XtremeSystems Forums
Reply
Old 04-07-2007, 09:55 PM   #1
anzial
Fuzion bought from Petratechshop - wrong barb threading?
Well, I went out and bought D-Tek Fuzion for my brand new C2D setup. Ordered from petra's tech shop with very little hazzle, excellent service, prompt shipping. However, I think I have a problem with the barbs they supplied with the waterblock - the threads do not match. I tried screwing in the barb and it doesn't want to go in. It seems, the Fuzion top has wider threads than the ones on the barbs.
Well, you can understand my concern. I don't want to force the barbs in, which will created a new thread in the top, while thread may potentially spring a leak. I also don't want to use teflon tape either as it will apply extra pressure on the plastic top, causing a long-term stress which may lead to cracking and leaking (happened to me before). Or do I worry too much about this?
I'd appreciate any advice. Thanks!
anzial is offline   Reply With Quote
Old 04-07-2007, 10:07 PM   #2
ranker
Send a message via AIM to ranker
Did you purchase chrome fittings or stock fittings? If you purchased the chrome fittings, Petras only sells EK's and DD's in conjunction with the Fuzion. Both are absolutely compatible. Sometimes you just need to use a bit more elbow grease.
ranker is offline   Reply With Quote
Old 04-07-2007, 10:10 PM   #3
anzial
Yeah, I got Dtek fittings actually Anyways, I don't have any problems with this but I'm used to fittings going in easy rather than requiring a wrench right off the bat... I mean I can't turn this thing even once before it stops dead in its tracks
Old 04-07-2007, 11:09 PM   #4
mcoffey
Banned
carefull, DD shiped me 9/16 fittings one time whe they should have been G1/4, they could have done the same with Petra's or you. I got a FuZion from Petra's with EK's barbs, and they went on like butter.
andyc
mcoffey is offline   Reply With Quote
Old 04-07-2007, 11:19 PM   #5
Petra
I am Xtreme
Petra's Avatar
Send a message via AIM to Petra
If you bought it recently, then you likely received D-Tek fittings. The new D-Tek fittings are pretty much exactly to spec... which is probably why you're having trouble--the tapped holes in the Fuzion seem a touch small (apparently, something to do with the injection molding process ). I say that they're small because my 1/4" BSPP (G1/4) tap pulls a lot of materiel outta the Fuzion's top, but the barbs work wonderfully after a quick clean-out with my tap. It is for this reason that D-Tek has started pre-installing barbs on the block (beginning with the shipment that'll be arriving on Tues.).
__________________
I'm doing science and I'm still alive...
Petra is offline   Reply With Quote
Old 04-08-2007, 12:15 AM   #6
anzial
Petra - so what am I to do? I'm afraid forcing the barbs into the plastic top to avoid cracks, but I don't want any leaks either... any ways to swap my block for the new one with barbs pre-installed by D-tek? That way if it leaks, it's all on them After all, I don't have a shop here with a tap to make this top compatible with the barbs I got
Old 04-08-2007, 12:24 AM   #7
Petra
I am Xtreme
Petra's Avatar
PM me with your order number and I'll send some EK barbs out to you on Monday--they should go in a lot easier.
__________________
Old 04-08-2007, 12:30 AM   #8
anzial
Thanks a bunch, petra! PM sent
Old 04-08-2007, 05:32 AM   #9
SiGfever
Hamster Powered
SiGfever's Avatar
Send a message via MSN to SiGfever
__________________
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
SiGfever is offline   Reply With Quote
Old 04-08-2007, 05:43 AM   #10
mike047
Xtreme Cruncher
mike047's Avatar
RESPECT
This is the way business should be done.
I'm not into "alternate" cooling, but if I was....Petra's is where I would shop.
__________________
mike
CIB For my DAD 09-11-07
comhar a neartú agus a leathnú
mike047 is offline   Reply With Quote
Old 04-08-2007, 06:44 AM   #11
septim
Banned
Send a message via Yahoo to septim
issue resolved with but a pm... another vote for Petra's shop...
thanks for mentioning this issue with the fuzion, i was just browsing thru the specs, and its looking good and bought...
septim is offline   Reply With Quote
Old 04-08-2007, 06:48 AM   #12
mcoffey
Banned
there's 2 things you can't beat IMO, a FuZion and Petra's Tech Shop. They get it.
have a blast,
andyc
Old 04-08-2007, 07:13 AM   #13
Subsider
Subsider's Avatar
Send a message via ICQ to Subsider Send a message via AIM to Subsider
nice to know and see a shop so dedicated !!!! I have a fuzion in route from Petra's . Im sure i would have been scratchin my head ! Im good though ,as i have some EK barbs lyin around !
__________________
Rig 1:
E6850 @ 3850Mhz - Asus p5k prem.
2x 1gig CellShock 8000 - Evga 880GTX
2x Segate 320gig HD Raid 0 - 750w PC & PC psu
H2O Cooled
Rig 2:
Q6600 G0 @ 3450Mhz - Asus p5k delx
2x1gig OCZ 8500 - Evga 880GTS 640
2x Segate 400gig HD Raid 0 - 750w PC & PC psu
dual loop H2O Cooled
Subsider is offline   Reply With Quote
Old 04-08-2007, 08:25 AM   #14
Fossil
Fossil's Avatar
I have just put in a FuZion that came from over-clock.uk, it came about a week ago with pre-fitted barbs, but I don't know if over-clock put them in whether it was or D-Tek. Barbs looked the same as others I had from over-clock, so I'm guessing the former.
__________________
Current: E6600, AT1950XTX, P5B Dlx, 2Gb OCZ Platinum 1T, 4x320Gb Seagate, Tt Tai-Chi case, D-Tek FuZion, MCW30, Tt P500 7W pump, Swiftech 7/16" tube, HiFlow barbs, TC PA120.2, w 2x Scythe SFF21 D, Scythe SFF21 E, Scythe SY1225SL VBL
Planned GFX loop: MCW60, DDC+ w Petra's top, BI GTS240 (or a PA if I can fit it in somehow)
Parts waiting for attention: MCW60, PA120.2, PA160, BI GTS120, BI GTS240, Apogee GT, more Scythe fans, DDC+ w dodgy AlphaCool top that no longer leaks (but does rattle) and a box of Tt landfill that came out of the Tai-Chi
Fossil is offline   Reply With Quote
Old 04-08-2007, 09:19 AM   #15
AndyM
AndyM's Avatar
I had trouble like yours on one hole of my DTek, that and the lack of a chamfer on the holes to support the o-rings made me really wonder about this design. I just got rid of the o-rings, used Permatex Ultra Black RTV, sort of 'cross threaded' the barb into the offending hole, and called it a day. Much easier than dicking with thread tape and poorly designed o-ring layouts.
__________________
C2D E8400 @ 4.4 Ghz
Asus P5K Deluxe
Nvidia 8800 GTS @ 648/900
2GB Ballistix
Dtek, Swiftech & EK blocks, 2x D5, PA120.3, 2, & 1.
WD Raptor X 150GB & Seagate 7200.10 320GB
X-Fi Prelude
Corsair HX620
Silverstone TJ07
Dell 2407 WFP
AndyM is offline   Reply With Quote
Old 04-08-2007, 11:05 AM   #16
Chas_The_Man
JB-WELD Is your Friend. I got an early one with D-TEK Barbs allready on it. No "chamfer" made me rip them out and put some JB-WELD on there.
__________________
Fold for Xtreme Systems : Help Cure Cancer and Have Fun! (Do something usefull with that pimped out rig you slackers)
My Rig : Intel 975 XBX2 / Qx6700 Quad-Core @3466.86 MHZ
4GB Crucial Ballistix DDR2 5-5-5-15 @1.84v
EVGA 7950GT KO -> BenQ FP241W (woot!)
PCP&C 750W Silencer - Zalman Reserator II (Modded)
Chas_The_Man is offline   Reply With Quote
Old 04-08-2007, 11:37 AM   #17
TheBigBunny
You're better off since teflon tape should NEVER be used on plastic threads.
TheBigBunny is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
