XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 04-23-2007, 06:24 PM   #1
onethreehill
onethreehill's Avatar
Another picture of R600
http://www.fudzilla.com/index.php?op...d=657&Itemid=1
onethreehill is offline   Reply With Quote
Old 04-23-2007, 06:28 PM   #2
Dainas
Dainas's Avatar
God thats allot of copper.
Well I guess we'll have to wait till launch to figure out what the none OEM cooling will be like, can't believe the partners are going to want to deal with this setup for long.
__________________
i7 860@3.9ghz---------Athlon X2 6000+
GSkill|4X2GB|CL9|1600-2x2GB DDR800
Asrock P55 Extreme-----MSI K9A2 Platinum
Agility120+F3 1TB-------F3 500GB
eVGA GTX 285-----------Diamond HD4850 512mb
Silverstone Zeus 850w--NeoHE 500
LG245WP+LP2475w-----LP2475w
Dainas is offline   Reply With Quote
Old 04-23-2007, 06:38 PM   #3
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
thats basically the same as the 7900GTX heatsink, but all copper, with a slightly different placement of the fan.
the 7900GTX's heatsinks was definatly one of the best stock coolers I ever seen.
now being all copper, it should be great for this card.
assuming the placement of the fan doesnt actually hinder its performance.
but if thats what happens, just take the top shell off, and zip tie a few 80mm fans to it, and it would basically solve any cooling problems it might have with weird fan placement on the end of the card.
but honestly, it looks like a real solid heatsink, after my experiences with the 7900GTX.
__________________
Kunaak is offline   Reply With Quote
Old 04-23-2007, 07:02 PM   #4
Daveb2012
Daveb2012's Avatar
Send a message via AIM to Daveb2012
I think ATI put a lot of thought into this, I have been impressed by their stock coolers for the 1900 and 1950 XTX. I was getting better temps with stock/lapped/as5 heat sink then any after market I tried.
__________________
Current Setup:
-9850 GX2's in Quad SLI config
-Asus P5N32-SLI MB
-2x512mb of PC2-5300 DDR2
-Intel Celeron D OC'd to 3.2Ghz
-Windows Me with XP theme
-WD Caviar 20GB Hard Drive
-Zip drive
-Jazz drive
-3.5" floppy drive
-5.25" floppy drive
Daveb2012 is offline   Reply With Quote
Old 04-23-2007, 07:40 PM   #5
red
Look at the size of the heatpipes, it's ridiculous but this is necessary to do remove 200W+.
red is offline   Reply With Quote
Old 04-23-2007, 07:48 PM   #6
m0da
m0da's Avatar
Send a message via AIM to m0da
200W+ is the number we're looking at.
__________________
m0da is offline   Reply With Quote
Old 04-23-2007, 07:52 PM   #7
gdogg
I am sure the reason for the fan placement, is to get that heat, out of the case, wouldn't want all that heat making your cpu boil, along with other components.
I sure hope the retail cooler doesn't throw heat into the case.
__________________
System
Intel C2D Q6600 @ 3.78Ghz 1.536V (1.55V bios)
TC PA 120.3 , D-TEK Fusion, MCP655, Micro Res, 6 Yate Fans
Mushkin HP2-6400 2X2GB @ 100Mhz 5-4-4-12
Asus Maximus Formula 420x9
4 Samsung Spinpoint 250GB SATA II in raid 0
Crossfire HD 2900XT 512MB 900/900 1.25V
Pioneer DVD-RW
830 Mobo Tray, Wating on MM Duality
PC Power and Cooling 750W , mobo/cpu/gpus/cdrom , Powmax 380W , hd, fans, pump
Acer AL2616W 19200x1200 100Hz (75hz native)
gdogg is offline   Reply With Quote
Old 04-23-2007, 08:11 PM   #8
p0tter
p0tter's Avatar
ROFL
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline   Reply With Quote
Old 04-23-2007, 08:14 PM   #9
johnsally
to me the x1900xtx coolers sucked ass. The temps were hot as hell while the fan is spinning out of control.
johnsally is offline   Reply With Quote
Old 04-23-2007, 08:23 PM   #10
Dainas
Dainas's Avatar
Well the X1950XTX cooler was a great improvement, and a derivative is what I'm betting the top end retail R600s will end up with... Well something that doesn't have the fan hanging over the edge of the card and adding 4-inches to its length. No doubts the R600 cooler we're seeing right now is really effective, Just can't believe that yields won't get better to the point they can use something smaller.
__________________
Old 04-23-2007, 08:46 PM   #11
Speederlander
Xtreme Mentor
Speederlander's Avatar
R600
That's due Q1 2008, yes?
__________________
"In today's regulatory environment, it's virtually impossible to violate rules." -- Bernard Madoff, Oct. 20, 2007
xtremespeakfreely
Speederlander is offline   Reply With Quote
Old 04-23-2007, 09:01 PM   #12
Hard H20
Xtreme Cruncher
Send a message via ICQ to Hard H20 Send a message via Yahoo to Hard H20
Holy Copper Batman.
Jebus, you will need an extra bracket just to hold the card in the slot. I know one thing, if that won't keep the card cool, nothing will!
__________________
Charles Barkley
"Poor People have been voting for Democrats for the last 50 years ... and they are still poor."
Hard H20 is offline   Reply With Quote
Old 04-23-2007, 09:08 PM   #13
FghtinIrshNvrDi
FghtinIrshNvrDi's Avatar
Send a message via AIM to FghtinIrshNvrDi Send a message via MSN to FghtinIrshNvrDi Send a message via Yahoo to FghtinIrshNvrDi
hmm, nice cooler. Hopefully they made it just a little overkill on purpose.
Ryan
__________________
"Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Abit IP35 Pro
Intel Core 2 Quad 6600 @ 3200 w/ Tuniq Tower
2x2gb A-Data DDR2 800
AMD/ATi HD 3870
FghtinIrshNvrDi is offline   Reply With Quote
Old 04-23-2007, 09:12 PM   #14
Duonger
Mushkin U.S.A.
Duonger's Avatar
Send a message via ICQ to Duonger Send a message via AIM to Duonger Send a message via MSN to Duonger
got 2 coming to me already to play with ... i cant wait.
__________________
Mushkin Employee and DAMN Proud Of IT!
www.mushkin.com<---new and improved
email me <--- For any assistance or help
Keep your eyes open... more to come.....muhahahaa
Duonger is offline   Reply With Quote
Old 04-23-2007, 09:17 PM   #15
BenchZowner
One-Eyed Killing Machine
BenchZowner's Avatar
Send a message via ICQ to BenchZowner Send a message via AIM to BenchZowner Send a message via MSN to BenchZowner Send a message via Skype™ to BenchZowner
you can always ask FedEx to redirect the package to my address.Ding, problem solved
__________________
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Oliver Baltuch, Steffen Eisentein
ASUS CAN LICK MY COJONES
BenchZowner is online now   Reply With Quote
Old 04-23-2007, 10:39 PM   #16
verndewd
verndewd's Avatar
dewd your company makes some nice ram
200w is outrageous and a hot chip for a 5lb cooler is insane. 65nm parts for the xtx would be alot better. I do like the clocks on these and I am hoping we get some faster ones on a node shrink with some scaling.
I am looking forward to 2ghz clocks on gfx .45nm nice and cool low powered sweetness. I am waiting for benches and prices before i trade out my 1900gt.
verndewd is offline   Reply With Quote
Old 04-23-2007, 10:44 PM   #17
Sentential
Sentential's Avatar
Send a message via ICQ to Sentential Send a message via AIM to Sentential Send a message via MSN to Sentential Send a message via Yahoo to Sentential
Lol.. doesn't Brian have enough AMD toys to play with?
__________________
NZXT Tempest | Corsair 1000W
Creative X-FI Titanium Fatal1ty Pro
AMD Phenom II 940BE XIGMATEK HDT-S1284 (CACVC AC 0850 BPDW)
BFG GTX260 216 55nm (730 / 1500 / 1160)
MSI K9N2 SLI Platinum
PNY PC2-5300 (4x2048MB)(5-5-5-12 @ 800mhz @ 2.22v)
Heatware: 13-0-0
Nintendo Wii (2GB Memory Card)
3dmark01SE: xx,xxx || 3dmark03: 81,010 || 3dmark05: 24,785 || 3dmark06: 19,602
Sentential is offline   Reply With Quote
Old 04-23-2007, 10:46 PM   #18
verndewd
verndewd's Avatar
sharing is caring ,right?
Old 04-23-2007, 10:50 PM   #19
Spawne32
Xtreme Guru
Spawne32's Avatar
Send a message via AIM to Spawne32 Send a message via MSN to Spawne32
the watercooled guys are gona need a whole separate loop for that thing.
__________________
My Heatware
Spawne32 is offline   Reply With Quote
Old 04-23-2007, 11:30 PM   #20
NightCrawler™
NightCrawler™'s Avatar
I really don't enjoy listening to the sound of a Boeing 747 taking off whenever I play a game....
__________________
Lian Li V2000+ Modded
Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
Asus Rampage Extreme 2
OCZ 3x2GB DDR3 1600 Platinum
EVGA 8800GT SSC 730/1800/2000Mhz SLi
OCZ GameXStream 700W
NightCrawler™ is offline   Reply With Quote
Old 04-23-2007, 11:43 PM   #21
safan80
Xtreme Guru
safan80's Avatar
I love all the copper!
__________________
Watercooling parts:
Pa120.3 rad (CPU)|PA120.3 (for video card)|GTZ on CPU
|stock cooling on chipset|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop|aqua extreme 50z pump on gpu l
cpu i7 960 @???
old cpui7 920 3836A762 @ 3.7Ghz
Gigabyte EX58-UD5 F9e bios
12GB of G.skill (6 x 2GB)DDR3 perfect storm F3-16000CL8-2GBPS 7-7-7-21
2x bfg 285
new Dell 30"LCD 3008wfp oh the colors!
LG GGW-H20L
COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250watt for the cpu/mobo & video
OCZ600MXSP 600W for the hard drives
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running two raid 10 arrays 2TB boot array 6TB storage
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
safan80 is offline   Reply With Quote
Old 04-23-2007, 11:45 PM   #22
grudgelord
grudgelord's Avatar
If I got one of the damn things I'd slap a hydrothermal generator and some thermocouples on it and sell some power to California!
__________________
Look at the tyranny of party--at what is called party allegiance, party loyalty--a snare invented by designing men for selfish purposes--and which turns voters into chattles, slaves, rabbits, and all the while their masters, and they themselves are shouting rubbish about liberty, independence, freedom of opinion, freedom of speech, honestly unconscious of the fantastic contradiction; and forgetting or ignoring that their fathers and the churches shouted the same blasphemies a generation earlier when they were closing their doors against the hunted slave, beating his handful of humane defenders with Bible texts and billies, and pocketing the insults and licking the shoes of his Southern master.
--Mark Twain, The Character of Man
Originally Posted by nn_step View Post
One would think your sense of freedom and liberty would not become more narrow as time goes along. Like the frog in the pot that is slowly boiling, just because it isn't instantly hot doesn't mean you wont cook alive...
grudgelord is offline   Reply With Quote
Old 04-24-2007, 12:15 AM   #23
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
my radiator just started crying when it saw that card.
MaxxxRacer is offline   Reply With Quote
Old 04-24-2007, 12:51 AM   #24
96redformula7
96redformula7's Avatar
Anybody notice those heat pipes are much thicker diameter too. I have a feeling it weighs alot too.
__________________
HTPC - AMD Regor 240 - 4GB Gskill - AMD HD 5850 - Avermedia Duet - Harman Kardon avr247 - Surround Sound (Infinity Beta 50's, 10's, 360, and ed a2-300) - Samsung 46"
Desktop Powerhouse PC - Gathering dust due to high usage of HTPC as general pc now
96redformula7 is online now   Reply With Quote
Old 04-24-2007, 05:32 AM   #25
doompc
doompc's Avatar
That's what I thought, I had the GPU at ~80ºC under full load.
Get Rivatuner and set the fan to about 70%, you'll have 65ºC full.
Under 60ºC full at 100% but it's LOUD!!!
__________________
Athlon II X2 240, Jetway XBLUE GF8100, 2X2GB DDR2-800, 80+500+750GB, Zalman 360w PSU = 70w idle
doompc is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
