XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme Stanford Folding Team
Reply
Old 03-28-2007, 01:17 PM   #1
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
G80 Folding?
I know this would probably be big news if there was even an announcement but.. are there any rumors of a G80 folding client or is Nvidia not working with Stanford like ATi is/was? I really want a client that'll run x86 code on a GPU, then I could run all my projects
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 03-28-2007, 01:22 PM   #2
justin_c
Xtreme Cruncher
justin_c's Avatar
they have plans for a nvidia folding client.
the only reason why its been held so far back is because the ATI cards are more adept at folding than the nvidias.
justin_c is offline   Reply With Quote
Old 03-28-2007, 03:39 PM   #3
[XC] gomeler
Damn shame considering how many G80s are floating around the world right now idle. They just need to somehow use virtualization hardware to run x86 code on the GPUs... somehow Thanks for the info, will keep my eyes peeled for a G70/G80 client.
__________________
Old 03-28-2007, 04:21 PM   #4
Sorrow13
Sorrow13's Avatar
the issue is (and likely will be) nvidia driver support. the hardware capability is there, but nvidia drivers simply do not work properly with folding.
this has been discussed at length HERE
__________________
sig is way out of date
Best way to catch me is by PM // AKA Harmavoidance0
Sorrow13 is offline   Reply With Quote
Old 03-28-2007, 05:38 PM   #5
embeejay
Xtreme Cruncher
embeejay's Avatar
Gpu's are specialized processors, they aren't able to do a cpu's job, virtulization or not, they simply can't do all the type of work a cpu can. what they can do is a small subset of what a cpu can, but way better than a cpu
__________________
My current aircooled system
Rig: Antec Solo, Seasonic S12-500, Intel D975XBX, Core 2 Duo E6600, Corsair TWIN2X2048-8500C5D, XFX GeForce 7950 GT 512MB, WD Raptor 150GB & 2 * Maxtor DiamondMax 10 250GB
Cooling: Thermalright Ultra120, 2 * Nexus realsilent 120mm & 2 * Nexus realsilent 92mm, gpucooling is passive.
OC: CPU: 3.36GHz, BUS: 373MHz @ strap1066, RAM: 467MHz @ 4:5
Voltage: vCORE: 1.29, vMCH: 1.6, vFSB: default, vDIMM: 2.2
Temps: Ambient: 22C, CPU: 43C/65C, GPU: 54C/80C, MCH: 43C/50C, ICH: 41C/47C
Noise: Whisper Quiet, but not inaudible
embeejay is offline   Reply With Quote
Old 03-28-2007, 07:38 PM   #6
couppi
Last I heard, even though the G80 has 128 unified pixel pipelines or whatever, only 16 at a time can be used for most folding calculations. For some specialized calculations, 32 pipelines can be used. The folding performance would be on par with an x1600 series card at best, and the Pande group doesn't feel that that's a worthwhile contribution
couppi is offline   Reply With Quote
Old 03-28-2007, 09:10 PM   #7
Sorrow13
Sorrow13's Avatar
if youre speaking of pixel granularity, i was under the impression that meant only blcks of 16 things at a time can be done. For instance, with 128 shaders, 8 groups of instructions can be issued if they are the right size.
HERE
Is an explanation ofwhat i believe pande group is referring to, albeit a bit old (only refers to 7900 series)
I believe the 8800 series is competetive in that area, if not as completely efficient as the ATI solution, the cards themselves still hold great potential.
__________________
Old 03-28-2007, 09:28 PM   #8
couppi
It took some googling, but I found the thread. On the sixth page, it looks like folding on G80 is more or less a driver issue, but I haven't read the whole thread.
Old 03-28-2007, 10:02 PM   #9
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
Why does that not surprise me.... nVidia drivers strike again
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline   Reply With Quote
Old 03-28-2007, 10:53 PM   #10
[XC] gomeler
Oh trust me, I know The ALU monsters that are GPU cores just need to be unleashed, rather than calculating vertexes they need to be crunching numbers for me. I would kill for all those gigaflops on a few of my pet projects.
__________________
Old 03-28-2007, 11:35 PM   #11
eXceededgoku
eXceededgoku's Avatar
Send a message via MSN to eXceededgoku
lol teh tables have really turned in the "ati makes sucky drivers" since CCC is actually almost bareable now (:O) and nvidias drivers now suck with a crappy control panel... what has this world come to!?
__________________
Core 2 Duo E6600 @ 3.2Ghz (400Mhzx8) 1.52V (set in bios, 1.47v after droop)- worst C2D ever | 4GB GeIL PC6400 4-4-4-12 @ 800Mhz 4-4-4-12 | Gigabyte DQ6 @ 1600Mhz | Sapphire 1024MB HD2900XT @ 858/1153 | Enermax Infiniti 650W | Silverstone TJ07-B with custom watercooling (CPU/MOBO/GPU) | Vista Ultimate x64 | BenQ FP241WZ
eXceed TJ07 worklog/build
eXceededgoku is offline   Reply With Quote
Old 03-29-2007, 01:41 AM   #12
embeejay
Xtreme Cruncher
embeejay's Avatar
hehe i couldn't agree more nvidia has taken a turn for the worse.. my next gpu will probably be an amd although i've been sticking with nvidia since the TNT2
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
