XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Operating Systems
Reply
Old 03-30-2007, 06:58 PM   #1
marsofold
marsofold's Avatar
How To Make An OS Selection Switch For Under $10
I bought a dpdt rocker switch at Radio Shack and a long "Y" power splitter cable with molex connectors on eBay. Cut off one of the yellow and red wires from the female molex connector and clipped the other red and yellow wire from it to 6 inches. Soldered the 6 inch red and yellow wires to the middle (source) contacts of the switch. Then I soldered the remaining yellow and red wires to the side contacts of the switch so that I can select which male molex connector gets power. Mounted the switch into a blank floppy bay panel. I have one Raptor drive going to sata port0 and another going to sata port1. And one molex from the switch feeding power to each of the two Raptors. Only a powered drive is seen by my motherboard (BadAxe2) and booted. So now I just flip the switch to one side to boot up Windows XP and to the other side to boot up Vista. Cheap and works like a charm!
__________________
Core2Duo E6700@3.00Ghz@1.35v
Thermalright SI-120 Cooler
Bad Axe2 with 2333 BIOS
Corsair Twin2X2048-8500C5@2.1v
256Mb Powercolor X1950Pro
(2)150Gb Raptors/Vista-XP Toggled
Samsung SH-S183L Burner
Corsair HX620 Power Supply
Antec Sonata II Case
Comcast@6Mb/sec
marsofold is offline   Reply With Quote
Old 03-30-2007, 07:02 PM   #2
IYP
Send a message via AIM to IYP
nice but i think its a little unnecessary considering the vista bootloader works without problems booting xp...and of course you dont have to wory bout the switch getting thrown at the wrong time
__________________
afireinside on AIM :: I just about got walked in on because my mom wanted to show me her website :|
IYP :: hahaha
afireinside :: friggin ruined my night
VOTE YES FOR A MOBILE PHONE SECTION HERE
Need a new screen? Go to THE LCD BUYERS GUIDE
IYP is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
