XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 02-18-2007, 03:58 AM   #1
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
Temperature protection for dummyload ?
Hi
I'm bit frustrated, I've just burned my dummyload second time (215W) . I forgot to plug it off from socket after turning down unit and some minutes after I saw only a lot of smoke in mine room . Enclosure from evap melts in half and after 10 minutes kprobe on evap was showing more than 170*C ..but it's all reparaible .
But... I don't want to make that again ...guys please write here how to make a protection for 230V dummyload ? Eg. Turn dummy off when temperature is over +50*C .
Now I plan to make around 230W new dummyload, because one or three resistors in mine just killed 215W dummy broke down . So I'll buy new resistiors, for little stronger dummy.
Regards
Peter
piotres is offline   Reply With Quote
Old 02-18-2007, 04:08 AM   #2
K404
Xtreme Mentor
K404's Avatar
Do you have any thermostats around? You could hook a temp probe up and also run the dummy through it and set it to kill the circuit and whatever temperature you like
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M View Post
Originally Posted by soundood View Post
you sigged that?
why?
K404 is online now   Reply With Quote
Old 02-18-2007, 07:01 AM   #3
harvshark
How about a simple HVAC snap disk tstat like these? They come in different temp ranges. Use a 'open on rise' type wired in series with your power input and they will open the circuit and shut the dummy load off when it gets too hot, automatically turning back on when it cools off. You probably all deal with HVAC suppliers that have these things.
http://www.grainger.com/Grainger/wwg...ed=Snap-Action
EDIT.....
Ooops, that link doesn't quite work.....type 'snap disk' in the right hand search blank at the top of the page.
harvshark is offline   Reply With Quote
Old 02-18-2007, 08:25 AM   #4
DetroitAC
DetroitAC's Avatar
I was thinking the same thing as harvshark. Snap disc thermostat is very reliable and very cheap, can just be wired in series to the heater.
__________________
Heatware
Two weeks in the lab will save you half an hour in the library
DetroitAC is offline   Reply With Quote
Old 02-20-2007, 01:54 AM   #5
Dimas
Dimas's Avatar
Send a message via MSN to Dimas
a NTC/PTC thermostat can do the trick, cut off heater after 30°C...
__________________
DIMASTECH Official Support
Extreme Cooling BLOG
BENCH TABLES REV2.5 LINK
Dimas is offline   Reply With Quote
Old 02-20-2007, 02:15 AM   #6
wdrzal
I am Xtreme
wdrzal's Avatar
Agreed, they are cheap
you can also just wire the dummy load to same circuit after the on/off switch as compressor,as 200 watt dummy @ 120v is less than 2 amps,plus compressor you should not overload circuit. when compressor is off dummy load is off.,unless you have massive mass on dummy load the residual cooling should cool dummy load down, when load and compressor are shut off together. I do believe in limit switches,they make the system (dummy proof) It's a normal practice to protect all circuits from overloading/heating in some way.
__________________
http://xtremespeakfreely.com/forum/
Register today .
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
wdrzal is offline   Reply With Quote
Old 02-20-2007, 02:49 AM   #7
johann
johann's Avatar
I use a simple thermal cut off switch, it cuts the circuit at around 60c and only cost about $1
__________________
My Phase change builds thread
johann is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
