Lian Li V2000B Plus II - oppinions?
I want to upgrade my case. I currently own the CM Stacker 830. The case is FULL, lots of cables inside, also, the water cooling setup. Due to the PCI-e rails going into the video cards I cannot close the door with the 4x120mm fans. Therefore I run without it and my system runs hot.
I was looking at Lian Li V2000B Plus II case. It looks sweet, has lots of space, I can move the PSU and my 4 HDD's in the bottom section and lose alot of wires. That would improve airflow.
What do you think? What's the better option for me? Stay with the Stacker 830 or go with the V2000B? Which is the better of the 2 considering you have many components to cool? I know the Stacker 830 is great, for air cooling, but it handled the situation well until I got the 1100W Tagan PSU and needed to remove the 4 fans.
Do you think the extra space in the V2000B will help the components stay cooler?
