XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Security & Networking
Reply
Old 01-05-2007, 05:03 PM   #1
Vapor
Admin
Vapor's Avatar
Recommend me a PCI(e) NIC :)
Well, just looked at the back of XBX2 for the first time after using it for nearly 3 weeks, just noticed it doesn't have two LAN ports
I need 2+, so I'm in the market for an NIC, but don't really want to spend much money....so I guess two (or more) ports on the NIC are a must, as is a good price
PCI or PCIe, both work
EDIT: wow, I can't even find one with 2+ ports that is inexpensive (at least for an NIC).....any good single port cards anybody can recommend that don't break the bank?
Vapor is offline   Reply With Quote
Old 01-05-2007, 06:32 PM   #2
pissboy
syskonnect SK-9E21D
Intel Pro/1000 Pt Desktop http://www.techonweb.com/products/pr...=C37982&src=FG
and for not too much more - syskonnect SK-9e22 dual port
note that dual port cards won't be x1 and shouldn't be pci (if they're gigabit at least)
pissboy is offline   Reply With Quote
Old 01-05-2007, 07:48 PM   #3
Vapor
Admin
Vapor's Avatar
Hmmmm, are things cheaper than that really bad? I don't really need it to do anything fancy (just need it to not suck), I have slower in-line hardware that'll bottleneck it anyway.
Old 01-05-2007, 07:56 PM   #4
nn_step
YouTube Addict
nn_step's Avatar
well this beast will definitely take care of your needs
it will work in PCI but its true power will not show up until you put it in PCI-X
http://www.newegg.com/Product/Produc...82E16833316009
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is offline   Reply With Quote
Old 01-05-2007, 07:58 PM   #5
Vapor
Admin
Vapor's Avatar
Wow, way more than I need
I just couldn't bring myself to spend that much on an NIC....even if it doubled my bandwidth (well, maybe.... )
Old 01-05-2007, 08:01 PM   #6
nn_step
YouTube Addict
nn_step's Avatar
fine, get two of these
http://www.newegg.com/Product/Produc...82E16833166003
since dual RJ-45 is usually on Server line cards, they don't come cheap
__________________
-Linus Torvalds
Old 01-05-2007, 08:08 PM   #7
Vapor
Admin
Vapor's Avatar
Hmmm, cool....looks like it's worth the $$.
Old 01-06-2007, 08:13 AM   #8
Omastar
Banned
Send a message via AIM to Omastar
XBX2 has no PCI-Ex1 slots.
Omastar is offline   Reply With Quote
Old 01-06-2007, 09:48 AM   #9
Vapor
Admin
Vapor's Avatar
But you can put PCIe 1x devices into larger slots.....
Old 01-06-2007, 06:45 PM   #10
nn_step
YouTube Addict
nn_step's Avatar
you can put PCIe 1x cards into:
32x
16x
8x
4x
2x
1x PCIe slots
but not into any PCI, AGP, PCI-X, or ISA slots
__________________
-Linus Torvalds
Old 01-06-2007, 06:52 PM   #11
Vapor
Admin
Vapor's Avatar
You knew what I meant
Old 01-06-2007, 06:53 PM   #12
nn_step
YouTube Addict
nn_step's Avatar
I know that you know, but I'm making sure that when some noob reads this thread they become wiser
__________________
-Linus Torvalds
Old 01-06-2007, 09:47 PM   #13
Knight
Knight's Avatar
I will.
__________________
Intel | Q6600
ASUS | P5Q-Deluxe
G.Skill | 2x2GB PQ
Nvidia | 8800GTS 320MB
Seagate | 2x320GB 7200.10 Raid 0
Corsair | 520W PSU
Knight is online now   Reply With Quote
Old 01-06-2007, 09:54 PM   #14
Omastar
Banned
Hmm, didn't know you could drop 1x into PCI slots. So why do mobo manufacturers even care about making PCI-Ex1 for their boards? What, higher bandwidth or something?
Old 01-06-2007, 10:21 PM   #15
Vapor
Admin
Vapor's Avatar
Omaster....PCIe 1x can go into any PCIe slot, not PCI. I have two open of both, so I didn't care which type of slot the card used.
Old 01-06-2007, 10:21 PM   #16
p0tter
p0tter's Avatar
haha, thanks for schooling me.
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline   Reply With Quote
Old 01-06-2007, 10:35 PM   #17
Omastar
Banned
Ah okay, had a brain fart there.
How about this:
http://www.newegg.com/Product/Produc...82E16833156139
Old 01-06-2007, 11:20 PM   #18
phelan1777
BLAH!!!!!!!!!!!
wow I didnt know about this.
So if space is a concern, and I don't like most on board LAN chipsets anyway. I can get one of these, and the are particulary small.
__________________
Mammal brains are rather like the engines in American performance cars. We tend to use cubic inches to compensate for the lack of precision engineering.
Movieman's alter ego ---------> SUPER MOD NOOB ADMIN!
Originally Posted by nn_step View Post
(A Professor to a class of students)
"If you put the sand into the jar first," he continued "there is no room for the pebbles or the rocks. The same goes for your life.
Take care of the rocks first - the things that really matter. Set your priorities. The rest is just sand."
Originally Posted by Omastar View Post
Those chubby chicks can be amazing in the sack sometimes, you know. (waits to be sigged)
phelan1777 is offline   Reply With Quote
Old 01-07-2007, 05:22 PM   #19
justin_c
Xtreme Cruncher
justin_c's Avatar
look at this:
http://www.wisp-router.com/itemdesc.asp?ic=RB44&eq=&Tp=
http://www.routerboard.com/rb44.html
i was going to build a ipcop box, but i just forgot about it.
justin_c is offline   Reply With Quote
Old 01-12-2007, 08:20 AM   #20
Madwand
The SysKonnect PCIe NICs are really nice IMO. They're Marvell-based. Good performance, driver support, feature set, and CPU utilization. The PCI versions aren't as good for performance, but do the other things well. Price and availability's the hard part with them -- they both vary strangely.
You can sometimes find these and others often for good prices on eBay. That's probably the only way to drop the prices on multi-port cards. PCI-X Server pulls are very common, and generally backwards compatible with PCI, but you'll give up something in performance with them (if it matters).
The Realtek-based NICs, such as the TrendNet, tend to perform OK, but at relatively high CPU utilization. Intel-based NICs are generally a good choice, although often at a bit more than SysKonnect/Marvell.
Madwand is offline   Reply With Quote
Old 01-16-2007, 05:13 PM   #21
Vapor
Admin
Vapor's Avatar
nn, got the Rosewill you suggested, worked out very well
Thanks for the help all.
Also, that NIC looks sweet, as small as it is (matte black PCB coating ).
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
