean.
- Life can be so tragic -- you're here today and here tomorrow.
- The chief danger in life is that you may take too many precautions.-- Alfred Adler
- Those who are too smart to engage in politics are punished by being governed by those who are dumb. - Plato
- Gunter's Airborne Discoveries: (1) When you are served a meal aboard an aircraft, the aircraft will encounter turbulence. (2) The strength of the turbulence is directly proportional to the temperature of your coffee.
- A wise man can see more from the bottom of a well than a fool can from a mountain top.
04-30-2007, 06:30 PM
#19
Xtreme Mentor
bummer city though. if you don't mind me asking, or if this isn't too far of topic, how many hp are those vapochill compressors?
05-05-2007, 01:20 AM
#20
I too, am a newb.. I bought my Vapo LS today. I couldn't pass it up.. Although it was roughly $850 dollars, I only had to pay for HALF. Brand new. So, it seems since I am a quadcore owner, it sounds like I need to find someone to mod it for me, as I would like a 24/7 overclock @ 4ghz.
__________________
Intel Q6600 @ 3.6ghz ~ Xigmatek S1284EE
GSkill DDR2-1066mhz @ 1080mhz / 2x2gb
Enermax Galaxy 1000w Gamers Edition PSU
Asus P5E-VM HDMI Motherboard
XFX GTX260 216 BLACK EDITION
WD 640gb HDD
Lian Li PC-A05B
Westinghouse 42" 1080P Monitor
Logitech G5 v2 Mouse
SPDIF (Pioneer VSX-D411) 5.1+1 surround sound
05-05-2007, 04:45 AM
#21
I am Xtreme
Or people also see the insulation on Vapochill or Mach, and go, o thats nice and easy, no hassles no mess. And then they trust that insualtion completely and kill hardware.
Ask Fragtek about that, and I don't mean in a sarcastic way, seriously ask him.
__________________
NoL: gom gom gom
05-05-2007, 05:14 AM
#22
Runmc is in Texas, he might be able to help you out  .
05-05-2007, 05:16 AM
#23
I am Xtreme
Mach's are cheaper to mod then Vapo's though, so expect the need for a new compressor to get better performance, possibly a SLHX or accumulator with capillary wrapping, and a new evap head even.
__________________
NoL: gom gom gom
05-05-2007, 08:25 PM
#24
Thanks.. I sent Jinu117 a message but I guess he is a busy man.. I will shoot RUNMC a PM..
__________________
WD 640gb HDD
Lian Li PC-A05B
05-05-2007, 10:54 PM
#25
Liquid Nitrogen GURU
As long as your Discharge and Compressor casing don't exceed 225F the unit is with in manufacturer specs for operating conditions.
__________________
"If It Don't Overclock Its Broken"
"NexGen Overclocking"
"Overclocking, its a life style"
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
