XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 02-16-2007, 09:51 AM   #1
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
Cool How hot do step4 c2ds run?
Just moved from phase change to air on my 6700es step 4 conroe and I am pretty pissedoff at temps. The cpu is lapped to mirror finish and looks flawlessly flat to me. Using a skythe infinity and its crappy stock mounting system I get 52C on idle and 75 on load accoridng to core temp??? This is at 3.5ghz @ 1.425 volts (bios) 1.41 real voltmeter reading under load. I remounted it 3 times with the same results and each time I saw that the contact was perfect...
Right now I am thinking the ihs isnt attached properly but thats sort of bs since the idle temps would still be decent in that case. I was also getting a decent differencial between evap and cpu temps when using phase. Got 4ghz stable at 1.55 volts before. Chip has never seen positive temps. Stock clock air cooling temps are about 5c lower then oc on idle and load. TAT shows similar temps to coretemp. The mobo sensor is the most ridiculously wrong thing I have ever seen, shws like 9c under udle rofl. Ambient is about 15C. Any ideas?
One_Hertz is offline   Reply With Quote
Old 02-16-2007, 10:17 AM   #2
Toferman
I'm curious about this too, actually. Mine seems to be doing the same thing (sig). Anything above 1.40 VID, and It jumps to 60'C idle.
Toferman is offline   Reply With Quote
Old 02-16-2007, 10:21 AM   #3
One_Hertz
One_Hertz's Avatar
hmm never tried below 1.4 vid. Will do when I get home.
Old 02-16-2007, 01:05 PM   #4
HamidFULL
Send a message via MSN to HamidFULL Send a message via Yahoo to HamidFULL Send a message via Skype™ to HamidFULL
some C2D with step 4 and 5 have load problem
__________________
www.HotOverclock.com Founder & Editor in Chief
Upgrading to X58 ...
Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
abit IX38 QuadGT Rev1.0 (X38 Rev.01)
4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
HDD 120GB Maxtor Max.10 6L120M0
PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
HamidFULL is offline   Reply With Quote
Old 02-16-2007, 01:51 PM   #5
ziddey
Send a message via AIM to ziddey
Hmm, under the same conditions, with my step5 (b1), coretemp seems to be pretty on par with a step6 b2 under the same conditions. Nice touch about peci. I didn't know what it was. Guess it's time to enable that in bios
edit: what kind of reading is peci supposed to give. I noticed with this p5b that with peci off, the cpu temp was reading higher than coretemp by about 10'c. Now with peci enabled, it's about 10'c lower than coretemp.
__________________
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
ziddey is offline   Reply With Quote
Old 02-16-2007, 05:31 PM   #6
smsmasters
smsmasters's Avatar
With my e6600 step 6 b2, at 2.4ghz default it idles 24C, 45C load
At 3.2ghz 1.3V, idles 33C, load 53C
At 3.6ghz 1.45V, idles 40C, load 60+
At 1.5V idles 45C+, load 70C+
This is with an arctic cooling freezer 7 pro.
smsmasters is offline   Reply With Quote
Old 02-16-2007, 06:17 PM   #7
ziddey
That's really impressive with the ac freezer. Perhaps you have a pretty cool chip too. With my e6400 6b2 l630a, I got:
stock 2.13: idle 35 load 45
3.2 1.3v: idle 35 load 58 (c1e enabled, which explains better idle)
3.6 1.45v: idle 52 load 72
1.5v: idle 58 load 80
Those results were with a lapped ihs as well.
Got rid of the ac freezer when I got my b1.
Sorry to bring this topic ot op.
OP: How does the distribution of thermal paste look when you remove the heatsink? Maybe the base of the hsf is a little off?
__________________
Old 02-16-2007, 06:36 PM   #8
smsmasters
smsmasters's Avatar
My e6600 is "L632B086".
When I take off the heatsink, the paste looks thinly evenly distributed.
Old 02-16-2007, 10:13 PM   #9
One_Hertz
One_Hertz's Avatar
paste distribution is flawless. Lowered the voltage to 1.38 (real) and saw a 3c drop in temps. Also lost 100 mhz oc so not happy at all :/. Nothing too disproportional here. I am thinking maybe the heatpipes are dead at this point.
Old 02-17-2007, 08:42 AM   #10
Revv23
I am Xtreme
Revv23's Avatar
Send a message via AIM to Revv23
is it stable at those temps? if so why worry?
Revv23 is offline   Reply With Quote
Old 02-17-2007, 05:34 PM   #11
One_Hertz
One_Hertz's Avatar
yep, still would like to show you guys this awesome screenshot. 0% cpu usage at that time as well. I love ES stuff. The asus probe thing shows some temps if the cpu isn't at 1.6 but they are still rather low.
funny thing, the idle temp is only 2C higher if I put the cpu at 3.5 @ 1.41 volts vs the current 1.6ghz and 0.8ish volts.
So there is NO way I could see my cpu temp at this point?
Old 02-17-2007, 07:14 PM   #12
ziddey
lol nice temps have you tried turning peci on/off?
__________________
Old 02-17-2007, 08:11 PM   #13
One_Hertz
One_Hertz's Avatar
no such option in this bios. Bios 0078 is the only one that works with step4 chips that I am aware of. P5W DH deluxe is the mobo.
EDIT: Aha! Speedfan seems perfectly correct. Shows 20-21C on idle when cpu is at 1,6ghz and 0.8 volts, which seems perfectly spot on considering the ambient is 19 and cpu takes like what, sub 5 watts in this mode? Orthos small ftt load temp when at 3.5ghz and 1.4 volts is 49C. Also found out that coretemp/tat are always exactly 29-31 degrees higher then speedfan no matter what state the cpu is in. Thank god thats over.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
