XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Bandwidth
Reply
Old 03-11-2007, 03:13 AM   #1
TigerLord
Teamgroup Xtreem Kit 2x1024MB DDR2-667 3-3-3-8 (D9) OC results?
Has anybody used the Teamgroup Xtreem Kit 2x1024MB DDR2-667 3-3-3-8
(D9). I finally settled for those for my P5B-D and E6600, I'm anxious to see what it'll give me.
What can I expect? What did guys get?
TigerLord is offline   Reply With Quote
Old 03-11-2007, 03:18 AM   #2
Micutzu
Champion
Micutzu's Avatar
Send a message via Yahoo to Micutzu
Hope this helps, it's not english but you only need to see the pics. Only low-latency testing because that's what gave the best results on 975X.
Micutzu is offline   Reply With Quote
Old 03-11-2007, 03:36 AM   #3
TigerLord
DDR830 on 3-3-3-4 ? Oh that is sexy ! Too bad you can't see the voltage he's using...
I found this thread too:
http://www.xtremesystems.org/forums/...ight=teamgroup
DDR2-1100@ CL4-4-4-12 @ 2.2v
Looking at the sig of the OP I'll have the exact same rig, I don't know if his OC is on air but if I get a good stepping I should be able to do 3.8ghz with those rams !
Old 03-11-2007, 04:28 PM   #4
TigerLord
Anyone else have testimonies?
Old 03-11-2007, 10:27 PM   #5
Micutzu
Champion
Micutzu's Avatar
There are 3 screenshots for every set of timings, made at different voltage levels: 2.0V, 2.27V and 2.38V (measured with multimeter). 2.38V is still good for 24/7 use, but going higher than that the risk on damaging the chips in long term increases.
Old 03-11-2007, 10:42 PM   #6
andre X_X
Team.ID
andre X_X's Avatar
Send a message via Yahoo to andre X_X
this is my test
http://koc2.com/thread-248.html = on E6600 + P5B Deluxe
http://koc2.com/thread-225.html = on AM2 3000+ with DFI (LOW Voltage Test)
http://koc2.com/thread-215.html = on AM2 3000+ max Vdimm
its not english but you can see the pictures, on AM2 test i was able to bench @ DDR1200 with new bios
__________________
E8600 Q820A750
DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
Winfast 8600GT
Silverstone Olympia 1000w
andre X_X -72c CO2 Cascade
My R22/CO2 Cascade Project
andre X_X is offline   Reply With Quote
Old 03-13-2007, 08:24 AM   #7
Aldy402
Aldy402's Avatar
these sticks rock!
I have these running naked without the heatspreaders
they barely get hot
I've only ran these so far at
ddr1000 - 4-4-3-4
ddr1030 - 4-4-4-5
all on 2.25volts, see sig
__________________
q6600 g0@3.6ghz [DFI LT X48-T2R] 1.4V
8gb gskill f2-8000cl5d-4gbpq
1tb wd black
evga gtx 260 [fuZion gfx 2 /w unisink] + x-fi xtrememusic
corsair hx-620w + lian li pc201b + dell 2408fpw
3/8" tygon r3400/d-tek fuzion/mcw30/petra ddc2+/thermochill pa120.3 with scythe s-flex "e"
*built for silence
Aldy402 is offline   Reply With Quote
Old 03-13-2007, 07:40 PM   #8
erwinz
Originally Posted by andre X_X View Post
this is my test
hey man.. im going to get this rams.. what is your highest ram clocks that is orthos stable..
__________________
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800 , E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
Ati FireGL V5100, Elsa FireGL V3100
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
Silverstone OP650
raptors, baracuda
erwinz is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
