I left idea of this PC @ p3 with full plexi case (p3 sucks honestly and more expensiv than a64 here lol)
so
this is new case, I am making it in free time, so build of it very slowly but I finally I mount my pc on it
case is done from 3mm thick alu profiles + semi transparent plexi panels
final dimension of it is:
lenght 270mm
height 333mm
width 214mm
specs:
-cpu, amd 3500 winchester @ stock speed @ xp90 cooller (but I will change for bigger hs soon)
-mobo is normal atx gigabyte k8u-939
-gpu gf6200 with intel(s423) heatsink :P:
-ram geil 512 ddr400 cl2,5
-hdd seagate momentus 5400.3 2,5: 100gb
-psu delta 350W with 12cm acutake fan
whole idea of it is small, silent pc
(max 2 fan on case each on 5V)
so lets go, some pics
geforce overkill
(max temp which I saw is 42*C in NFSMW)
hdd is mouted under mobo
on front i make holes for 120mm fan(maybe in future i put thermochill pa120.1 for watercooling) 4x20 lcd whcich I want plug on LPT, + hole for power button and 2x usb on front, I dont need other holes for leds or reset button bcoz I dont use it
and comparasion with intel box
