XtremeSystems Forums
Reply
Old 02-10-2007, 06:34 PM   #1
CedricFP
CedricFP's Avatar
PA160 Radiators
Originally Posted by Marci
Break it down...
* PA160 with 1x Panaflo M1A @ 7v: CPU - 21 GPU - 22
* HE120.3 with 3x ^^ ^^ ^^ ^^ : CPU - 18 GPU - 19
* PA120.2 with 2x ^^ ^^ ^^ ^^ : CPU - 17.7 GPU - 18
* 2x PA160 with 1x ^^ on each ^ : CPU - 15.8 GPU - 15.1
* PA120.3 with 3x ^^ ^^ ^^ ^^ : CPU - 15 GPU - 15
Source: http://www.over-clock.com/ivb/index.php?showtopic=17958
Seems to me that 2xPA160's perform nearly as well as a single PA120.3.
Now, as I understand it, my MCR220 gets beat by a PA160 in all situations, low flow, high flow, low CFM, high CFM. However, probably by very little at all of an improvement making it a somewhat lateral movement.
Now, in my case, I have a LL PC7-B case (a PC60 with 120mm fans instead of 80mm) and it provides a VERY neat installation for a single PA160.
(Courtesy of Marci) Source: http://www.over-clock.com/ivb/index.php?showtopic=12424
However, if I am to make this somewhat lateral movement worthwhile (as I can easily fit my double in the top), I would get a second PA160, which as Marci's tests show (quoted above) perform nearly as well as a PA120.3.
The question is, what do you think about that? I could put one PA160 in the top, one PA160 in the bottom, and loop them in series with my D5 (which should surely be powerful enough for 2 low restriction, single pass radiators), particularly when compared to the (relatively) high restriction of my MCR220.
What are your opinions on this? It leaves me 2 or 3 5.25 bays free, and I can always put the hard disk enclosure in the middle of the floor, leaving me space for 3 HDD's still.
I would appreciate opinions. I am on the verge of pushing the order button, but I wanted to check for views on here.
Thanks in advance
EDIT: For those who don't want to read too much:
1. Want a PA160
2. Almost a lateral movement from MCR220
3. Want 2 PA160's.
4. Is it a good idea to run them in series with single D5?
5. What are your opinions? Just get a PA120.2 and call it a day?
6. Do you have any other idea for mounting two PA160's in a single LL case this small
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 02-10-2007, 06:37 PM   #2
kamongear
kamongear's Avatar
If cash isnt an issue then go for it.
kamongear is offline   Reply With Quote
Old 02-10-2007, 06:39 PM   #3
CedricFP
CedricFP's Avatar
Yes, that would be the logical conclusion. I have the money, certainly and I've just been paid for Jan.
However, I also need some input on the mounting difficulties of the second rad.
Any ideas?
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
