XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 01-06-2007, 11:29 AM   #1
bigKr33
tuniq tower 120 performance?
How does the tuniq tower 120 perform on a opty 165? I can't find any reviews or anything of it tested on opterons.
I'm planning on air cooling my comp again. I'm hoping i would be able to keep it stable at 2.8-3ghz on air. Case of choice would be a pc-7b plusII to keep proper airflow.
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 01-06-2007, 10:40 PM   #2
enz660
enz660's Avatar
my guess is that you will stay between 55-60c depending on the voltage that you are using.
edit: ok, so in your sig you have 1.475. I overclocked an a64 x2 socket 939 to 2.5 on that same vcore using a big typhoon. The fan spun at 800rpms and temps did not rise over 53c. Make sure you lap the tuniq if you get it.
__________________
Specs:
- e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
- P5W DH Deluxe Cooling Mod
- 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
- Nvidia 7800gt (490/575) +.1vmod (Upgrading xmas 07)
- Silverstone ST75F 750watt
- Modded Asus Vento (Black) *Heavy Case Modding In Progress*
enz660 is offline   Reply With Quote
Old 01-07-2007, 11:47 AM   #3
Baenwort
Baenwort's Avatar
The TT should be flater then you can get by hand laping. If yours isn't you should get it returned. As far as a Opt 165. I had mine on a TT for about 3 months before my Apt got broken into and it was stollen. At 1.45 with a Silverstone FM121 inside at full speed I was runing 2.9 at ~47C load with a Amb of 21C. I had it in a moded P180 case.
Baenwort is offline   Reply With Quote
Old 01-07-2007, 11:52 AM   #4
ReelFiles
ReelFiles's Avatar
Send a message via MSN to ReelFiles
CoreTemp reads 28C idle / 50C load on a naked Opty 170 @1.475v, ambient temps ca 80F. Best air cooler I've ever had.
__________________
R.I.P. DFI-Street
ReelFiles is offline   Reply With Quote
Old 01-09-2007, 12:58 AM   #5
aka1nas
Do you guys think it would be noticeably better than an XP-90? I have my Opty 165 @2.8Ghz on one and it idles at 26C and hits up to 65C on sustained Orthos Load.
aka1nas is offline   Reply With Quote
Old 01-09-2007, 01:11 AM   #6
enz660
enz660's Avatar
tt 120 will be a lot better than an xp90. Flatter than you can get it by hand? I can make an ultra flat, mirror finish thats always better than stock. Have you ever lapped a heatsink before?
__________________
Specs:
Old 01-09-2007, 01:26 AM   #7
dranom
dranom's Avatar
i have a TT 120 on my opty 165 2.8ghz 31c idle 49-52c full load on orthos. 1.4vcore on a mozart tx case.
dranom is offline   Reply With Quote
Old 01-09-2007, 05:53 AM   #8
ineedaname
ineedaname's Avatar
I used to have a opty 165 CCB1E running at 3ghz with 1.5vcore that was about max load 55C with a zalman 9500 with 80CFM fan. I'm positive you will get better results with the infinity as long as you have a decent stepping. Oh and as a side note i used liquid metal for my TIM.
__________________
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
ineedaname is offline   Reply With Quote
Old 01-09-2007, 05:59 AM   #9
ineedaname
ineedaname's Avatar
The infinity is a lot better but you're probably better off getting a faster fan blowing on your xp-90. I also have the xp90 and it works best with high cfm fans like the vantec tornado. The vantec tornado is really loud though so u might wanna find something else.
__________________
2xHR-05
2xHR-09
Vid: HIS 4850
3dmark06: 16k
Old 01-09-2007, 11:42 AM   #10
aka1nas
I have a ~48CFM Panaflo 90mm fan on it right now. Other than the Tornado, I'm not sure what I can put on it that would be faster.
Old 01-10-2007, 01:41 PM   #11
junkun13
junkun13's Avatar
can i mount a 120x35m fan on it's side using zip ties?
junkun13 is offline   Reply With Quote
Old 01-10-2007, 03:30 PM   #12
bigKr33
wow really good input on cooling solutions thanks. a few months from now ill be sent to my new duty station for the navy so making my computer smaller and more practical will make things a little easier when I move. I wont be doing the rebuild right away, and to be perfectly honest I may just let my parents have the computer, or sell it,but we'll see.
__________________
Gaming PC
Living Room
Heatware
Old 01-11-2007, 02:06 AM   #13
junkun13
junkun13's Avatar
anyone?
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
