XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware > Video Cards
Old 01-21-2007, 03:22 AM   #1
joshd
Xtreme Cruncher
joshd's Avatar
Permenant Damage?
Hey All.
Yesterday, I gave my brother and his friends use of my computer to play BF2 LAN. I went on it myself yesterday evening, and noticed it was artifacting pretty heavily, at texture edges, such as tree > ground border, which on this card, I have found to mean memory artis. I went on FEAR, to check a certain location that I have found particularly sensitive to memory artifacts, and sure enough, it was.
The scary thing is... it still does this at stock clocks. If one of my brothers friends did not notice the artifacts, and carried on playing regardless, could this have permenantly damaged the card in some way? ATi Tool seems to be artifact free, it is just games. Any advice?
__________________
Q6600 G0 @ 3.4GHz, Tuniq Tower, 9800GTX, 4TB Total
4GB GeIL Ultra (DDR2-850), ASUS P5K Premium
ASUS Xonar D2 + KEF Celeste IV, Quad 33+303 amp+pre, Denon D2000
joshd is offline
Old 01-21-2007, 03:45 AM   #2
Drager2
Drager2's Avatar
Send a message via ICQ to Drager2
What videocard do you have? Sounds like Palit 7900GS.
PS=: Ati Tools is sucks for testing for artifacts.
Drager2 is offline
Old 01-21-2007, 03:51 AM   #3
joshd
Xtreme Cruncher
joshd's Avatar
its all in the sig, but it is a Gainward 7900GT. It was clocked at 560/810 when they were playing on it yesterday, but it now does it at the stock 450/660.
__________________
joshd is offline
Old 01-21-2007, 04:08 AM   #4
Drager2
Drager2's Avatar
Ok, I see it in profile. So congrats, you`ve kill the memory. So what is your cooling? What is your vmem voltage? If it is more than 1.9v - try to do voltmod to get 1.8v (after some time memoru frequency can rise)/ Try Alt+Tab when you play some 3D/ apply acept 3 buffering (ssory, I dont know how it in english)/ Set timmings from datasheet / apply PEG root control. So smth from this tweaks should help. Good luck. But it wouldnt help - just change video in shop.
Drager2 is offline
Old 01-21-2007, 04:14 AM   #5
DataNusse
DataNusse's Avatar
Sounds like your card got the 7900GT artifect issue. There is not mutch to do than to send it back and get it replacet.
sorry..
__________________
"The flames of freedom. How lovely. How just. Ahh, my precious anarchy.."
DataNusse is offline
Old 01-21-2007, 04:41 AM   #6
Martijn
Mr. Boardburner
Martijn's Avatar
Send a message via MSN to Martijn
Looks like crap, I did the same to my old Radeon 9200 SE... Ran at it's absolute max, then started artifacting like crazy, on stock as well. Can you get it replaced?
__________________
Main rig:
CPU: Xeon W3570 C0 ES @ 3.8Ghz (160x24, 1.35v)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
OS: Intel X25-M G2 80GB
Apps: Spinpoint F1 1TB
Media/Storage: 2x Spinpoint F1 500GB, 1x Seagate 7200.11 1.5TB, WD MyBook 1TB (USB)
PSU/Case: BeQuiet 650W DPP, Silverstone TJ07
Crunching:
Server: Dual XeonLV s479 @ 2.0Ghz (up), Lappy: T9300 (up)
Badges:
Statistics are like miniskirts. Sure, they give you ideas, but they hide the essence of what we're doing.
Martijn is offline
Old 01-21-2007, 05:44 AM   #7
akshayt
I don't understand, can playing at insane settings damage the card so badly in such a short interval of time?
akshayt is offline
Old 01-21-2007, 05:52 AM   #8
Drager2
Drager2's Avatar
akshayt Cause palit/geinward use to high voltage on memory with bed or stock cooling.
Drager2 is offline
Old 01-21-2007, 06:07 AM   #9
DataNusse
DataNusse's Avatar
Im very sure that this is the "7900GT issue". It can come at the same day you put the card in or after several weeks.
http://www.google.se/search?hl=sv&q=...%B6kning&meta=
If u havent done any vmods or anything then it shuldent be any problem for you to RMA it and get a new one.
__________________
Old 01-21-2007, 07:34 AM   #10
joshd
Xtreme Cruncher
joshd's Avatar
no, no voltmods. I will try and get it replaced then. I'll wait until tomorrow and then make some phone calls.
heh, never realised how hard it is to get a picture of an artifact, but I managed to capture one:
they flash and sort of "move" along edges between textures, like in the SS.
__________________
joshd is offline
Old 01-22-2007, 10:06 AM   #11
joshd
Xtreme Cruncher
joshd's Avatar
OK, that has been shipped back to OCUK.
__________________
joshd is offline
Old 01-23-2007, 08:20 AM   #12
Drag
Banned
Drag's Avatar
LOL martijn i bet they have that with ati cards all the time
Drag is offline
Old 01-24-2007, 06:54 AM   #13
joshd
Xtreme Cruncher
joshd's Avatar
Replacement 7900GT is shipping as I type, should arrive tomorrow morning.
Hope it's a good clocker
__________________
joshd is offline
Old 01-24-2007, 12:25 PM   #14
Drag
Banned
Drag's Avatar
accourding to xfxforce you can oc the card to
Memory Clock
1.65 GHz
Clock rate
560MHz
Drag is offline
Old 01-24-2007, 12:36 PM   #15
p0tter
p0tter's Avatar
The Samsung chips had the problem you experienced, I believe the Hynix chips are more stable but OC less.
I had the same problem with my 7900GT the samsung clocked 900, but started to artifact a month later.
My replacement had Hynix and only would clock 600... i ebay;d it
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline
Old 01-24-2007, 01:28 PM   #16
joshd
Xtreme Cruncher
joshd's Avatar
they are 660MHz stock?!?
I think the replacement will be another lot of samsung. I am not even sure if the caps have all been changed to the black ones or not, all the pictures I have seen of it all have some mint coloured caps. Oh well, just have to see. If it breaks again I can always RMA it again I suppose....
who??? the card is a gainward... not an XFX is that is what you mean.
__________________
joshd is offline
Old 01-25-2007, 05:18 AM   #17
Drag
Banned
Drag's Avatar
xfxforce sell factory overclocked cards
Drag is offline
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
