XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 01-05-2007, 08:37 PM   #1
bigKr33
mid tower suggestions?
im thinking of getting lian li's pc-7bPLUSII case. does this case have pretty good airflow? im putting everything you see in my sig minus the water cooling in it, if I get it . hopefully I can keep my opty stable on air with same speeds.
my stacker is way too large. something a little more practical will do. any mid tower case suggestions?
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 01-05-2007, 09:39 PM   #2
Pepi93
Lian-Li PC60B+II is a better choice, read the difference in specs on newegg...this will give you more room and airflow, I was also going to choose the 7b but once I read it more carefully, I decided to go with the P60B+II, now the only thing is to wait until someone locally gets it back in stock....another task at hand here in Toronto.
Pepi93 is offline   Reply With Quote
Old 01-06-2007, 12:58 AM   #3
alejo
alejo's Avatar
I bought the 7B and I like it so far. Just take off the black mesh for the fans and it should increase air flow. I like how the front of it also seems very open and unrestrictive and unlike the PC60B+, it has 120mm fans instead of 80mm in the back. I'm pretty happy wit the temps I'm experiencing. I keep my room pretty cold though, so your mileage may vary.
alejo is offline   Reply With Quote
Old 01-06-2007, 08:27 AM   #4
bigKr33
thanks for the input,greatly appreciate it now its time to find the right heatsink to cool my opty.
__________________
Gaming PC
Living Room
Heatware
Old 01-06-2007, 01:33 PM   #5
thespeakerbox
thespeakerbox's Avatar
scythe infinity .
thespeakerbox is offline   Reply With Quote
Old 01-07-2007, 07:46 PM   #6
bigKr33
thanks for the suggestion,but just recently I found a review with a opty 170 oc'd to 3ghz@1.52v being cooled with the tuniq tower. his temps were between 45-47c I find that to be pretty amazing.
whats really hard to find though is led 120mm fans that perform real well. if I get that lian pc-7b, im replacing the fans because I want a little more flash. fans I was looking at were yate loons blue led, aerocool xtreme turbine w/89cfm (not sure how accurate that is), and well thats bout it
I heard that yates perform real well,but im not sure if 47cfm is going to be sufficient enough.
__________________
Gaming PC
Living Room
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
