Hey guys I decided to fill an hour with testing of X23-7762....
I'll let the burn in happen (we'll see if that makes a difference) but Ill share some preliminary results.
I have had AS5 on the cpu (size of a rice grain method) for one full week and during tonights testing period it was yielding idles (core temp for all measurements) of
34c and loads of
62c (Orthos small ftt, priority 9, for 3 minutes.)
With a fresh application of x23-7762 I was getting an idle of
31c and the same load test of
65c.
Ambient was 19c for both tests under a Thermalright Si-120 (non mirror lapping) with a medium panaflo sitting at 1000rpm, 1.4v applied to the CPU (yes I have vdroop on this board,) e6400 CPU Freq. 490x7 (3430Mhz), case side panel removed for both tests...
Application was ok. 7762 is much less dense than As5 but I got a good application down I think... we'll let this burn in, see if it makes any difference and then I'll move onto G751 or another application 7762 (btw, i have found no documentation describing how ShinEtsu thinks their TIM's should be applied on cpus.)
Pics:
AS5 - Orthos load for 3 minutes
http://i144.photobucket.com/albums/r...thosSmall_.jpg
x23-7762 - Orthos load for 3 minutes
http://i144.photobucket.com/albums/r...rthosSmall.jpg
Test conditions (w 19c ambient)
http://i144.photobucket.com/albums/r...e/P3050092.jpg
7762 Application (Note: After I shot this picture I thought there was just the tinyest bit too much so I paired it down a bit)
http://s144.photobucket.com/albums/r...t=P3050091.jpg
