I want to watercool all my components inside my new Lian Li V2000b Plus II case. I don't seek the best performance out there, just good performance that I can achieve without having to bring heavy modifications to the case.
I've done some research, this is what I came up with:
1 Laing DDC Ultra 12V pump
1 Swiftech MCRES Micro AGB reservoir
MIPS EVGA 680i complete set
MIPS RAM Freezer
2 x EK 8800 GTX
20 1/2" fittings
20 Hose clamps
1 Black Ice Xtreme 2x120 radiator
1 Black Ice Xtreme 1x120 radiator
7m of Tygon clear tube
1 50ml bottle of UV blue additive
1 50ml bottle of anti-corosive
I want your suggestions. Do you think it will work? What should I expect? I'm a noob at watercooling, this is my first setup.
I now have a Asetek Waterchill kit for the CPU only right now, not too fond of it. It only has a 1x120 rad and my CPU stomps all over it.
Up until now I thought I had it all figured. I'm now running into some problems, as some say the SB waterblock will not allow the X-Fi card to go in. I checked some pictures, it seems like a tight fit to me, but I might be wrong.
Does anyone have this MIPS SB waterblock and an X-Fi mounted in the PCI slot between the black and blue PCI-E slots?
I also heard the MIPS 680i set is very restrictive. Will the Laing Ultra DDC 12V pump be able to pull it and move water fast enough to cool the system? If not, will a second Laing DDC Ultra help?
I looked everywhere, I can't find a MOSFET waterblock, aside the one that should launch at Cebit, from Innovatek. Any other alternatives?
CPU will NOT be watercooled. I have a Vapochill LS unit for it.
