XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Bandwidth
Reply
Old 03-07-2007, 09:56 PM   #1
luihed
Overkill
luihed's Avatar
Testing my cheap rams... Im kinda speechless
I have a set of Ballistix pc5400 but after a month, its doing the 1.8v no boot issue so I had to RMA them.... In the meantime I borrowed these rams from my local store to tie me up for now..... These rams are Kingston unmatched PC5400 Cas5, same rams the store uses for thier ready built systems....
As expected, these are nowhere close to my Ballistix, what I didnt expect though are the numbers I got from them.... here goes, all test @ 2.4v
Memtest.....
Superpi 32M
Some 3-3-3 action.... not too bad...
And then 5-5-5-15.... what these rams are rated at
24/7 I run my ballistix at 4-4-4-6 @ 420fsb, Ive had these modules run with my D9s at the same speed but at 4-4-4-12 instead.... I ended up buying these cos 1, there cheap and secondly if ever I get the 1.8v syndrome again, I have these to get to the bios..... Im very curious though on how these cheeapies compare to non-D9 midrange performance rams.....
__________________
E8400 DFI LP P35T2R Ballistix
8800GTS PCP&C 1.2kw Raptors
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
luihed is offline   Reply With Quote
Old 03-07-2007, 10:08 PM   #2
technodanvan
technodanvan's Avatar
They don't look bad at all - honestly I really feel blowing $250+ isn't necessary for people that don't run benchmarks for a living.
That said, I still have my $450 Redlines and $300 HZ's....
*sigh*
That worst thing about that is they don't gain me anything - I play with them a little bit but then just go back to my normal routine of dicking around online, doing stuff for class, and playing games. They net me nothing at all.
Wanna trade?
__________________
DFI Lanparty NF590 SLi M2R/G
AMD 3800+ X2 Windsor @ 250x10 1.375v w/ stock fan (for the moment)
2x1GB Mushkin Redline @ DDR2-1000 4-4-4-5 2T 2.3v
Evga 7900GTO @ stock
Evga 7100GS @ stock
Auzentech X-Plosion
2x Hitachi 80GB RAID 0
320GB WD storage drive
Corsair HX520 Power Supply
technodanvan is offline   Reply With Quote
Old 03-07-2007, 10:22 PM   #3
luihed
Overkill
luihed's Avatar
You must be joking about trading cos these are $90 sticks lol....
Im happy with what I have right now cos if I need to do some benching I can run my D9s... 24/7 I run all 4..... 420x9 at 4-4-4-12 should be more than what I need....
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 03-08-2007, 11:44 AM   #4
ineedaname
ineedaname's Avatar
This has already been covered here.
Your ram seems to do a better than mine at 5-5-5 tho.
__________________
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
ineedaname is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
