02-25-2007, 06:34 PM
#1
Diablo 3! Who's Excited?
Source of Condensers
I'm sure a thousand of people have asked this before and a thousand will ask it after me.. does anyone know of a stable source of condensers for our sized applications? I've googled/ebayed my heart out and I can't find anything, I either get condenser fan motors or I get airconditioning condensers or specialized automotive condensers that are either too large or overpriced. I think Under-the-ice used to sell small condensers but now all I can find are the shrouds. Any help would be great, I would hate to have to purchase a dehumidifier just to rip it to shreds everytime I want to build a system
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
02-25-2007, 06:40 PM
#2
-100C Club Member
chillys partner just got 600, i think he might have some spares, check out his thread in this section
02-25-2007, 06:54 PM
#3
I am Xtreme
www.under-the-ice.com
Run by runmc himself. I think he'll be selling Chilly1 style condensers soon?
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
02-25-2007, 06:59 PM
#4
Originally Posted by n00b 0f l337
I specified that I checked UTI and it doesn't sell condensers unless they are hidden or via email only. Who is Chilly's partner and what is his contact info if anyone has it?
__________________
02-25-2007, 07:12 PM
#5
I am Xtreme
I think they'll be coming up soon.
__________________
NoL: gom gom gom
02-25-2007, 07:17 PM
#6
bah, I need right quick not soon  Just sent chilly1 a pm, hopefully that'll yield results.
__________________
02-25-2007, 07:20 PM
#7
I am Xtreme
Or pm runmc himself
__________________
NoL: gom gom gom
02-25-2007, 07:26 PM
#8
Good point, done
__________________
02-25-2007, 09:57 PM
#9
HVAC/R Engineer
Send me your email address and I will copy you in when we get the site up.. Due to the demand for parts We will be selling the condensers and other parts to XS members starting on tuesday.. so PM me for orders... and Runmc will also have them at under the ice..
02-25-2007, 10:07 PM
#10
HVAC/R Engineer
single stage condenser next to the cascade condenser good to about 1.5 Hp
02-26-2007, 05:21 AM
#11
I am Xtreme
Dayum, all blue?
__________________
NoL: gom gom gom
02-26-2007, 05:48 AM
#12
hey Chilly1, do you make those blue covers/fan holders around those condensers?
looks like they are just rivited together? so you could take them apart and paint them easily im sure...
__________________
Current System Build
Designaton: " Rad Hat "
__________________ - Mother Board, RAM and CPU:
Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
- Graphics Processor:
GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
- Hard Drives:
RAID: 2x 74GB Raptors on RAID 0 for OS Drives
- Case and Power Supply:
Case: Antec Case | PS: OCZ ProXstreame 1000W
- Water Cooling:
Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
- (Water Blocks and Fittings):
CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
Last Updated 11/11/09
02-26-2007, 06:07 AM
#13
I am Xtreme
Whats the fin density on those smaller condensers, how many rows? Dimensions?
Tube size?
Need a bit more info chilly1.
__________________
NoL: gom gom gom
02-26-2007, 06:20 AM
#14
__________________
02-26-2007, 06:30 AM
#15
I am Xtreme
K, is the tubing rifled?
Still got some questions as to BTU capacity.
Can't wait for your store reggie.
__________________
NoL: gom gom gom
02-26-2007, 07:37 AM
#16
www.kaeltetechnik-shop.at
There is a English botton...
__________________
Originally Posted by Xeon th MG Pony
....and avoid being a total venting loser!
02-26-2007, 09:39 AM
#17
Bah wtf, gotta create an account to view the prices? Think I'll stick to the US shops though, thanks for the link
__________________
02-26-2007, 02:43 PM
#18
http://hvac-talk.com/vbb/showthread.php?t=131172
I'm hoping that somebody has an easy solution to my problem/question. In the past the condensers that I have used were either purchased on ebay or stripped from donor dehumidifiers. The systems I build are based around 1/3 to 1/2 hp compressors and move 150 to 250 watts of heat with evap temperatures peaking around -30 celsius at full load with the condenser's under ~180 psi. I'm in search of a source of small condensers that are roughly 1 foot by 1 foot by 5 inches or so. I've contacted condenser fabricators and the prices were outrageous, does anyone know of a place to purchase such condensers? Sadly none of the condensers I've used have model numbers stamped into them so I can't order them as replacement parts. Thanks for any help, it's most frustrating trying to find parts for anything smaller than a 1 ton system.
ps- these systems are used to cool computer processors and graphics cards for those that are curious. There are various commercial systems available but I'm part of the small group of builders that build these things as a hobby.
contact a refrigeration company in your area, i scrap condensers that size all the time.
__________________
Originally Posted by A HVAC friend of mine
If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her evaporator coils.
02-26-2007, 04:24 PM
#19
psssst..
"Guess I'll start making some calls, thanks for the heads up."
But thanks for reminding me again
__________________
03-20-2007, 10:17 PM
#20
I am Xtreme
Chilly1 can you confirm Daniel Blasco is your partner and will be accepting money on your behalf???? @ danielblasco@msn.com
Not implying anything just a prudent question that needs confirmed by chilly1.Since he did not mention this in any previous post that I seen.
Thanks and take care chilly.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????  I forgot "you must"
03-20-2007, 11:10 PM
#21
Can I be the spelling police? On topic, any ETA on when the website will be up and what the URL will be? Glad to hear that the ball is rolling on this, will be nice to have a source of larger condensors.
__________________
03-21-2007, 04:44 AM
#22
I am Xtreme
Ive PM'd Daniel asking, per normal forum policy, for pictures of his products with his username and the date.
__________________
NoL: gom gom gom
03-21-2007, 05:07 AM
#23
I recived a Mail from Chilly saying that he has not been well and things where not going to be avalible for a few months, but Daniel BLasco is saying its ready now, i for one would like this cleard up once and for all, if the items are for sale please list the web site, and if they are not please could you let us all know when things will be ready.
__________________
03-21-2007, 06:04 AM
#24
I am Xtreme
noob you can pm daneil all you want, there needs to be a post by chilly or Fugger that daniel can accept money on chilly's behalf.
I just brought this to admin. attention, and Its not forum policy for you or me to do more than I did. the ok MUST come from XS administration. which neither us or even the mods are.
by the way when is that pallet of danfoss compressors comming in???? are you selling any???
__________________
Register today .
03-21-2007, 06:26 AM
#25
I am Xtreme
PS: noob 1337 micheil only has 17 post so unless admin. gives him special access he can't even post in for sale section per forum rules.
Let Admin. handle this and let the official word come from them.
__________________
Register today .
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
