XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 01-08-2007, 02:47 AM   #1
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
Thumbs up Corsair PC10000 1250Mhz @ CES
XS has a demo machine setup at the Corsair suite running the new Dominator PC10000, I had a few days to play with the ram and I am very impressed with the high speed and lower latency this product is capable of delivering.
Let the numbers speak for themselves. These results were done at the default Mhz and just the timing was changed, I tighened it up @ 2.4v, pretty much the maximum safe voltage that I would suggest for 24/7 use.
The motherboard is the first round of the evga 680i, I will switch over to the Abit Max board for the Swiftech/XS OC event on Tuesday.
1250Mhz @ 4-4-3-x 2.4v
__________________
Intel Core i5 661 @ 4.6Ghz
Gigabyte P55A - supports 32nm now
Gigabyte GTX 260 SOC
Corsair Dominator 8GB 2200C8
Intel SSD RAID 0
http://valid.canardpc.com/show_oc.php?id=925582
FUGGER is offline   Reply With Quote
Old 01-08-2007, 03:10 AM   #2
mrlobber
mrlobber's Avatar
Send a message via Skype™ to mrlobber
Siiiiiiiiick.
The speed and undoubtedly the price as well
__________________
away & gone
mrlobber is offline   Reply With Quote
Old 01-08-2007, 03:10 AM   #3
jimmyz
Xtreme 3D Team Member
jimmyz's Avatar
wow nice clocks for only 2.4v !!!
question time:
1. what ic's?
2. what is max 1t speed and timings?
3.are those speeds posted memtest stable?
4. were those hand picked or retail samples?
jimmyz is offline   Reply With Quote
Old 01-08-2007, 03:15 AM   #4
erwinz
very nice mems.. I hope I can go at the exhibit..
__________________
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800 , E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
Ati FireGL V5100, Elsa FireGL V3100
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
Silverstone OP650
raptors, baracuda
erwinz is offline   Reply With Quote
Old 01-08-2007, 03:52 AM   #6
FUGGER
Xtreme Owner
FUGGER's Avatar
I have benches on the other drive and I will run extensive tests on Tuesday. I will also do a 3-3-3-9 1T push to see where this stuff tops out at.
__________________
Intel SSD RAID 0
Old 01-08-2007, 03:59 AM   #7
XSAlliN
XSAlliN's Avatar
That C2 X6800 at 4.000 Mhz helped to achieve those results .
__________________
XSAlliN is offline   Reply With Quote
Old 01-08-2007, 04:00 AM   #8
N3RO
N3RO's Avatar
Send a message via MSN to N3RO
Are retail or samples?
Can run 3dmark at 625@4-4-4?
How much €€?
[]s
__________________
Feedback Heatware
N3RO is offline   Reply With Quote
Old 01-08-2007, 04:05 AM   #9
dinos22
...you two characters
dinos22's Avatar
How much €€?
[]s
they are rated at that speed....of course they will be able to do that
the only thing i am wondering about is what mobos or chipsets are confirmed to be able to run at those speeds.......would be interesting to see whether they will support 975X chipset as well heheheh
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 01-08-2007, 04:05 AM   #10
NapalmV5
LOVE=MC²
NapalmV5's Avatar
let me guess.. 1000$/2x1GB kit?
__________________
NapalmV5 YouTube vidz
NapalmV5 is offline   Reply With Quote
Old 01-08-2007, 04:06 AM   #11
FUGGER
Xtreme Owner
FUGGER's Avatar
Retail pack samples, part number read-able above.
CPU Mhz doesn't matter, FSB speed does. I am up at/over 500 producing top numbers seen from any 680i. 975x should be insteresting, I will have to push for lowest latency settings.
__________________
Intel SSD RAID 0
Old 01-08-2007, 04:06 AM   #12
N3RO
N3RO's Avatar
lololol
not for mortal people
__________________
Feedback Heatware
Old 01-08-2007, 04:20 AM   #13
nn_step
YouTube Addict
nn_step's Avatar
Oh god, imagine the latency if it was on an AMD board
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is offline   Reply With Quote
Old 01-08-2007, 07:05 AM   #14
mascaras
Xtreme Mentor
mascaras's Avatar
Corsair Releases World's First PC10000 2GB kits
As a part of the CES live demonstrations, Corsair announced the new TWIN2X2048-10000C5DF DOMINATOR memory kits. Designed for overclocking and achieving the highest frequencies in mind, the TWIN2X2048-10000C5DF DOMINATOR is rated and tested at a frequency of 1250MHz(5-5-5-15-2T@2.4V), thus making it the world's highest frequency production ready memory. Specially designed for NVIDIA nForce 680 SLI media and communications (MCP)-based motherboards, the new DOMINATOR extends Corsairs leadership in enthusiast memory. All DOMINATOR memory modules feature Enhanced Performance Profiles (EPP) and SLI-Ready technology. As a DOMINATOR modules the Airflow Fans are included within each kit. A DOMINATOR heat sink assembly, using DHX technology and the addition of the Airflow fan, allows a Corsair module to reach PC10560 or 1320MHz at CAS 5 settings. The TWIN2X2048-10000C5DF DOMINATOR 2GB kits will be available by the end of January through Corsair's worldwide authorized distributors, retailers, resellers and e-tailers. All Corsair memory products are backed by a lifetime warranty and complete customer support.
http://www.corsairmemory.com/corsair...OR_PC10000.pdf
regrds
__________________
[Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
[Review] ASUS HD4870X2 TOP » Here!! «
.....[Review] EVGA 750i SLi FTW » Here!! «
[Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
[Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
mascaras is offline   Reply With Quote
Old 01-08-2007, 07:19 AM   #15
Yellowbeard
Corsair Rep
Yellowbeard's Avatar
Send a message via AIM to Yellowbeard
LOL...yeah, it would be hard even for FUGGER without a CPU.
__________________
Yes, Yellowbeard, a tall rough man with a big yellow beard
Yellowbeard is offline   Reply With Quote
Old 01-08-2007, 07:24 AM   #16
lawrywild
Xtreme Cruncher
lawrywild's Avatar
Send a message via MSN to lawrywild
No, they're rated at 625 5-5-5 not 625 4-4-4
__________________
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
lawrywild is offline   Reply With Quote
Old 01-08-2007, 08:20 AM   #17
kemo
Send a message via MSN to kemo Send a message via Skype™ to kemo
So that will cost 700+$ or more ram price/speed gone crazy these days
__________________
Intel Core I7 920 @ 3.8GHZ 1.28V (Core Contact Freezer)
Asus X58 P6T
6GB OCZ Gold DDR3-1600MHZ 8-8-8-24
XFX HD5870
WD 1TB Black HD
Corsair 850TX
Cooler Master HAF 922
kemo is offline   Reply With Quote
Old 01-08-2007, 08:21 AM   #18
Brettbeck
Brettbeck's Avatar
Send a message via MSN to Brettbeck
Hey FUGGER... do you have any pictures yet from the first day at CES? Or anyone else for that matter .
Brettbeck is offline   Reply With Quote
Old 01-08-2007, 08:29 AM   #19
NapalmV5
LOVE=MC²
NapalmV5's Avatar
lololol
i guess only when we pass to immortal..
Fugger, yeh, let us know how low the timmings go on the 975x.. thanx!
__________________
Old 01-08-2007, 08:37 AM   #20
marauder16
marauder16's Avatar
Send a message via MSN to marauder16
man this speed is sick, and only at 2.4V! just wondering what lies under the hood, must be some great handpicked GKXs to run that thing...
__________________
DFI ICFX3200 07/30 w/ MCW30
E6600 L632A407 w/ EK Supreme
Powercolor HD3870 w/ MCW60
OCZ Reaper 2x2GB CAS4
WD Caviar Black 1TB
Silverstone Strider 750W
MM U2-UFO Extended CYO
CPU & NB loop = PA120.3, DDC 18W w/ Petra's top, 7/16''
VGA loop = PA120.2, DDC 18W w/ Petra's top, 7/16''
10 fans on 7V, PX-750A, all on SM 930BF
" Having a DFI board is like having a hot girlfriend thats a total b1tch" ...
marauder16 is offline   Reply With Quote
Old 01-08-2007, 09:58 AM   #21
Redbeard
Corsair Rep
Redbeard's Avatar
You have no idea, Bachus spent the past 2 weeks screening to make what few kits we have now! Heh.
Redbeard is offline   Reply With Quote
Old 01-08-2007, 10:14 AM   #22
XSAlliN
XSAlliN's Avatar
Hire more people.
PS.I'm available .
__________________
Old 01-08-2007, 12:04 PM   #23
filmbot
filmbot's Avatar
Send a message via AIM to filmbot Send a message via MSN to filmbot
Glad to see Bachus is making quite an impact over there thus far
filmbot is online now   Reply With Quote
Old 01-08-2007, 12:27 PM   #24
Vapor
Admin
Vapor's Avatar
To anybody claiming these are unrepresentative cherries....the entire PC10000 line are cherries
Vapor is offline   Reply With Quote
Old 01-08-2007, 12:31 PM   #25
frankR
frankR's Avatar
12.5 GB/s bandwith !!
or
0.1 Tb/s.
__________________
Intel E8400.C0 "Wolfe"| 400x9 3600 Mhz @ 1.272 Vcore
TT Sonic Tower | Dual 120mm Antec Fans | Silent Air @ 1200 RPM
ASUS P5Q-E | BIOS 0610
G.Skill F2-8000CL5-2GBPQ | 400 MHz (5-5-5-15) @ 2.0 V (? Auto)
XFX 7800GT
Wester Digital Raptor 74GB | Maxtor Maxline III 300GB | Seagate 7200.7 120GB
Antec P-180 | Antec True Power 2.0 550W
Dell 2407 | Dell 2405
frankR is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
