01-17-2007, 10:30 AM
#1
Mr. Swiftech
All Apogee GT Owners Please Read!
I am not sure if this is the appropriate format for me to post this, so forgive me in advance.
As more and more users implement the Apogee GT o-ring tweak, I wanted to make sure that everyone understands that the base plate needs to be oriented properly in relation to the inlet and outlet ports. here is a schematic that we also posted on the apogee and apogee gt pages, as well as in the tweaking guide:
__________________
CEO Swiftech
01-17-2007, 12:02 PM
#2
Xtremely Wet
Bumpage! Gabe, just a thought but perhaps you could notch (or mark) each side that needs to correspond to a barb on the SIDE of the base plate. This is not only for replacing the oring but for anytime the block is opened. I opened mine and had no clue it was a directional base. I assume some could even get assembled incorrectly at the factory as well.
__________________
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
Q6600 @ 3.7Ghz / Maximus Formula X38 / 4GB Supertalent 6400 / 4870 HD
PC Power & Cooling 750W
Mountain Mods U2-UFO Cube
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
Win7
"Artificial intelligence is no match for natural stupidity."
Originally Posted by ranker
Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
01-17-2007, 12:20 PM
#3
Administrator
I'll sticky this thread for the time being.
This is some important information for all those who have bought (or are planning) to buy this block.
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman
I've got Supermicro boards that lasted longer than one of my marriages!
01-17-2007, 12:21 PM
#4
Xtremely Wet
Jupiler, I'm just afraid no one will see it in the stickies... I thought it got removed lol.
__________________
Win7
01-17-2007, 12:42 PM
#5
Administrator
You're probably right about this.
I'll leave it unstickied, and hope everyone takes the time to read it.
__________________
Rig #1
BFG GTX280 OC
Coba Nitrox 750W
Rig #2
Powercolor 4870
Corsair 520HX
01-17-2007, 12:49 PM
#6
Xtreme X.I.P.
I was wondering if the Apogee's had a directional base. It seemed logical that they did because the pins are set at a particular angle, but now we know for sure.
I will change the title to urge all apogee readers into reading this thread.
BTW, thanks for the heads up Gabe.
01-17-2007, 01:25 PM
#7
Mr. Swiftech
what we need is make sure everyone knows about this. First step was to put it on the web site - done - second step was to post in the forums - in process - third step is to include it in the installation guide - in process -
__________________
CEO Swiftech
01-17-2007, 01:47 PM
#8
Administrator
Have the online retailers been contacted about this?
So they can update the correct installation procedure for the base plate on the GT, once customers decide to put the thicker O-ring instead of the regular one..
__________________
Rig #1
BFG GTX280 OC
Coba Nitrox 750W
Rig #2
Powercolor 4870
Corsair 520HX
01-17-2007, 01:52 PM
#9
it would be interesting to see the performance difference between right and wrong, time for a few e-mails to swiftech
__________________
465 Watts of Computing Power....Running Off the Sun.
**w00t for solar panels**
01-17-2007, 01:57 PM
#10
The instructions that came with my Apogee talked about the pin orientation and had a picture indicating the correct orientation.
What more do you need?
01-17-2007, 01:59 PM
#11
Aint No Real Gangster
i had my apogee opened the other day and was wondering this exact thing.
i forget which way i put in on though.
__________________
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale
2x1GB OCZ PC2-9200 FlexXLC
BFG GTX 280 OC2
Maxtor 6L250S0
Maxtor 6V300F0
Western Digital WD2500JS
Western Digital WD500AAKS
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Arctic Cooling S1
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
01-18-2007, 07:09 AM
#12
Bumb, pretty good info! Im about to buy one of those GT
__________________
• - EVGA 680I A1 (vdroop mod)
• - Intel QX6800ES G0 @ 3.95Ghz
• - SLI BFG 8800GTX OC2 @ 626Mhz \ 2000Mhz
• - 4GB G.SKILL F2-6400PHU2-HZ @ 1005Mhz
• - Ultra X3 1000 Watt Modular PSU
• - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX 160W RMS
• - WD RaptorX 150GB \ WD Raptor 150GB \ Hitachi 1TB
• - Custom Modded CoolerMaster 810
• - Dell UltraSharp 2407WFP-HC 24''
Watercooling Loop #1 : D-Tek FuZion (Quad Core Nozzle) - 2x MCW30 (NB\SB) - T-Line + Fil-port - MCP355 w/ Petra's Top - Thermochill PA120.3 (3x Scythe SFF21F S-FLEX™) - Masterkleer 7/16" ID 5/8" OD
Watercooling Loop #2 : 2x Ek-FC 8800GTX WBs - Swiftech MCRES - MCP355 w/ Petra's Top - Thermochill PA120.2 (2x Scythe SFF21F S-FLEX™) - Masterkleer 7/16" ID 5/8" OD
X.E.T.M Completed
January - SLI Rig Of The Month
01-18-2007, 07:18 AM
#13
Lets wait first for Nikhsub1 to have the new o-ring and show us the test with apogee gt and fuzion.
Also, i think that we should take care in finding the right design of a nozzle for the fuzion.
01-18-2007, 11:27 AM
#14
My apogee came preassembled. I'm not sure if this is normal or not. So I never really thought much about orientation. Guess when I pull it apart to do o-ring soon, I'll make sure
__________________
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
01-18-2007, 01:18 PM
#15
You can see fairly easily by looking into the block from the barb openings just make sure it looks like the pic at the top of the thread.
__________________
Main Rig:
| eVGA X58 Classified | 920 D0 | Corsair Dominator GT 3x2gb | 3X eVGA GTX285 -Tri SLI |
| 4x 32gb SSD - RAID 0 | Plexy 716SA Black | PC P&C Turbo Cool 1200 | Dell 2405FPW |
| Dimastech Bench Table |
HEAT EBAY
01-18-2007, 01:31 PM
#16
Hmmm...I might have to try a bowed base on my custom block, seeing as how the Apogee is nearly a direct ripoff of my Whatblock design (just wider.)
http://www.ocforums.com/showpost.php...90&postcount=1
(okay don't have a cow Swiftech guys...I'm just messin with ya!  )
01-18-2007, 07:11 PM
#17
Xtreme Cruncher
I'd almost be scared to use that on a Kentsfield. Would it be able to fully cover both dies? It looks like it might not be wide enough. lol
__________________
A wolf in wolves clothing.
01-18-2007, 07:35 PM
#18
Don't sweat on the nozzle design of the Fuzion. D-Tek will be releasing pre-tested nozzle kits for different system characteristics. It was in the works before anyone here ever tested it. They are in the process of testing various size nozzles for the end user, so they will have a clue which one to select for their components. With the flow advantage the Fuzion has you could place quite a decent downsized nozzle in there and still outflow most blocks. I don't think it will be much longer before you see the nozzle kit on their site.
__________________
ASUS P5B-Deluxe
C2D E6600 @ 3.525g
G.Skill 2x1gb PC6400 HZ's
2x Seagate 400gb SATAII HDD's
PNY 7900GS @ 450/1320mhz
Lite-On SATA and IDE DVD-RW
OCZ GameXTreme 600w PSU
D-Tek FuZion "bowed"
LAING D5
Thermochill PA120.2
2x Scythe SFF-21F's
01-18-2007, 07:44 PM
#19
LOL! Yeah, it's definitely from another era.
Would be very easy to make a wider one though. Hmmm...
01-18-2007, 08:10 PM
#20
...at which point my MP-05 SP LE gets replaced...
__________________
Components
Case: Antec P180/ PSU: PCP&C Silencer 610 (dual fan modded)/
Mobo: Gigabyte GA-P35-DQ6/ CPU: c2Q Q9550 @ 3.18 GHz/
VGA: Sapphire Vapor-X 4890/ Memory: 8 Gb G.Skill DDR2 800
OSs: Win7 HP x86_64/ Kubuntu 10.04 x86_64
Cooling
CPU: D-Tek FuZion v1- fitseries3 Delrin top
GPU: EK FC4890
Rads: 1x Thermochill P120.3, 1x Swiftech MCR120 (pre QP)
Pump: Swiftech MCP350 with Petra's top
Fans: 3x low-speed Yates @750/ 567rpm, 1x low-speed S-Flex @800/ 500rpm, 1x Kama Flex @1000/ 500rpm, 1x modded Nexus Real Silent @800rpm
Tubing: 3/8" x 5/8" Tygon R3400
certified quiet PC loony
01-21-2007, 02:49 PM
#21
does this apply to the GT only or both (the regular and GT)?
__________________
Intel Core 2 Duo E6400 L625A491 @ 3.2 Ghz 1.36V dual prime stable 25+ hrs large FFTs |
4GB (4x1024) D9GMH 1:1 |
P5B deluxe | 8800GT | XiFi Xtreme Music | 2x Raptor 150GB Raid 0 | Westy 37w3 | Zippy PSL-6850P(G1)-PCIE4 PSU | Lian Li v1200Aplus WC|
01-21-2007, 02:52 PM
#22
both
__________________
01-21-2007, 06:55 PM
#23
blah, now i have to take apart my loop to see if I have the correct orientation? Is there an easier way to do this?
__________________
01-21-2007, 07:26 PM
#24
What about MCw60?
01-21-2007, 08:21 PM
#25
Xtreme Cruncher
You could use a specular mass techtrometer with a inverse diode attachment to measure various anomalies in the newtonic molecular substrate of the base-plate...
Ply
__________________
Antec 900 Case
Q6600 SLACR @3550 / Giga P35 DS3R
Cooler Master Hyper 212/ PCP&C Quad 750
4 gigs G.Skill PK series
BFG 8800gt / Thermaltake DuoOrb GPU Cooler
X-fi pci-e / Logitech Z5300
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
