IMO the TJ09 is not the greatest for water cooling.
The problem is now to fit everything in, elegantly. Since the PS is on the bottom of the case, you have a pretty tight spot in between the PS and the intake fan, so it's not a comfortable place for the pump to sit -- especially with a large PS like the 180-220mm units. Your best bet is probably the Swiftech integrated MCP350 & 5.25" bay reservoir unit, although like most bay reservoirs it tends to make water-bubbly sounds a lot. If you used an MCP650 it would take up like 3 of your 5-1/4" bays.
__________________
"Stability is Everything" - Current Rig:
Vista x64 | Asus P6T Deluxe | Core i7 965 @ 3.81 GHz | 12 GB Mushkin CAS7 DDR3-1600 | EVGA GeForce 295 | Apple 30" Cinema Display | Intel PRO/1000 PT PCI-e x1 Server NIC
Danger Den TDX 1366 water block, Laing 355 pump, Thermochill PA120.3 radiator, Papst 120mm fans | CoolerMaster Stacker STC-01 w/ 300mm Cross Flow Fan | ToughPower 1200 PS
Adaptec 5805 SAS RAID Controller | 2x Seagate Cheetah 15K.6 15,000 rpm 300GB SAS drives in RAID0 (boot/OS) | 2x WD Caviar RE3 1TB SATA drives in RAID0 (data)
Asus HDAV1.3 Deluxe PCI-e x1 into Pioneer Elite VSX-84TXSi (as preamp) via HDMI | 4x Marantz monoblock amps | B&W Nautilus 805 speakers (front) | B&W DM600 (rear) | REL Q150E Sub
