03-02-2007, 03:24 PM
#1
Is it WORTH it to buy an 88GTX now?
Right, so I've finally got my PC-7 modded with my rad in the top. I've got my 205bw hooked up to my lappy at the moment, and all I need are the system components.
But I can't buy it yet because I don't know if I should get the 88GTX now... it seems that on the very rapidly approching horizon there are better cards that might just be worth waiting for.
If you were in my shoes, would you purchase NOW or get a hold-me-over to see what the near future brings?
Thanks.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
03-02-2007, 03:48 PM
#2
no, no point at all when R600 is around teh corner which will bring down the prices of 8800 series anyway... and then nvidia might (very big might) release an 8900 series.
__________________
Core 2 Duo E6600 @ 3.2Ghz (400Mhzx8) 1.52V (set in bios, 1.47v after droop)- worst C2D ever | 4GB GeIL PC6400 4-4-4-12 @ 800Mhz 4-4-4-12 | Gigabyte DQ6 @ 1600Mhz | Sapphire 1024MB HD2900XT @ 858/1153 | Enermax Infiniti 650W | Silverstone TJ07-B with custom watercooling (CPU/MOBO/GPU) | Vista Ultimate x64 | BenQ FP241WZ
eXceed TJ07 worklog/build
03-02-2007, 05:05 PM
#3
So you reckon I should get a hold-me-over for the time being, something small and useful as a backup.
I've been seriously considering that option for a while now, actually.
__________________
03-02-2007, 05:17 PM
#4
If I was you I would spend as little amount of money as possible until at least April, when Nvidia will be releasing its mid and low range models. If you wait you'll be the winner in the longrun (cheaper 8800 series if it's rival - R600 - doesn't perform, and a possible refresh!)
__________________
03-02-2007, 05:25 PM
#5
Not to mention Core 2 price cuts on April 22.
Perhaps I will wait.
__________________
03-02-2007, 05:40 PM
#6
With R600 no where in sight I would say get a low end 8800 320mb and camp out for the R600
__________________
"WW3 will be fought with nukes, WW4 will be fought with rocks!":
03-02-2007, 05:51 PM
#7
That's an idea I've been contemplating for a while as well.
__________________
03-02-2007, 05:53 PM
#8
Perpetually learning
I've made the same choice and I'm waiting on the face off between R600 and 8900. This point in time is too close to the next gen and price moderations.
imo
03-02-2007, 06:01 PM
#9
you can also get a new 8800gtx for $520 then step up
__________________
i7 860/True 120
GA P55 UD6/4gb Ripjaws
HD5850/Benq G2400WD
XFI Titanium/beyer dt770 pros
Klipsch PM 2.1/WD 640 Black
Corsair 750/HAF 932
HEAT
03-03-2007, 03:44 AM
#10
Banned
i'm surprised you asked that and its your own choice
03-03-2007, 06:35 AM
#11
^ Uh, I know it's my own choice but I was looking for the opinions of others. That is why I posted this thread.
Rattle: Live in HK. No EVGA step up for me
__________________
03-03-2007, 07:19 AM
#12
Xtreme Cruncher
Nah I wouldnt go for a GTX now. Get something mid-range and then step up to the 8900 series; like a GTS 320/640.
Edit: I didnt notice you are in HK, I guess your best chance might be to just wait it out at least till April..
__________________
For all your cooling needs: ShopPTS.com
System:
Rampage Formula // E8400 @ 4.0 (1.28v)
4x 1GB Ballistix Tracer @ 600 (5-5-5-15)
4x 74GB Raptors 16MB Raid-0 // Samsung F1 1TB
eVGA 8800GTS 512MB @ 800/1111/2000
Corsair HX620 // LG246WP
Cooling:
D-TEK FuZion // PA120.3 // 3x Yate Loon SH
MCW60GT // EK Multi-150 // DDC-2 + Petra's Top
03-03-2007, 07:45 AM
#13
I would get the Zotac 8800 GTS 320 which is there locally  its about $480 (Sg $) in singapore should be the same in HK thats your best bet for now
__________________
03-03-2007, 10:35 AM
#14
3dMark Isn't Everything
Hell yes it's worth it, ive just installed mine, upgrade from a X1800XT 512mb, and iam amazed at the performance increase.
eXceededgoku R600 is right around the corner? It's 2-3 months away at least, who says we won't see another delay. I was waiting for it, but i couldn't be arsed to wait any longer.
You could always get the EvGA one and then use the step up program, if 8900 comes out. You can always ebay the 8800 if the new cards really are that much better, but i can't see it myself.
You won't be disapointed with a 8800GTX thats for sure!
__________________
Kentsfield Q6600@ 3100Mhz
Asus P5B-E Plus
2GB GSkill DDRII PC6400GBHZ
Albatron Geforce 8800GTX
Silverstone Temjin TJ-09
Thermalright Ultra 120
Corsair 620W HX
74GB Raptor/ X-Fi Platinum
19" CRT NEC 930 SB
Windows XP Pro SP2
03-03-2007, 12:10 PM
#15
Banned
you won't be dissapointed fore beeing an nvidia fan as well because ati is bad
03-03-2007, 12:16 PM
#16
the 8900 gts is only gonna be 128 bit, if thats true then its garbage you'd be better off with a 8800 320 gts only reason to wait would be for any price drops.
__________________
i7 860/True 120
HD5850/Benq G2400WD
Corsair 750/HAF 932
HEAT
03-03-2007, 12:22 PM
#17
BLAH!!!!!!!!!!!
pM me I can sell you a IHSLESS 8800 GTS ;-P.
__________________
Mammal brains are rather like the engines in American performance cars. We tend to use cubic inches to compensate for the lack of precision engineering.
Movieman's alter ego ---------> SUPER MOD NOOB ADMIN!
Originally Posted by nn_step
(A Professor to a class of students)
"If you put the sand into the jar first," he continued "there is no room for the pebbles or the rocks. The same goes for your life.
Take care of the rocks first - the things that really matter. Set your priorities. The rest is just sand."
Originally Posted by Omastar
Those chubby chicks can be amazing in the sack sometimes, you know.  (waits to be sigged)
03-03-2007, 03:53 PM
#18
We don't have Zotac here.
I guess I could just get the 320 MB version and see how that lasts me. Not a bad idea really.
EDIT: Phelan, why are you selling your GTS' anyways?
__________________
03-03-2007, 03:55 PM
#19
BLAH!!!!!!!!!!!
Cause I have two, and really don't need SLI and I could seriously used the money.
__________________
03-04-2007, 03:54 AM
#20
For crying out loud man, stop your dribble.
__________________
Asus P5B-E Plus
Corsair 620W HX
19" CRT NEC 930 SB
Windows XP Pro SP2
03-04-2007, 07:51 AM
#21
i'm gonna try to wait ti out. i'm hoping it will be released sometime in april.
03-04-2007, 08:33 AM
#22
Just deleted over 900 PMs
No kidding, I've had far-more problems with Nvidia's drivers than I ever did with ATI.
__________________
Desktop:
NZXT Zero
Central Processing: ABIT IP35 Pro / Core 2 Duo E6850 @ 3.6Ghz / 4GB G.Skill F2-8000CL5D-4GBPQ
Cooling Station: Enzotech Ultra-X / Sharkoon Silent Eagle 120mm / Modded IP35 Pro Heatsink System
Storage Subsystem: WD Raptor 150GB / WD Caviar 640GB / WD GP 1TB / Samsung 18x DVD-R/RW
Networking Department: D-Link DIR-655 / Realtek Gigabit NIC
Visual Processing and Display: EVGA GTX 260 896MB Superclocked / BenQ 24" 1920x1200 LCD
Tonal Processing and Delivery: Auzentech X-Fi Prelude / Onkyo TX-SR304 / Athena S.5 5.1 / Velodyne VX-10
Peripheral Input: Razer Deathadder / Logitech LX710 / Steelseries 5L
Power Delivery: Corsair 620HX / APC BX1300LCD UPS
Midnight Blue Dell Inspiron 1720
Core 2 Duo T7500 @ 2.2Ghz
4GB PQI PC6400
NVIDIA 8600M GT 256MB @ 625/1250/1024
WD Scorpio 250GB (5,400RPM)
17" 1920x1200 LCD
< Nikon D300 >
03-04-2007, 08:41 AM
#23
lol soul  that retarded card of yours that wont run all the resolutions  I think you need to rma it
__________________
03-04-2007, 03:42 PM
#24
I'm waiting for this reason (getting a E6700 or a xeon 3070 with much higher overclock potential than 6600).
I'm not sure when nvidia will release the 8900. Ati R600 is delayed until may and looks like a power hungry of unprecedented proportions  But if it really comes out in may, then nvidia will release the 8900 GTX in may as well.
So, if u are not going to SLI, I would get the 8800 GTX now. If you are thight on budget wait end of april/may.
__________________
Gaming Rig:
| CPU: Xeon E3110 Q807 @4GHz | Cooling: TRUE with Scythe Ultra Kaze 3000
| Motherboard: Asus Rampage Formula | RAM: 4GB G.Skill F2_9600CL5D_4GBPI | Video: Asus GTX 280
| Storage: Controller: LSI Megaraid 320-2E 128MB | 3x Fujitsu MAU 146 GB 15k raid0 + Samsung F1 1TB + 2x WD GP 1TB
| Audio: Creative SB X-Fi Xtreme Fatal1ty Pro | Sennheiser HD595 hearphones
| Case: Lian-Li PC 78 | | PSU: Silverstone Zeus 750W | Display: Samsung 2693HM 25,5" LCD
| OS: Vista x64 / Windows7 x64 b7000 (testing)
Music Rig:
| Dual Xeon with Reveal 5A active monitors
AC powered through APC Smart-UPS 1500 and APC PowerSurge
03-04-2007, 05:17 PM
#25
I'm talking now, and in the past (years ago), cumulatively.
The card runs fine, its the drivers that don't play nice.
__________________
Desktop:
NZXT Zero
4GB PQI PC6400
17" 1920x1200 LCD
< Nikon D300 >
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
