XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 02-01-2007, 09:11 PM   #1
luihed
Overkill
luihed's Avatar
E6600 "B" Thread
Guys with a B stepping E6600 please post your overclocks here.... I want to see how these new stepping are compared to the "A" stepping.....
Please post as follows:
Stepping
Max overclock
voltage
Temp
Cooling
mobo
ram
I have an E6600 coming on Monday (L633B) so Ill post my result then.... Hopefully we can help future E6600 buyer find a good chip...
Thx
__________________
E8400 DFI LP P35T2R Ballistix
8800GTS PCP&C 1.2kw Raptors
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
luihed is offline   Reply With Quote
Old 02-01-2007, 09:21 PM   #2
GrimReaper
GrimReaper's Avatar
http://www.xtremesystems.org/forums/...d.php?t=127379
compare them here
__________________
"WW3 will be fought with nukes, WW4 will be fought with rocks!":
GrimReaper is offline   Reply With Quote
Old 02-01-2007, 09:28 PM   #3
luihed
Overkill
luihed's Avatar
Yeah, I guess thatll work too lol....
Nice databese you have there GR....
Why dont we use this thread for max screenie ( cpuid verified ) or max superpi 1M clocks?
__________________
E6600 =5400mhz
E6700=5680mhz
QX9650= 6000mhz
Old 02-01-2007, 10:17 PM   #4
MrDeeds
MrDeeds's Avatar
Because we already have a thread for that also
http://www.xtremesystems.org/forums/...d.php?t=115109
__________________
Asus Commando 6600 week 28B @4.2 1.475v(1.475 in bios) 525x8 4-4-3-4 1150mhz 2.3v
2x1gb Patriot Pc-8000 Xbl | X1600 Pro | 2 Wd 36gb Raptors
Seagate 750gb | Vapoli V2000B SS | Pc p&c Black Silencer 750
Originally Posted by chron
Its DDR2 - doesn't it need to be ran with 2 sticks at a time?
MrDeeds is offline   Reply With Quote
Old 02-01-2007, 10:25 PM   #5
shogo_ca
shogo_ca's Avatar
Stepping L631B106
Max overclock 4160 Mhz (bootable), 4010 Mhz Benchable, 3860 Mhz Orthos Stable
voltage 1.55v
Temp 45c Idle, over 80c Load @ 1.55v , 33c Idle, 70c Load at 3860 MHZ (1.475v)
Cooling Air (thermalright ultra-120/panaflow fan)
mobo Badaxe2
ram teamxtreem 2x1gb 667 c3 @ 890 4-4-3-4
__________________
CPU Intel C2D 6400 - 6600 L631B Aircooled 4010 MHz (wip) 3850 MHz daily
COOLER Big Typhoon 120 - Ultra 120/Panaflow 103cfm
MOBO Asus p5w dh - Badaxe 2
RAM 2gb Team 667 cl3 844mhz 4-4-3-4 2.0v (wip)
GPU Bfg 7900GT - XFX GX2 600/1600 3Dmark06 10554 (wip) 207K AM3
PSU Gamestream 600w - Powerstream 520 - Silverstone Zeus 750w
Chassis Lian-Li V2000b Plus2 Lian-Li v1100b
shogo_ca is offline   Reply With Quote
Old 02-02-2007, 04:47 PM   #6
Halvie
L63B442 won't boot into windows at 400X9 unless vcore is set to at least 1.47 in bios...and fails orthos within a minute. Urghhh
ds3
gskill ddr2 800
x1950xt
Halvie is offline   Reply With Quote
Old 02-02-2007, 08:07 PM   #7
Charloz24
Charloz24's Avatar
He means "B" batch code, not stepping....
__________________
Q6600 rig coming soon....
Charloz24 is offline   Reply With Quote
Old 02-03-2007, 04:27 PM   #8
JoeBar
Xtreme Mentor
JoeBar's Avatar
There's an open thread already. No need for this.
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
