01-19-2007, 08:56 PM
#1
-100c club
lost another mobo to phase
Ok just lost my striker to what im assuming is a phase related problem but i did a very thorough job of condensation proofing. Anyway i need a replacement Sli mobo until the striker gets fixed is the EVGA 680i board just as good as the striker. I run my e6700 (ES) at 4.4 ghz for 24x7 use.
Let me know because the EVGA is the only decent Sli mobo my local Frys caries in stock
01-19-2007, 09:02 PM
#2
Banned
eVGA 680i is a good board but as has been noted, it has its quirks. I'm really hoping that the niggling SATA, SB, RAM issues have been corrected by now, and if so, I'd go for it.
01-19-2007, 09:23 PM
#3
I used an EVGA 680i for over a month and never had a single issue with it, even running at 4.5Ghz for a couple of weeks
Until I tightened my evap mount too tight and killed the motherboard .......
Here's what the backplate looked like:
__________________
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
01-20-2007, 06:20 AM
#4
-100c club
Ok looks like ill be trying out the evga for a while...
Thanks guys.
01-20-2007, 10:16 AM
#5
-100c club
Just got back with the EVGA 680i will install soon and see what it can do...
01-20-2007, 10:26 AM
#6
Xtreme Mentor
Did you glob on the dielectric grease for your condensation proofing?
01-20-2007, 10:36 AM
#7
Memory Addict
WTF.. surprised the board didn't snap!
01-20-2007, 08:42 PM
#8
-100c club
Ok after playing with the evga board for a day i can say that this board is horrible....the Striker is so much better that its not even in the same category.
I am appalled by this mobo the bios is a joke and the stability is so far below the striker that its sad. Sorry to offend anyone but im honestly shocked....
01-21-2007, 09:32 AM
#9
just use hacked drivers on 975X
__________________
PHENOM II x4 720 @3.5Ghz // GIGABYTE GA-MA790X-UD4P // 4GB DDR2-800 4-4-4 // hd4870 512mb // CORSAIR CMPSU-750TX // ZEROtherm Nirvana // Intel X25-M 80gb // 2 * WD 640GB
01-21-2007, 09:49 AM
#10
I am Xtreme
have you ever tried to snap a mobo?
Its quite hard.
01-21-2007, 09:51 AM
#11
Xtreme Cruncher
Yes, that is a good idea. 975 is a very stable chipset, but not great for high FSB
__________________
No more PC, damn economy
02 Tahoe with a *NICE* stereo! Soon to be:
2 300a alts, 4 AQ2200D amps, AQ90x4 amp, 4 18" AQ HDC3A's (2200RMS Watts each) multi batts in rear all G31's, MLA 15.4v module, etc.... Nearing 10,000watts
01-22-2007, 10:43 PM
#12
The board was bent slightly. I removed the bend in the board but it didn't work though
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
