XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 01-05-2007, 01:53 PM   #1
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
Any benefit to running AHCI on P965?
I'm about to reinstall windows finally after viruses, ram tweaking, and other crap destroyed my current install. I'm curious about something. When I first setup this core 2 system however many months ago and ditched my opty 165, I noticed a big drop is program "snappiness". Programs definately didn't pop up as quickly. At first I attributed that to higher latencies on the FSB and DDR2, but when I really started tweaking and got the higher clocks with my conroe and it was STILL noticabley slower in this regard, I got to thinking it might be my drives.
When I installed windows last time, I used no driver, and left bios at it's defaults. Now I see this AHCI stuff and notice that I can install an Intel Matrix Storage driver with F6 on a fresh windows install. Now first of all...what is AHCI? And do I want it if I'm running a single 74GB Raptor for boot/programs and a 36GB Raptor for storage?
Thanks.
EnJoY is online now   Reply With Quote
Old 01-05-2007, 08:21 PM   #2
STickGuy
STickGuy's Avatar
Send a message via MSN to STickGuy
Good Post i would like to know 2
STickGuy is offline   Reply With Quote
Old 01-05-2007, 08:28 PM   #3
alejo
alejo's Avatar
As far as I know, if you run in AHCI you get some features native to SATA. You get NCQ and the ability to hot swap.
alejo is offline   Reply With Quote
Old 01-06-2007, 07:37 AM   #4
EnJoY
XIP
EnJoY's Avatar
Okay, do these native benefits also include anything that equates to a performance boost?
Old 01-06-2007, 07:43 AM   #5
newls1
Xtreme Cruncher
newls1's Avatar
Send a message via AIM to newls1
What a damn good question! Would like to know this answer as well.
__________________
No more PC, damn economy
02 Tahoe with a *NICE* stereo! Soon to be:
2 300a alts, 4 AQ2200D amps, AQ90x4 amp, 4 18" AQ HDC3A's (2200RMS Watts each) multi batts in rear all G31's, MLA 15.4v module, etc.... Nearing 10,000watts
newls1 is offline   Reply With Quote
Old 01-06-2007, 10:20 AM   #6
Dr.Frankenstein
Dr.Frankenstein's Avatar
You should look into using the Limited account coupled with RunAs. Of course, even with all that protection, you still need to scan anything before giving it privileges.
Dr.Frankenstein is offline   Reply With Quote
Old 01-06-2007, 11:46 AM   #7
EnJoY
XIP
EnJoY's Avatar
I just need to stop using bittorrent.
Old 01-06-2007, 01:53 PM   #8
freecableguy
Banned
freecableguy's Avatar
Send a message via MSN to freecableguy
I hear using AHCI makes your sperm swim faster. Is that a benefit?
freecableguy is offline   Reply With Quote
Old 01-06-2007, 05:26 PM   #9
roibm
nope... in this case slower is better
roibm is offline   Reply With Quote
Old 01-06-2007, 07:50 PM   #10
d.chatten
d.chatten's Avatar
Thanks.
With the old Raptors with an 8meg cache you won't see any difference at all in performance, the new Raptors with a 16meg cache you get NCQ (Native Command Queing) "if AHCI is enabled" which gives a very small performance boost when multitasking, you also get the Hot Swap feature, also with AHCI mode you get up to 300MB/s (SATA II) transfer rates if the drive you use supports 300MB/s transfer rates.
Apart from a very small performance boost when multitasking with an NCQ capable drive you won't notice any difference at all.
Hope this helps!
__________________
Asus P5W DH Deluxe
Intel Core 2 Duo E6850
Zelman CNPS9500 AT
Crucial Ballistix PC2-8500 4x1GB
BFG GeForce 7800 GTX OC 256MB
Enermax Galaxy DXX EGX1000EWL 1000W
Western Digital Raptor WD1500ADFD x3
Pioneer DVR-115DBK x2
Plextor DVDR PX-716A
CoolerMaster Stacker 830 Evolution
d.chatten is offline   Reply With Quote
Old 01-06-2007, 07:52 PM   #11
Charloz24
Charloz24's Avatar
Don't know what in h*ll AHCI is, but what I do know is that you have to run in AHCI on 965 boards to be able to run Ubuntu, Kubuntu etc. (if you still have IDE drive/ cd/dvd)
__________________
Q6600 rig coming soon....
Charloz24 is offline   Reply With Quote
Old 01-07-2007, 03:13 PM   #12
EnJoY
XIP
EnJoY's Avatar
You know me Kris...the last one to win the race is the one that saves me the slap in the face.
Hope this helps!
Thanks dude, very helpful.
Old 01-07-2007, 03:25 PM   #13
quicksilverXP
Yesh... I noticed the same things when I switched from AMD to Intel. My older AMD system was quicker to open certain programs. For example, I get the "rolling" effect of the icons the first time I open the Control Panel. But with my older AMD system, the icons would just all snap open.
Yet in benchmarks, games, and encoding the Conroe is way faster. Done all the tweaking I could possibly do and I think that's just the way it is. Maybe it's just the 965 chipset or somethin.
quicksilverXP is offline   Reply With Quote
Old 01-07-2007, 07:42 PM   #14
newls1
Xtreme Cruncher
newls1's Avatar
I thought I was the ONLY ONE to notice the "rollin" effect when opening control panel, damn glad im not, heres to ya
__________________
Old 01-08-2007, 03:31 AM   #15
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
no AHCI doesnt do anything for speed regardless of what somepeople dig up out of Intel articles.
for you linux geeks it does help do 1 thing.
install Linux.
with AHCI OFF, linux will not install becuase it thinks it cant see the cd rom to load from .
but with it ON then everything is fine.
not sure why it cant find the cd to load from because it just booted to it in order to get to the install gui, and then the gui turns around and says "doh! i lost it, now i cant install"
stupid linux
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 01-08-2007, 03:59 AM   #16
eva2000
Memory Addict
eva2000's Avatar
install Linux.
stupid linux
for linux and jmicron based 965p you need to install and boot linux with command line option of -all-generic-ide
eva2000 is offline   Reply With Quote
Old 01-08-2007, 04:05 AM   #17
nn_step
YouTube Addict
nn_step's Avatar
http://www.intel.com/technology/serialata/ahci.htm
for the most part it is kinda helpful, but you hit one of Intel's flaws right on the head. Poor hard drive support (since it doesn't matter in benchmarks that Intel uses)
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
