XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 01-04-2007, 12:19 PM   #1
bigKr33
switching to aircooling?
is there any heatsink on the market that can keep an overclocked opty stable as seen in my sig?
im planing on putting all my hardware in a lian li case thats smaller than my stacker. my computer is not practical enough for what I do. my computer as of now needs too much attention and im not always around to do that. so I really feel that having a lighter air cool setup is the way to go.
any suggestions?
__________________
Gaming PC
In planning stages...
Living Room
46" Sony Bravia XBR4 | Xbox 360 Elite | Arcam AVR-600 rcvr | Paradigm studio 60's v.5 (fronts) bi-amp'd | Paradigm studio cc-590 v.5 (center) bi-wired | Paradigm studio 10's v.5 (rear) | Velodyne optimum-12" sub | Richard Gray 400 pro power conditioner | Analysis oval-12 speaker cable
Heatware
bigKr33 is offline   Reply With Quote
Old 01-04-2007, 07:59 PM   #2
bigKr33
well I did find one heatsink, and that is the tuniq tower 120. from what ive seen, people have being using them on overclocked quad core intels. anyone see how well they're doing on dual core opty's?
__________________
Gaming PC
Living Room
Heatware
Old 01-04-2007, 08:28 PM   #3
enz660
enz660's Avatar
as long as the new case you have is at least 19cm wide, the tuniq should fit. On another note, if a 3ghz opty is not practical for what you do, why not lower the overclock a bit? Then you can choose between quieter heatsinks.
__________________
Specs:
- e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
- P5W DH Deluxe Cooling Mod
- 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
- Nvidia 7800gt (490/575) +.1vmod (Upgrading xmas 07)
- Silverstone ST75F 750watt
- Modded Asus Vento (Black) *Heavy Case Modding In Progress*
enz660 is offline   Reply With Quote
Old 01-05-2007, 08:46 AM   #4
bigKr33
my opty is perfectly stable as well as reliable, but water cooling and being in the navy isnt all that easy. an air cooling solutions rids the constant maintenance and check ups.
I brought the tuniq tower in the equation because it seems like the only logical choice to cooling a 3ghz opty on air. it doesnt take alot of voltage to keep my opty 24/7 prime stable as you clearly see in my sig. oh and my case decision is either a mid tower lian li, or antecs new 900 case.
well its either air cooling or I sell the computer.
__________________
Gaming PC
Living Room
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
