XtremeSystems Forums
Go Back   XtremeSystems Forums > Gaming > PC Gaming
Reply
Old 02-12-2007, 05:38 PM   #1
Judaeus Apella
Judaeus Apella's Avatar
Send a message via ICQ to Judaeus Apella Send a message via AIM to Judaeus Apella Send a message via MSN to Judaeus Apella Send a message via Yahoo to Judaeus Apella
Numberpad-Like Gamepad For PCs? Ever see one?
I've always used the numberpad when playing any game, but I have to slide the keyboard to the left so I can do it without bending my left hand to the right near the mouse. I hate having to play this way. Isn't there a game control pad or a number pad that’s nearly identical to the way a numberpad is organized? By this I mean a straight line of 5 buttons or more long (up and down) and 4 or more buttons across, but with more buttons for gaming.
I compared a picture of the Wolfking gaming keyboard pad to the number pad on a standard keyboard and noticed some differences that I know I'd totally hate. Good idea on their part though... but those long keyes in the middle kinda screw it up by leaving out three important keys as a result. (The ones I use for strafe left, strafe right, and reverse)
The way I usually have it set up:
0 - Duck
Del - Toggle run/fast walk
1 - Strafe left
2 - Reverse/backwards
3 - Strafe right
4 - Lean left
5 - Forward (default speed)
6 - Lean right
7 - Toggle creep/slow walk
8 - Jump
9 - Special function
/ - Use/Interact
* - Flashlight
- - Drop/release/throw down weapon/object
+ - Change fire setting
Enter - Prone
Then I also use the arrow keys, and the Insert, Home, PgUP, Delete, End, and PGDN keys for other things like going into the menu, using tools, special equipment, grenades, etc.
The Wolfking would have been perfect if they hadn't cut out those 3 keys I need. I was just about to order it when I noticed the problem too.
I actually did see an assignable keybad that looked almost exactly like a numberpad with no lables on the buttons. It looked like clearish wite plastic I think. It might have been lighted. I don't remember. I would love to find that product!
Can anyone help me out with finding a gamepad like anything I've mentioned?
Edit: I would LOVE to have something like this:
But there's no way I'm paying $200!! Where do they get off!?
http://salestores.com/genova09.html
__________________
Reality is merely an illusion, albeit a very persistent one. - Albert Einstein
True wisdom is the ability to see past the limitations of knowledge. Insanity is knowing too much, and sanity is knowing too much about nothing important.
Judaeus Apella is offline   Reply With Quote
Old 02-12-2007, 06:09 PM   #2
pissboy
not sure if you want something like this, but its cheap at $7.99
http://www.newegg.com/Product/Produc...82E16823205010
Also look for CAD keypads, they usually are programmable or you can set each key to do different keystrokes/key combos/etc.
http://biz.tigerdirect.com/applicati...2664&CatId=536
http://biz.tigerdirect.com/applicati...2660&CatId=536
This might ultimately be what you want though:
http://www.cyberguys.com/templates/s...792&sk=MC51419
pissboy is offline   Reply With Quote
Old 02-12-2007, 08:46 PM   #3
Judaeus Apella
That first one doesn't have enough keys, second is WAY out of my price range, 3rd is the same thing as 1 but costs several times more, and the 4th link is broken. Thanks though. I didn't know to look for a CAD keypad. That should help me find something.
__________________
Old 02-13-2007, 08:00 AM   #4
DaveMcGee
I have tried the following and like them . Keeps my desktop tidy (slide under kboard)
Belkin nostromo n52
http://www.raven.com.ar/files/thumb/n52-nostromo.jpg
saitek game commander
http://www.saitekusa.com/images/300dpi/key/Cpad.jpg
Havent tried...
http://lib.store.yahoo.net/lib/xoxid...rior-blk-2.jpg
http://www.komplett.no/img/p/400/322782.jpg
dave
DaveMcGee is offline   Reply With Quote
Old 02-13-2007, 01:20 PM   #5
pissboy
4th was something called "wolfking warrior game pad"
http://froogle.google.com/froogle?q=...oogle&ct=title
couple of links there
Old 02-13-2007, 01:23 PM   #6
Judaeus Apella
LOL, read my first post.
__________________
Old 02-13-2007, 01:31 PM   #7
p0tter
p0tter's Avatar
Found this looking for keypads.. rofl
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline   Reply With Quote
Old 02-13-2007, 01:39 PM   #8
2fink
Xtreme Cruncher
2fink's Avatar
Send a message via ICQ to 2fink
wouldnt be something like this okay for your needs?
__________________
E2160 @ 360x9, max 390x9 watercooled
GA-P35-DS3
Cellshock D9GMH @ 545mhz cl5-5-5-5-15
Palit 7300gt 500/1000 @ 780/1600 watercooled
2fink is offline   Reply With Quote
Old 02-13-2007, 02:40 PM   #9
Judaeus Apella
0 - Duck
1 - Strafe left
3 - Strafe right
4 - Lean left
6 - Lean right
8 - Jump
/ - Use/Interact
* - Flashlight
Enter - Prone
Please read the first post.
__________________
Old 02-13-2007, 03:02 PM   #10
DaveMcGee
Not sure what u r on about??
But given that the pads I mentioned are programmable it doesn't really matter what keys they emulate. The n52 has 17 keys and a dpad which is ideal for menu nav. Cant think of many games where you need more, and if u do it has 3 shift states.
Alternatively use wasd, u then have easy reach to 80 odd keys or more
Old 02-13-2007, 04:17 PM   #11
Judaeus Apella
If Im using my mouse with my right, and the controller with my self.. how am I going to use shift states? Also "By this I mean a straight line of 5 buttons or more long (up and down) and 4 or more buttons across, but with more buttons for gaming."
I don't mean to be rude, and I know you guys are trying to help, but I think Pissboy may have been the only person who actually read my post.... and he still posted the one controller I said I didn't like. LOL Did the rest of you just read the title, and post something without reading the actual post?
If you want to help someone who posts a question, read all the way through their post... otherwise people just spam that person with useless information.
__________________
Old 02-13-2007, 05:10 PM   #12
chunkylover77
XS News
chunkylover77's Avatar
Send a message via MSN to chunkylover77
Doesn't the saitek come with something like what you are looking for? Let me have a look.
Nope only comes with 9buttons total.
__________________
RIP Dad. I will miss you always.
Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
chunkylover77 is offline   Reply With Quote
Old 02-13-2007, 05:59 PM   #13
Judaeus Apella
Yeah, I know. Its really difficult to find something like this. Also those controller pads with the flat shaped rubber buttons are trash. The best ones have the traditional plastic keys.
But what really confuses me is how are users of these gaming keypads, playing games with half the keys missing? There's probably twice as many critical functions you have to use in most games than any of these keypads support... what a waste of money. And those axis keypads suck for gaming... thats the whole reason I got into PC gaming years ago. The only decent gaming keypad is that WolfKing, but like I said they cut out a row of buttons I need.... which was a real let down. I was really excited when I found that keypad.
__________________
Old 02-14-2007, 12:56 AM   #14
DaveMcGee
Unfortunately you come accross as very rude and very unclear you say ""By this I mean a straight line of 5 buttons or more long (up and down) and 4 or more buttons across, but with more buttons for gaming."" Which reads like something from an Edward Lear Poem.
As far as using shift states go's it is blatantly obvious from your reply that you have no idea what this means, so don't try and be sarcastic.
I did read through your posts, it is a bit of a struggle due to the lack of clarity.
Old 02-14-2007, 03:14 AM   #15
pissboy
I cant think of the name off the top of my head but there was a company that made custom keypads where you could move the buttons/etc.. keys were normal keycaps..
Old 02-14-2007, 03:26 AM   #16
Amplified
Amplified's Avatar
Just wondering, why don't you just used WASD keys etc? That is what most people use afaik...
__________________
Amplified is offline   Reply With Quote
Old 02-14-2007, 09:10 AM   #17
Judaeus Apella
Well, perhaps it was the way I worded my first explanation. We all think differently and come from different walks of life, and something that sounds obvious as one thing to someone, may sound as something completely different to someone else. I'll try again. No hard feelings I hope?
And this has a lot to do with the question,
I cannot play a game using the letter keys. They feel incredibly awkward to me the way they don't line up and I cannot get used to them, which causes me to play badly. But I am very comfortable using keys that are laid out so they are straight up and down like the number pad, in straight vertical and horizontal lines. So Im looking for something set up so that the keys are laid out in straight up and down lines, unlike the letter keys, but with more keys than a number pad; at least 26 to 30 keys. And if the keys on the number pad are seperated into different groups, then the largest concentration of them must be a group of 5 keys up by 4 keys across like the numberpad.
Its difficult for me to understand why something like this is so difficult to find, and when you do they are SO expensive! With all the different uses for keypads like this including CAD, scientifc and industrial work with special equiptment requiring a simple keypad like this, design and modeling work where a keypad like this would be a great way to enhance productivity, and of course gaming... there has to be something like this that doesn't cost a bloody fortune!
Anybody heard of this?
__________________
Old 02-14-2007, 12:12 PM   #18
DaveMcGee
ok maybe something like this would work
http://www.gearlive.com/index.php/ne...keys_05060217/
Dave
Old 02-14-2007, 12:13 PM   #19
DaveMcGee
Dave
the price though....Ouch...
Old 02-14-2007, 12:24 PM   #20
DaveMcGee
again not quite maybe but who knows
http://keyboards.stores.yahoo.net/progkeypadpf.html
Old 02-14-2007, 12:24 PM   #21
DaveMcGee
Old 02-14-2007, 12:27 PM   #22
DaveMcGee
http://www.keenzo.com/showproduct.asp?ID=4519&ref=FRG1
Old 02-14-2007, 02:12 PM   #23
Judaeus Apella
Holly sh*t thats awsome! I love that! It even matches the color of my other keyboard. LOL
I wonder if anyone else sells it....
__________________
Old 02-14-2007, 02:36 PM   #24
Judaeus Apella
I read a few user reviews about the Wolfking... and they say that it feels awkward at first, but they soon got used to it and now they love it. I found it at Microtech cheap. Think I should get it or... are they not a trustworthy store? I've never heard of them.
http://www.techmicro.com/ProductDeta...Code=DK2388UBK
__________________
Old 02-14-2007, 06:29 PM   #25
Plywood99
Xtreme Cruncher
Plywood99's Avatar
Send a message via MSN to Plywood99
That is a nice keypad. Cherry switches are some of the best on the market...
Ply
__________________
Antec 900 Case
Q6600 SLACR @3550 / Giga P35 DS3R
Cooler Master Hyper 212/ PCP&C Quad 750
4 gigs G.Skill PK series
BFG 8800gt / Thermaltake DuoOrb GPU Cooler
X-fi pci-e / Logitech Z5300
Plywood99 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
