02-09-2007, 01:19 PM
#1
3800+ X2 memory controller woes
Ok I can't get my memory to run stable stock (250 MHz) no matter what settings I use. I am considering RMAing the memory (in my sig), but I have spoken to several people, mainly TeamGroup techs, that say my memory controller is probably the culprit, and that RMAing will probably not help any.
Is there any way that I can test the memory controller?
I am currently running the modules at 241 MHz, and it is pretty stable in games, but I get errors in Memtest after about 5 minutes.
I've tried SUPER relaxed timings, 2T command rate, pretty much everything that I can think of.
I'm just wondering if anyone has any ideas, or if anyone with a socket 939 3800+ X2 has gotten their memory over 240 MHz stable.
__________________
Q6600 G0 @ 3.8 (475x8) 1.496V || ASUS Maximus Formula X38 || 4x2GB Geil Evo One DDR2-950 5-5-5-15 ||
Sapphire 4870X2 857/1000 || XSPC Delrin full coverage block || MCP655 || D-Tek Fuzion Nozzled ||
Black Ice 480GTX 8 120mm Yate Loon push/pull || Silverstone DA850 PSU 70A +12V || Auzentech Prelude ||
Vantage P15071 in Vista x64
02-09-2007, 06:03 PM
#2
Well my sticks are good to 12hrs prime blend 280MHz 1:1 but they won't do 287MHz like with the 146  Still it sounds fishy when your sticks won't do what they are promised to do. How can the techs know if it is the memory or the memory controller that is faulty? Bad stepping for the X2 3800+ or what?
If you can't test your components in someone else's rig then RMA the sticks.
__________________
AMD X2 3800+ Toledo LCBIE 0628DPMW @ 2.9GHz 1.400v
OCZ Gold (UCCC) 2x1024 PC4000 @ 287MHz
Thermaltake Big Typhoon
DFI nF4 LP Ultra-D Rev. AD0 704-2BTA
MSI 7900 GTO @ GTX (685/840)
Antec TX1050B
Antec Smartpower 2.0 500W
02-09-2007, 06:25 PM
#3
I'm using the same modules and they're good up to 270Mhz on my ATI board. Post a link to a screenshot of your desktop while running A64 info so I can see what all your memory settings are. If I see anything that stands out I'll try to help. BTW rather than an RMA would you consider selling them to me as they are out of stock and I've been searching frantically for another pair.
__________________
ICFX 3200 7/30 bios
E6850 423X9 1.42V.
2X1024 Tracer 2.0V 4,4,4,14
Audigy ZS X1900XTX
ST 60 PSU
02-11-2007, 04:25 PM
#4
I'll be able to post some screens as soon as I get my PC connected to the internet. I'm staying at my parents while I recover from back surgery, so my PC is downstairs until next week. I tried the timings that OnePageBook posted in the TeamGroup support forum on this site, using the loosest of the range. I also tried the 2T command rate. At these loose timings I couldn't even get 241 MHz to pass Memtest.
__________________
02-11-2007, 04:27 PM
#5
YouTube Addict
sounds like the Abit board is having a problem selecting the correct drive strength
02-11-2007, 07:32 PM
#6
That's interesting......it doesn't have that option in the BIOS. I have tried setting this option in A64 Info.
I'm not really familiar with this setting's function, but the default setting when I open A64 Info is "weak" and the DRAM data drive strength is L4 (reduce %0)
Is there a way to isolate this, given that it isn't an option in my BIOS?
__________________
02-11-2007, 09:19 PM
#7
pardon my ignorance, but what is the drive strength for and how does it affect performance and stability?
And what is the difference between DRAM Drive Strength, and DRAM Data Drive Strength?
02-11-2007, 10:10 PM
#8
I'm not really sure what the difference is, as it isn't an option in my BIOS. The only details that I know about these settings are from A64 Info, which are:
Drive Strength: Weak or Strong
DRAM data drive strength:Reduce by %X (4 levels)
I also know that Micron ICs prefer Weak strength according to the settings guide by OnePageBook in the TeamGroup section.
__________________
02-12-2007, 02:48 PM
#9
Here are some screens of some timings that I have tried, all failed Memtest and Orthos blended.
I don't have a screen of the loosest timings that I tried, but they are the upper values of the timings listed here:
http://www.xtremesystems.org/forums/...ad.php?t=90438
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
