Here's the data sheet
http://www.intersil.com/data/fn/fn9070.pdf
It looks like pin 3 is ground. I would wait for someone else to verify this before you try anything.
It looks like you need a Variable Resistor on pin 3 to 6 and another on pin 3 to 9. I'm not sure which set controlls what. If you start with 200K ohms and slowly turn down the resistance. You could figure it out. It probally won't change until you hit 100K or 50K, maybe even 25Kohms, 200K is just playing it safe.
Your voltages should read off the + leg on the capacitors, I'm not sure which ones though. Hopefully someone can add to this.
