XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 03-25-2007, 06:18 PM   #1
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
My First Autocasacde, r290/r744
After months of planning and research I took the plunge into autocascades.
Compressor: 1/2HP Rechi Rotary
Condensors: 2x 10x10 two-row condensors in parralel
Phase Seperator: 12" long 1" diameter copper pipe with endcaps and copper wool
Suction Line Heat Exchanger: 10" liquid/gas HX, can't remember the manufacturer
Heat Exchanger: 12" long 1" diameter copper pipe filled with 7 10" long 1/4" copper pipes connected in parralel.
Metering Devices: 7' of 0.031" cap tube for the evap and 8' of 0.031" of cap tube for the HX
Filters: 2x liquidline filter/dryers for installed before each cap tube.
Fan: 12" unducted fan cooling compressors and condensors.
Static Pressure: 97 psi
Unloaded Pressure: 210 psi high 40 psi low
Safety: 325 psi electrical cut off, 375 psi valve
It took me a while to figure out how to tune this system, the amount of volume compared to a single stage made it rather difficult when I dumped roughly 20 ounces of propane into the system to get the proper HX temperatures. I made a mistake in the HX captube, on reflection it should be much shorter, think I'll cut off 18 inches next weekend. I don't know if my system was just terribly thought of but I can't get the HX to drop below -20 celsius and the evap to drop below -56.5.
Pulldown time from system at ambient to -56.5 on evap takes about 10 minutes. The worst part is the drop from 31 celsius (ambient today) to 5 celsius takes a good 7 minutes then it snowballs to -56.5 celsius. On startup discharge pressures spike at 255 PSI on immediate startup and drop down to 210psi within the first minute. Power consumption peaks at 540 on immediate startup and slowly drops down to 460 watts with a 35 watt fan included. I think that just about covers it, diagram of the system along with pictures below, it isn't pretty but I think it's pretty good for a first job and a test system.
Future ideas to be applied will be:
Wrap r290 captube around the suction line
Pipe the evap gases into the HX rather than bypass to SLHX
Larger HX/Plate HX
Better gases, r1150 and/or r170.
Better tuning techniques
Sorry about the crappy pictures, I only have a camera cell phone, 1.3MP doesn't cut it.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 03-25-2007, 10:39 PM   #2
aasmaukr
aasmaukr's Avatar
Send a message via MSN to aasmaukr
Nice, good luck with the tuning If the evap captube is only 7' i'd add 2 feet to it. It's a bit short.
I'll post mine again when I'm done with some mods.. High pressure cut-off, evap suction through HX, auxillary condenser etc..
__________________
Asus P5K, C2D E8400, Ati HD4870, 2x2GB Mushkin PC-8500.
My R290 single-stager
aasmaukr is offline   Reply With Quote
Old 03-25-2007, 11:31 PM   #3
{.bLanK} GoD
{.bLanK} GoD's Avatar
Send a message via ICQ to {.bLanK} GoD Send a message via MSN to {.bLanK} GoD
Good to see you're using a cut off switch as well as a release valve. Walt will be proud.
Nothing wrong with that for a first auto cascade. It will only get better
__________________
Originally Posted by kayl View Post
the ethylene in NZ is colder
Originally Posted by DetroitAC View Post
When in doubt about an unknown substance, I taste it just in case it's pie.
Originally Posted by Pete View Post
Would you be willing to piss over the mona lisa?
{.bLanK} GoD is offline   Reply With Quote
Old 03-26-2007, 12:04 AM   #4
[XC] gomeler
Well I managed to get temps down to -59 celsius by venting some of the r290/r744 and then charging with r744 to bump up the r744 content in the loop. Now my static pressures are at 210 psi, operating pressures are 35/230, and it pulls down to the -5x rather quickly but that final creep to -59 takes forever. Done toying with it now, need to get a loadtest on it and see how it handles that first. The captube lengths were definetly the weakspot, I just went with I thought would be decent lengths, I actually thought they could be too short, especially on the evap. Apparently I need a more restrictive system. Wish I had a way to view the inside of all the pipes to see if I'm overcharged on CO2, undercharged on propane etc w/o having to install 5 sight glasses.
__________________
Old 03-26-2007, 05:17 AM   #5
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
Sight glasses are useless as theres no chance of full separation.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 03-26-2007, 05:24 AM   #6
runmc
Admin
runmc's Avatar
How did you find a sightglass in there NOL?
__________________
Worthy is the Lamb
runmc is online now   Reply With Quote
Old 03-26-2007, 05:25 AM   #7
LukeXE
-130C Club Member
Send a message via AIM to LukeXE Send a message via MSN to LukeXE
Add more propane to the system. 35psi lowiside ? Way too much ! Idle you should have around 0,5-1bar, not 35psi.
I`ve got 27psi lowside in autocascade under 350W load (-61*C, CO2 autocascade), so your 35psi is too much. add more R290, let out some R744.
LukeXE is offline   Reply With Quote
Old 03-26-2007, 05:29 AM   #8
n00b 0f l337
I am Xtreme
Luke you also use quite a bit stronger compressors. These are like 9cc rotaries. I think he does need more r290 though. And better capillary sizing.
And Ron,
__________________
NoL: gom gom gom
Old 03-26-2007, 05:42 AM   #9
[XC] gomeler
I'll have to retune it when I get a dummyload onto it, will have start over which is a shame as there is more than a pound of r290 in it. Guess it's time to hitch a ride to refill my cylinder, never thought I'd see the day. Was never expecting amazing results with this system, next one will be a step above with much more attention paid to the cap tube sizing as I just ordered a 100ft spool of the stuff, no more 10ft limitations from Supco.
__________________
Old 03-26-2007, 05:57 AM   #10
n00b 0f l337
I am Xtreme
Gom can you PM me the link to where you ordered from?
I Think you'll see most of your improvement by adding 2 feet of captube, and though I can't see what your HX's look like, maybe neatening up a bit (i know its just a test system) and improving your HX's.
__________________
NoL: gom gom gom
Old 03-26-2007, 06:58 AM   #11
sacha35
sacha35's Avatar
Good luck with the tuning, will watch with intrest.
__________________
sacha35 is offline   Reply With Quote
Old 03-26-2007, 09:35 AM   #12
[XC] gomeler
The 100 footer? I ordered at my local United Refrigeration, the guy gave me a 5 finger discount Once I have the spool in hand (10 days as it's being shipped form chicago) I'll tweak my captube. Final cost is going to be ~$32 for the spool I think, check your local HVAC stores, if anything I could ship you a spool if you can't get it for any cheaper + shipping locally.
__________________
Old 03-26-2007, 09:46 AM   #13
andre X_X
Team.ID
andre X_X's Avatar
Send a message via Yahoo to andre X_X
a friend of mine have a problem on tuning R744 autoc system, usually dice is formed in the captube causing a sudden increase in evap temps. do you have this problem too? how do you tune it?....
__________________
E8600 Q820A750
DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
Winfast 8600GT
Silverstone Olympia 1000w
andre X_X -72c CO2 Cascade
My R22/CO2 Cascade Project
andre X_X is offline   Reply With Quote
Old 03-26-2007, 09:59 AM   #14
LukeXE
-130C Club Member
adding more, more, more and more R290 in to the system.
Old 03-26-2007, 12:36 PM   #15
[XC] gomeler
nope, no dice in the lines yet, the temps just plateau at a point and flucuate +- 0.1 celsius. Just a terrible tune + incorrect captubes are my problem. Store that sells the wirebound resistors I wanted to buy is closed, will have to wait till tomorrow
__________________
Old 03-26-2007, 01:00 PM   #16
LukeXE
-130C Club Member
First tune it to have good idle temp, then try it under load.
Old 03-26-2007, 01:01 PM   #17
n00b 0f l337
I am Xtreme
Just know you'll be increasing the gas charge
Luke, hop to Msn if you could.
__________________
NoL: gom gom gom
Old 03-26-2007, 03:53 PM   #18
TopherTony
TopherTony's Avatar
good luck and keep us posted
__________________
My Custom Pressure/Temperature Charts for Various Refrigerants
QX6700 @ 3900 | EVGA 680i |2 GB Corsair 8500 Dominator | 7800 GT SLi | Silverstone 1KW | Seagate 7200.9 Barracuda RAID 0 + Hitachi Deskstar 2TB RAID 0 | SS Phase w/ Cryostar Evap | MIPS Full Motherboard cooling
My Fake Quad Core is better than your real Quad Core! **cough**Barcelona**cough**
Lian Li Cube Case with Phase and Water DONE!!
TopherTony is offline   Reply With Quote
Old 04-09-2007, 06:00 PM   #19
Ad Rock
Ad Rock's Avatar
Send a message via AIM to Ad Rock Send a message via MSN to Ad Rock Send a message via Yahoo to Ad Rock
Any updates Gomeler?
I want to attempt something similar myself this summer, so I would love to see your results.
__________________
I am intercontinental when I eat french toast.
Heatware
Ad Rock is offline   Reply With Quote
Old 04-09-2007, 07:44 PM   #20
kayl
-100C Club Member
kayl's Avatar
Send a message via MSN to kayl
If ya need some more info on autocascades have a look at this forum, it has ppls builds on autocascades from the last previous competitions.
http://www.teampuss.com/forums/index.php
Also an actual autocascade section as well. Lots of good stuff in there hey.
http://www.teampuss.com/forums/viewf...a00b9645905e74
__________________
GIG X58-UD5, i7 960 5535 i7950 5352Mhz E8600 6300Mhz
Kayl Block Frozen SS systems
Cascade CPU/GPU Tubes
kayl is offline   Reply With Quote
Old 04-09-2007, 10:12 PM   #21
[XC] gomeler
No updates as of yet, been hammered with school and I haven't had a chance to go pick up my spool of .031. This weekend should have enough time, sorry
__________________
Old 04-09-2007, 11:49 PM   #22
Xeon th MG Pony
Xtreme Mentor
Xeon th MG Pony's Avatar
Send a message via Yahoo to Xeon th MG Pony Send a message via Skype™ to Xeon th MG Pony
How are dice geting into your system? Playing yatzie while building?
Or do you mean Dry Ice
__________________
Bring back natural selection! No more warning lables!
The one and Only MG Pony
Today's Fortune Cookie:
- Imbesi's Law with Freeman's Extension: In order for something to become clean, something else must become dirty; but you can get everything dirty without getting anything clean.
- Life can be so tragic -- you're here today and here tomorrow.
- The chief danger in life is that you may take too many precautions.-- Alfred Adler
- Those who are too smart to engage in politics are punished by being governed by those who are dumb. - Plato
- Gunter's Airborne Discoveries: (1) When you are served a meal aboard an aircraft, the aircraft will encounter turbulence. (2) The strength of the turbulence is directly proportional to the temperature of your coffee.
- A wise man can see more from the bottom of a well than a fool can from a mountain top.
Xeon th MG Pony is offline   Reply With Quote
Old 04-09-2007, 11:53 PM   #23
JT from Russia
JT from Russia's Avatar
Send a message via ICQ to JT from Russia
JT from Russia is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
