XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 02-12-2007, 03:53 PM   #1
Judaeus Apella
Judaeus Apella's Avatar
Send a message via ICQ to Judaeus Apella Send a message via AIM to Judaeus Apella Send a message via MSN to Judaeus Apella Send a message via Yahoo to Judaeus Apella
Arrow Delta Fans Finally At Newegg, Along With Some Others
I was looking through Newegg's selection of fans, and I noticed "Rexus" Fans being sold and I thought, "Don't they mean Nexus?". Turns out its not a rip-off of Vantec's line of Nexus silent fans, but Rexus is actually a well known manufacturer. They make the NZXT line of cases, and they make PSUs, cables, enclosures, input devices, and tons of other components; many of which Newegg sells.
Even though none of the fans are made by Rexus, they ARE manufactured by Delta, Panaflo, AddA, and JMC/Datech. The two Delta models being sold are current models, but all the Panaflo models are the older ones and I suspect as much for the AddA and JMC/Datech too. The prices don’t reflect that fact though, as the Panaflo fans are $20 to $13.
I’m going to guess Rexus needed to get rid of their stock of older and overstocked on some other current fan models, and sold them off cheap to anyone who would buy them so they could make the room for a supply of new models.
If this means that someone new is going to be supplying a fresh stock of the new Panaflos (and perhaps more Delta models) to resellers like Newegg, then this could be good for those of us who know the difference between the old and the new models, but bad for the common simple minded consumer on which most of Newegg’s business is based on unfortunately. Still, the older models being sold are still good fans… but they aren’t worth those prices.
92x38mm Delta Fan
Great performance fan that pushes +9mmH20 of air pressure at just under 80CFM at 46dba, which means it has the most air pressure verses CFM and noise level, when compared to everything else in that size at Newegg.com. (Air pressure is how hard a fan pushes the air. So a fan with low air pressure won’t push much air through a heatsink cooler, while a fan with a lot of air pressure will do it well.) It’d be good for overclocking, servers, etc. Just tame it if you use it on a rig that doesn’t normally need the extra power.
70x15mm Delta Fan
70mm fans are usually used on smaller CPU coolers in PCs and servers. Despite its size, it does probably the best air pressure of all their selection of 70mm fans at Newegg. It’d probably be useful in a server application, or again for overclocking. Its small, so it could also be used to cool other things in your case, like memory or a video card, or to help guide the airflow in a case. Would be a good idea to tame it down a tiny bit to benefit from that air pressure without the unneeded high output, unless the noise doesn’t matter.
Yep... no 120mm models. All these fans are being sold as "Rexus" fans, not by the actual brand name. I got kind of a love hate thing going with this news. It sucks that they're selling old models, but this might mean that Newegg will start selling other Delta models in the future. Guess I'll have to wait and see.
__________________
Reality is merely an illusion, albeit a very persistent one. - Albert Einstein
True wisdom is the ability to see past the limitations of knowledge. Insanity is knowing too much, and sanity is knowing too much about nothing important.
Judaeus Apella is offline   Reply With Quote
Old 02-12-2007, 06:30 PM   #2
otogrim
boo for no 120mm...Wonder why they left those out
__________________
DFI LanParty Ultra-D 704-2bt
AMD Opteron 165 CCBBE 0616 XPMW @ 3.0ghz - Ultra-120
2GB (2X1gb) OCZ EL Gold PC4000
x2 EVGA 7800gt 256mb PCI-E
NEC DVD-RW
X-Fi Xtreme music
OCZ Powerstream 520W
74gb raptor for OS
120gb Seagate & 250bg WD Storage
otogrim is offline   Reply With Quote
Old 02-12-2007, 07:47 PM   #3
Spawne32
Xtreme Guru
Spawne32's Avatar
Send a message via AIM to Spawne32 Send a message via MSN to Spawne32
the 70mm which i would have needed is out of stock
__________________
My Heatware
Spawne32 is offline   Reply With Quote
Old 02-13-2007, 08:02 PM   #4
john80y
Rexus don't make anything, they are just a low level distributor (High level would be Techdata or ASI)
There website is http://www.rexuscorp.com/
john80y is offline   Reply With Quote
Old 02-13-2007, 08:45 PM   #5
Judaeus Apella
Uh... I hate to break it to you but,
"REXUS CORP is recognized as one of the premier power supply providers. We are devoted to manufacturing and developing power supply and chassis for every computer user. Utilizing our technical expertise and innovative designs, we are constantly expanding our product line to offer advanced computer peripherals to meet the personal and industrial needs of modern computer users.
REXUS' mission is to produce the top quality thermal solutions on the market. We produce quality products that help you keep your system cool. Our primary goal is to create viable solutions to satisfy the consumers' needs."
Thats quoted from their web page. LOL
__________________
Old 02-13-2007, 08:47 PM   #6
p0tter
p0tter's Avatar
Cant find a better deal on Yate Loons
www.petrastechshop.com
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline   Reply With Quote
Old 02-13-2007, 08:53 PM   #7
Spawne32
Xtreme Guru
Spawne32's Avatar
i wish someone would make a really awesome 3 blade fan, only because i think they look really cool
__________________
My Heatware
Old 02-13-2007, 09:13 PM   #8
Judaeus Apella
Awfully suspicious the way Yate Loon Provides no info on air pressure measurements...
Without air pressure, all of its stats mean zilch. The fact that they're so quiet could be an omen... because air pressure makes noise. Thats the problem with a lot of quiet fans, they have little air pressure and can't actully push that air if there's any obsticles or resistance, but of course none of the manufacturers who make their money on quiet fans would ever warn you about that... and then some idiot who spent $20 per a fan wonders why everything is overheating. LOL (I've seen them complain about this without knowing whats wrong on various store sites with customer reviews.)
The funny part is, a lot of these companies are making loads of cash on really poor quality fans, that are sold for so much cash BECAUSE of their low specs. Its the best scam I've ever seen. Really it is. Im not saying Yate Loon is one, but I'd like to see someone take turns filling a thick garbage bag up with air with different fans, and see which fans fill the bag up with the most volume. Or you could do the ball tube test, where a fan has to blow a ball up a tube, and you measure how high each fan holds the ball steadily.
__________________
Old 02-13-2007, 09:30 PM   #9
adamsleath
Xtreme Guru
adamsleath's Avatar
....complementary earmuffs with those deltas? 46dba is vewwy noisy...i can hear 36 dba from the other end of my house great air flow...good for people who are deaf or who have hermetically soundproofed cases.
__________________
q9550@3.75GHz|GTX295[SOLD]|4x2GBDDR2|P5Q-Pro|640GB WD X2|Vista 32+64 dual boot|BenQ G2420
adamsleath is offline   Reply With Quote
Old 02-13-2007, 09:33 PM   #10
Spawne32
Xtreme Guru
Spawne32's Avatar
__________________
My Heatware
Old 02-13-2007, 09:41 PM   #11
adamsleath
Xtreme Guru
adamsleath's Avatar
yeah alright ..but i think you wood want to turn down that 92x38mm delta a bit....well i would for noise anyway.
and i would also not touch anything with no spec.
__________________
Old 02-14-2007, 11:03 AM   #12
john80y
I hate to break it to you, I can put that on any web page and it doesn't make it true.. They are a one man band and they buy products in China and brand them as there own, they do not own any factories or manufacture anything.. I know the owner, he's called Lucas and used to work for another distro called AOCUSA.
Old 02-14-2007, 01:44 PM   #13
Judaeus Apella
Okay... thats fine. I was using common sense and going by what the webpage read.
Settle down. LOL
__________________
Old 02-14-2007, 02:33 PM   #14
goreblast
Check out sidewindercomputers - they have the biggest range of Delta fans in stock I have ever seen. And even though I'm from the UK I have ordered from them before. Very good site.
goreblast is offline   Reply With Quote
Old 02-15-2007, 10:52 AM   #15
Judaeus Apella
Thumbs down
Oh, now you went and got me started on them again! Avoid them like the plague!
Sidewinder computers has a pretty good scam going with their single channel fan controllers. LOL Have you seen what they charge for those things!? Just the 25w is $29 and don't even give you a nob for it! And they have the nerve to make some cheap plastic nob a $5 option! ROFL
I tried emailing Sidewinder Computers about this, and how potentiometers aren't even efficient because they get really hot and just add heat to your case, compared to much more efficient controllers.
I tried to be polite in the email, but they sent me a really rude snobby reply. They told me that I obviously don't know what I'm talking about, and went on and on about how efficient that part was, using a bunch of big words.
I've since been looking for another website to do business with, cause those guys are just @SSHOLES. A lot of their prices for other components suck too, and they don't really have that great of a selection to begin with. They don't even carry that nice Sunbeam RHK model, while nearly everyone else has it. They probably just wanted to just push their sh*tty potentiometers.
The Sunbeam 4 channel RHK, with 20 watts PER a channel and oversize heatsinks per channel, costs about the same as just ONE of their 25w potentiometers.
But for now, they DO have the widest selection of current Delta models... so order from them if thats all you need. Just don't order anything else from them. LOL
__________________
Old 02-15-2007, 11:28 AM   #16
ozzimark
Love and Peace!
ozzimark's Avatar
Send a message via AIM to ozzimark
btw, i have 2 of those 70mm deltas.... came off amd retail heatsinks
__________________
Got a fan over those memory sticks? No? Well get to it before you kill them
ozzimark is offline   Reply With Quote
Old 02-15-2007, 12:25 PM   #17
Praxis1452
Their custom made potentiometers. What other fan controller will handle 25W or 50W? The 50W isn't matched anywhere last I checked. Their prices are high and I agree however their delta selection can't really be beat.
Praxis1452 is offline   Reply With Quote
Old 02-15-2007, 01:01 PM   #18
[XC] MarioMaster
Xtreme Cruncher
[XC] MarioMaster's Avatar
Send a message via AIM to [XC] MarioMaster
yes, wire-wound potentiometers also known as rehostats, they generate heat since all they do is create resistance
__________________
|Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
(12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
(12:16:19 AM) OC3D NoL: RAWRRRR
[XC] MarioMaster is offline   Reply With Quote
Old 02-15-2007, 02:31 PM   #19
Judaeus Apella
Talking
Exactly! They are an innificiant technology thats been around for decades. If you need more than 20 and its important, then yeah I guess. But I can only immagine how much heat that 50w potentiometer must generate. Damn, you'd need a heatsink and a fan just for the controller. LOL
__________________
Old 02-17-2007, 10:16 AM   #20
vafan13
Correct me if I am wrong, but the RHK uses potentiometers, too...
And they say they use Ohmite rheostats. If you look up 25 watt Ohmite rheostats you'll notice they are $25 each. So I am going to say that $29 for the rheostat + sleeved Molexes isn't exactly a "scam."
vafan13 is offline   Reply With Quote
Old 02-17-2007, 11:55 AM   #21
exhausted mule
exhausted mule's Avatar
they get hot because reostats use resistance to absorb the amperage that would otherwise be going to the fan. they do this by converting current to heat.
go back to school pls.
exhausted mule is offline   Reply With Quote
Old 02-18-2007, 07:44 AM   #22
meshmesh
Xtreme Cruncher
May I ask, why would someone need a 25 Watt rheostat? What type of fans are attached that would require such a rating? Thanks.
__________________
Dual Clovertown @ 3.2 GHz (stock Vcore), 4x1GB 667 FB-DIMMS, SM X7DAE, Silencer 610 PSU, Windows server 2K3 EE.
(professionally built & generously hosted by movieman)
AMD64 X2 4400+ @237x11 (1.39v), Corsair TwinX2048-3500LL @2.5-3-2-6-1T (2.75V), MSI K8N Neo4, Tagan 420W PSU, Windows XP Pro SP2.
meshmesh is offline   Reply With Quote
Old 02-18-2007, 10:08 AM   #23
Baenwort
Baenwort's Avatar
All of the high end Deltas. Take a look at http://www.sidewindercomputers.com/de12gf.html I've got one and the 50w Rheostat to control it as it sucks in 32w. look around Sidewinder's Delta section. many of the higher end Deltas pull enough power to fry conventional controllers.
Even the ones that only take 18-20w steady state pull enough current on startup that I've had them kill Sunbeams before.
__________________
HARDWARE
CPU:Intel e6600
RAM:2gig Mushkin Redline 8500
MB: DFI RD600(ICFX3200 T2R/G)
GPU:ATI x1950xtx Vmods and 237W TEC(retired)
ATI 4780x2 w/Swiftech Caldera
AUDIO:M-Audio Firewire Audiophile
HD:
2x150gig Raptors RAID 0
4x320gig WD16mb RAID 5
2x120gig WD8mb External
PSU:
BFG ES-800
Meanwell 320w-12
MNT:Acer 2423W
COOLING
CPU:Swiftech Storm Rev2
GPU:Swiftech Caldera and 6002
RAD:BlackIce III Extreme
PMP: 2xLang D5 in series
TUB:1/2" ID (3/4" OD) Tygon Silver Antimicrobial Tubing
FANs:
3xDelta EFB1212SHE TriBlade
1xPapst TYP4114N
1xDelta GFB1212VHW
1xSilverStone FM121
2xSharktoon SK-2000-80
Baenwort is offline   Reply With Quote
Old 02-27-2007, 07:53 PM   #24
MadZalmanModder
MadZalmanModder's Avatar
yeah. i got my 220cfm 120mm from side winder as well (got two so i can clam shell my zalman) and yes, they are very noisy. and my fan mate 2 controller lasted ohhhh about 90 seconds before it started to "smoke and smell" when trying to control the fan speed.
MadZalmanModder is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
