XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 02-27-2007, 06:09 PM   #1
vega22
Scythe Infinity...Bad Axe 2...hummmm...
I have installed a Infinity in my new Bad Axe 2. Temperatures ok. Nevertheless, the dissipator has a base that excels some cms of the socket, and is upon a line of capacitors. The distance over the capacitors until this base has only the thickness of a sheet of paper.
Is this correct or I must worry? Is better to change by another heatsink more safe -I.E. Thermalright ultra 120-? Thanks!
vega22 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
