I get a 10mm thick piece of neoprene that extends about 8 centimeters out from the center of the backside of the socket and then lightly coat the neoprene in dielectric grease. When mounting this in a case, simply press the neoprene against the motherboard and then squish the board down so that it forms a tight seal against the motherboard tray. If you have condensation issues on the backside of the board after that then you'll want to invest in some heating elements and more neoprene. The grease is easy to remove with a little elbow grease and a tooth brush, just a thin layer on the neoprene will do.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
