XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Operating Systems > Microsoft Windows
Reply
Old 03-06-2007, 08:58 PM   #1
DangerIsGo
DangerIsGo's Avatar
vista and resizing partitions
Ok so I got vista and wanted to play around with it, so i installed it on a 15gb partition (wasnt gonna do much with it) but i realized that 15GB is too small. heh. My 160GB drive is like this
80GB - XP
15GB - Vista
60GB - important/non-raided storage
What I wanna do is add another 5-10 GB from the important storage that isnt being used. I tried the vista disk manager and tried to shrink the non-raided storage (its a Basic drive) but it keeps giving me an error saying to check the system event log for more information on the unexpected error. I dont know what to do? Does anyone know any partition managers that work with vista? Partitionmagic 8.05 from symantec doesnt, it sees my drive as BAD. Any others?
__________________
Upgrade in progress....
DangerIsGo is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
